Lian Li ha presentato quattro soluzioni per hard disk in rack mount.
Costruiti interamente in alluminio sono dotati di uno sportello anteriore, hot swap e un pcb posteriore con un controller RAID della Silicon Image (Sil5744 chipset) con connessione SATA.
Il collegamento esterno avviene via USB 2.0 (480Mb/s) ed e-SATA.
In base al modello ci sono diverse soluzioni RAID:
EX-20: RAID Mode
BIG / JBOD / RAID-0(FAST) / RAID-1(SAFE, SAFE 33, SAFE 50)EX-30 and EX-50: RAID Mode
BIG / JBOD+ (DISK 2 & DISK3)RAID-0(FAST) / JBOD+ (DISK 2 & DISK3)RAID-1(SAFE)
Model: EX-10
1 x 3.5 SATA hot swapable HDD
Plug ang Play
1 x 60mm ball bearing fan with washable filter (1500RPM)
HDD mounting with Lian Li patented anti-vibration kit
Interface: USB2.0 x 1, E-SATA x 1,Dim: 175 x50 x 215 mm ( W,H,D )
Model: EX-20
HDD Type: 3.5 SATA
HDD Amount:2
Interface: USB 2.0 (480Mb/s), e-SATA (3 Gbps, auto-negotiates to 1.5 Gbps)
Raid Controller: Silicon Image SiI5744
Raid Mode: BIG / JBOD / RAID-0(FAST) / RAID-1(SAFE , SAFE 33 , SAFE 50)
Features: Hot Plug / hot swap
Plug and play functionality
Automatic disk rebuild (when one or more RAID 1(SAFE) volumes are configured)
Independent 8KB FIFO/ Port
No driver, BIOS or software required
No drive reformatting on RAID change
LED states for each HDD
Model: EX-30
HDD Type: 3.5 SATA
HDD Amount: 3
Raid Mode: BIG / JBOD+ (DISK 2 & DISK3)RAID-0(FAST) / JBOD+ (DISK 2 & DISK3)RAID-1(SAFE)
Model: EX-50
HDD Type: 3.5 SATA
HDD Amount: 5
Interface: e-SATA (3 Gbps, auto-negotiates to 1.5 Gbps)
Raid Controller: Silicon Image SiI3726 One-to-five native SATA Port Multiplier
Raid Mode: RAID 0, 1, 5, 10 (Running RAID functions With Silicon Image SIL3531 PCI Express to 2-Port Serial ATA II Host Controller card, included, for PC only)
140mm cooling fan, 3-speed fan controller : 1200-1000-800RPM
