Dtek FuZion-GFX
Visualizzazione dei risultati da 1 a 10 su 64
    Mar 2006
    Predefinito Dtek FuZion-GFX
    Detailed Description
    The all-new D-Tek FuZion™ GFX CPU block will bring a new level to GPU cooling with its direct impingement design, appearance, and high quality manufacturing. Unique to the FuZion™ GFX is the mid chamber design that provides good flowrates while utilizing direct impingement to the GPU core that puts this block at the level we normally see only in CPU cooling designs. The GFX is the perfect match for the FuZion™ CPU waterblock.
    Features:
    * 100% copper baseplate featuring dense rounded pins and smooth flow channel.
    * Anti-oxidant treated precision machine lapped copper baseplate.
    * Low profile design allows installation with Nvidia® SLI and ATI's CrossFire™ systems.
    * Black one-piece molded delrin mid chamber is pressure balanced and internally optimized for rapid water transfer.
    * G-1/4" hose barb threading offers compatibility with a wide variety of cooling kits currently on the market as well as direct European compatibility.
    * Chrome plated 1/2" or 3/8" Hi-Flow hose barbs included.
    * Includes all hardware and chrome plated S/S mounting and backing plates for ATI® and Nvidia® video cards including the 8800
    * 100% leak tested prior to distribution.
    Compatibility:
    The D-TEK FuZion GFX™ comes with all the necessary mounting hardware for the following Video Cards.
    ATI:
    * ATI Radeon® X1000 series via the 4 mounting holes though the video card.
    Nvidia:
    * Nvidia® 8000 Series via the 4 mounting holes through the video card and included 8800 mounting and backing plates.
    * Nvidia® 6800 / 7800 / 7900 series via the 4 mounting holes through the video card.
    The Fuzion GFX includes provisions for 2-hole mounting systems as seen on older video cards (i.e. Radeon 9800pro). An optional mounting kit will be available in the future to mount the GFX to these particular video cards.
    D-TEK guarantees compatibility only with video cards following the ATI and Nvidia® reference designs.
    [SIGPIC][/SIGPIC]
    Mar 2006
    esteticamente ..visto cosi... non mi sembra il massimo
    speriamo nelle performance...
    poi sarebbe da capire com'è montato, c'è quella placca in acciaio alla base, magari hanno fatto un wb che si potrà adattare ad altre vga cambiando quella placca.
    [SIGPIC][/SIGPIC]
    Jan 2005
    Anche questo segue il concetto di base del fuZion....
    A vederlo cosi promette una portata molto alta che non è mai una qualità da disprezzare.....
    Esteticamente non mi dispiace sinceramente... il top trasparente è una figata....anche se forse l'avrei preferito piu stondato....
    Cmq alla fine contano le performance ....e in questo D-tek non ci delude mai....
    PS: non vedo l'ora di metterlo sotto torchio.....
    L'idea non mi sembra per niente male, certamente per fare prodotti simili ci vuole un centro di stampaggio e costi di setup non indifferenti.
    Ci vuole la prova sul campo!
    exbibyte L'avatar di lore85bg
    Nov 2005
    Gandino (BG)
    costi elevati per lo stampo... e costi bassissimi per la realizzazione...
    L'avatar di fabcam73
    Feb 2006
    VERONA
    bello davvero
    davvero magnifico, a me piace un casino!!!
    è una figata esteticamente è una bomba chissà se con un intervento di mod si può mettere un led dentro ...
    per le prestazioni...... com dice il proverbio l'abito non fa il monaco !
    Get Rich or Die Tryin'
    Zola Predosa (BO)
    cavolo... bello davvero!!!
    crazy... hai ragionissimo.. l'idea del led potrebbe essere carina!!
    My HPE MicroServer:
    Configurazione e Setup
    mebibyte
    Mar 2005
    Secondo voi sarà compatibile con R600?
  1. Dtek Fuzion gfx V1 non pari al nuovo.."NUOVO" + Lunzini Enzotech
    By 88RIO88 in forum -= Vendite : Hardware - Software =-
    Risposte: 16
  2. Cerco WB acs g - Fuzion v2 - Fuzion GFX - Ybris Eclips
    By CrAzY MoDdEr in forum -= Acquisti : Hardware - Software =-
  3. Fuzion GFX
    By Snowfortrick in forum -= Water Cooling =-
    Risposte: 18
  4. DTek Fuzion V2 [NEWS]
    By stoner in forum -= Water Cooling =-
    Risposte: 19
