Foxconn BLOODRAGE "Official Thread"
Pagina 1 di 9 1 2 3 4 5 6 7 8 9 ultimo
Visualizzazione dei risultati da 1 a 10 su 86
    Moderatore L'avatar di Kam
    Sep 2004
    Predefinito Foxconn BLOODRAGE "Official Thread"
    Foxconn BLOODRAGE
    Attesissima nuova nata della casa Taiwanese basata sull'ultimo chipset Intel X58.
    Creata per l'overclock estremo, con una ricchezza in dotazione e features veramente seconda a nessuno.
    Specifiche Tecniche
    Processor: Supports the newest Intel® CoreTM i7 and CoreTM i7 Extreme (Bloomfield) processors, Socket T (LGA1366)
    Chipset: Intel® X58 + ICH10R Chipset
    Front Side Bus: QPI 6.4GT/S
    Memory: Triple DDR3 1800(**oc)/1600/1333x 3 DIMMs, Max.12GB
    VGA on Die: Discreted
    Expansion Slots: 4* PCIe2.0 x16, 1* PCIe2.0 x1, 1* PCI
    IDE: 1* ATA 133
    Serial ATA(SATA)/RAID: 6* SATAII + 2* eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology
    Audio: SONAR X-Fi audio card, Realtek® ALC889, 7.1 channel Audio
    LAN: Dual Gigabit LAN support teaming function by Realtek® 8111C
    IEEE1394: 2*1394a
    Back Panel I/O Ports:
    1 x PS/2 keyboard port
    1 x S/PDIF Coaxial port
    1 x 1394 port
    2 x eSATA ports
    2 x RJ45 LAN ports
    8 x USB 2.0 ports
    Internal I/O Connectors:
    1 x ATX 24-Pin power connector
    1 x 8-Pin ATX 12V power connector
    1 x 4-Pin CPU Fan connector
    1 x 3-Pin System Fan connector
    1 x 3-Pin NB Fan connector
    2 x 3-Pin Fan connectors
    3 x Onboard On/Off/CCMOS/Force Reset buttons
    1 x IDE connector
    2 x USB 2.0 connectors support additional 4 ports
    1 x HDA header
    1 x Front Panel header
    6 x SATAII connectors
    1 x 1394 header
    1 x SONAR X-Fi Card
    BIOS Features: Dual 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
    Support CD: Drivers, Adobe Reader, Norton
    Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
    Special Features: ** Achieved by overclocking
    * Quantum Force segment, based on Intel® X58 chipset
    * Supports the newest Intel® CoreTM i7 and CoreTM i7 Extreme (Bloomfield) processors, Socket T (LGA1366)
    * 4* PCIe x16 Gen 2.0 with ATI CrossFireX™ & NVIDIA® SLI™ support
    * Triple DDR3 1800(**oc)/1600/1333x 3 DIMMs, Max.12GB
    * 4in1 Quantum Cooler
    * 14 phase Digital PWM
    * Quantum BIOS
    * SONAR X-Fi audio card–7.1 channel HDA daughter card with 108dB DAC SNR/104dB
    * Quantum Flow and Quantum Lap unique accessories
    * 100% SOLID Capacitor design and Ferrite Choke
    Form Factor: ATX (12" x 9.6")
    Downloads:
    Manuale
    Manuale in Inglese versione 1.1
    Bios
    Versione 8A1F1P04
    Versione 8A1F1P06
    Versione 8A1F1P07
    Versione 8A1F1P08
    Versione 8A1F1P09 NEW
    Drivers
    Link alla pagina dei drivers sul sito del produttore
    Utility
    FOX Live Update
    PLL da Utilizzare con SetFSB
    PCI-E & BClk hardware mod
    Ultima modifica di pippo369 : 28-08-2009 a 23:32
    Sep 2004
    FOTO
    Ultima modifica di Kam : 17-03-2009 a 21:30
    Sep 2004
    BIOS
    Aggiungo il BIOS template per confrontare eventuali settaggi:
    Bios Ver: Quantum BIOS (XXX)
    CPU Features
    PPM :
    EIST :
    CxE :
    Execute Disable Bit :
    Virtualization :
    Hyper Threading :
    Active Processor Cores :
    Memory Settings
    Memory Controller Settings
    IMC Configuration :
    Channel Congifuration :
    Channel Interleaving :
    Rank Interleaving :
    Memory Timings
    Extreme Memory Profile XMP :
    Memory Profile Select :
    DRAM Timing Control :
    tCL (CAS Latency) :
    tRCG (RAS to CAS Delay) :
    tRP (RAS Precharge) :
    tRAS (Precharge Delay) :
    CR (Command Rate) :
    tRFC (Refresh Cycle Time) :
    tWR (Write Recovery Time) :
    tWTR (Write to Read Delay) :
    tRRD (RAS to RAS Delay) :
    tRTP (Read to Precharge) :
    All Voltage Settings
    CPU Voltages
    CPU Core Voltage :
    CPU Target Core Voltage :
    CPU Vdroop Compensation :
    CPU VTT (UnCore) Voltage :
    1.8 PPL Voltage Setting :
    CPU Clock Amplitude Ctrl :
    Memory Voltages
    DRAM Voltage :
    DIMM1 Vref CA (Addresses) :
    DIMM1 Vref DQ (Data) :
    DIMM2 Vref CA (Addresses) :
    DIMM2 Vref DQ (Data) :
    DIMM3 Vref CA (Addresses) :
    DIMM3 Vref DQ (Data) :
    Chipset Voltages
    X58 IOH Core Voltage :
    X58 IOH VCCA 1.1V :
    X58 IOH VCCA 1.5V :
    ICH10 SB Voltage :
    OC Gear : Skipping this part
    CPU Turbo :
    System Turbo :
    Clock Speed Control Center
    CPU Bclock (FSB) :
    QPI Link Fast Mode :
    QPI Multiplier :
    QPI Target Speed :
    CPU Core Multiplier :
    CPU Core Target Speed :
    CPU Uncore Multiplier :
    CPU Uncore Target Speed :
    Memory Bus Multiplier :
    Memory Bus Target Speed :
    CPU Clock Skew :
    IOH Clock Skew :
    Ultima modifica di Kam : 11-04-2009 a 11:50
    Sep 2004
    OVERCLOCK
    Vantage
    Spi
    Ultima modifica di Kam : 17-03-2009 a 22:17
    Sep 2004
    Setup
    Ultima modifica di Kam : 17-03-2009 a 22:38
    . L'avatar di Hiwa
    May 2007
    ci voleva un thread
    se boss mi regala una
    sbav aspetto qualche test ......
    Get Rich or Die Tryin'
    Boni!!
    Slurp!!
    Sep 2007
    si si si... parecchio interessato a questo 3d
    My Flickr
  1. Asus Rampage Extreme "Official Thread"
    By giampa in forum -= MotherBoards =-
    Risposte: 853
