Asus Rampage Extreme, nata per stupire - [RECENSIONI]
    Predefinito Aspira a diventare la regina delle mainboard X48 l'ultima nata in casa Asus
    Equipaggiata con il chipset Intel X48 che ha introdotto il supporto ufficiale al bus Quad Pumped a 1600 Mhz ed alle DDR3 alla medesima frequenza, questa mainboard fa parte della famiglia R.O.G. di Asus, una linea di mainboard studiata per venire incontro alle esigenze dei gamers più smaliziati.
    Di seguito le caratteristiche tecniche della mainboard:
    CPU
    Intel Socket 775 for Intel® Core™2 Extreme/Core™2 Quad/ Core™2 Duo/Pentium® dual-core/Celeron® dual-core /Celeron® Processors
    Support Intel® next generation 45nm Multi-Core CPU
    Compatible with Intel® 06/05B/05A processors
    * Refer to www.asus.com for Intel CPU support list
    Chipset
    Intel X48 / ICH9R
    Intel Fast Memory Access Technology
    Front Side Bus
    1600/1333/1066/800 MHz
    Memory
    4 x DIMM, Max. 8 GB, DDR3 2000(O.C.)/1800(O.C.)/1600/1333/1066/800 ECC,Non-ECC,Un-buffered Memory
    Dual Channel memory architecture
    *Overclock speed
    - Supports Intel® Extreme Memory Profile (XMP)
    - For the X.M.P. support, CPUs with FSB 1333 or above are recommended.
    - When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
    - Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lidts).
    Expansion Slots
    2 x PCIe 2.0 x16 , support at full x16, x16 speed
    3 x PCIe x1 ( the PCIEx1_1 (black) is compatible with audio slot)
    2 x PCI 2.2
    CrossFire
    Support ATI CrossFire™X Technology graphics cards
    Storage
    Southbridge
    6 xSATA 3 Gb/s ports
    Intel Matrix Storage Technology Support RAID 0,1,5,10
    Marvell® 88SE6121 controller:
    1 x UltraDMA 133/100/66/33 for up to 2 PATA devices
    1 x External SATA 3.0 Gb/s port (SATA On-the-Go)
    Silicon Image Sil5723 controller:
    2 x SATA 3.0 Gb/s port
    Supports RAID 0, 1
    LAN
    Dual Gigabit LAN controllers, both featuring AI NET2
    Support Teaming Technology
    Audio
    SupremeFX X-Fi Audio Card
    - ADI® AD2000B 8-channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports 1 x S/PDIF out header
    - Supports Coaxial/Optical S/PDIF out ports on rear
    IEEE 1394
    2 x 1394a ports (1 port at back I/O, 1 port onboard)
    USB
    12 USB 2.0 ports (6 ports at mid-board, 6 ports at back panel)
    Overclocking Features
    Fusion Block System with optional thermal kit on MOS and NB
    Extreme Tweaker
    TweakIt
    Extreme Engine
    - 16-phase CPU power design
    - 3-phase NB power design
    - 2-phase DDR3 power design
    - ML Caps on CPU, memory and NB respectively
    Speeding HDD
    iROG
    BIOS Flashback
    Loadline Calibration
    Intelligent overclocking tools:
    - CPU Level Up
    - Memory Level Up
    - AI Gear 3 + ™
    - ASUS AI Booster Utility
    - O.C Profile
    Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
    Special Features
    External LCD Poster
    Onboard Switches: TweakIt / Power / Reset / Cls CMOS (at rear)
    EL I/O
    Q-Fan Plus
    ASUS EPU-6 Engine
    ASUS Q-Connector
    ASUS Fan Xpert
    ASUS EZ Flash 2
    ASUS CrashFree BIOS 3
    ASUS MyLogo3
    Back Panel I/O Ports
    1 x PS/2 Keyboard port(purple)
    1 x External SATA port
    2 x LAN (RJ45) port
    6 x USB 2.0/1.1 ports
    1 x IEEE1394a port
    1 x Clr CMOS switch
    Internal I/O Connectors
    3 x USB 2.0 connectors supports additional 6 USB 2.0 ports
    1 x Floppy disk drive connector
    1 x IDE connector for two devices
    6 x SATA connectors (Blue)
    2 x Speeding HDD SATA connectors (Black)
    8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
    3 x thermal sensor connectors
    1 x IEEE1394a connector
    1 x LCD Poster connector
    1 x EL I/O Shield connector
    1 x Chassis Intrusion connector
    24-pin ATX Power connector
    8-pin ATX 12V Power connector
    1 x En/Dis-able Clr CMOS slide switch
    System panel connector
    BIOS
    16 Mb Flash ROM
    DMI 2.0
    AMI BIOS
    PnP
    WfM 2.0
    SM BIOS 2.4
    ACPI 2.0a
    Multi-language BIOS
    Manageability
    WOL by PME,WOR by PME,Chasis Intrusion,PXE
    Accessories
    Fusion Block System Accessory
    Optional Thermal Kit for NB and MOS
    DIY Pedestal
    ASUS Optional Fan
    External LCD Poster
    3 in 1 ASUS Q-Connector Kit
    UltraDMA 133/100/66 cable
    Floppy disk drive cable
    SATA cables
    SATA power cables
    2-port USB2.0 + IEEE 1394a module
    EL I/O Shield
    Thermal sensor cables
    Cable Ties
    User's manual
    Support Disc
    Drivers and applications
    ASUS PC Probe II
    ASUS Update
    ASUS AI Suite
    Sound Blaster X-Fi Utility
    Futuremark® 3DMark® 06 Advanced Edition
    Kaspersky® Anti-Virus
    Form Factor
    ATX Form Factor
    12 inch x 9.6 inch ( 30.5 cm x24.5 cm )
    Bella recensione
    La scheda è molto curata nei dettagli.
    Jan 2006
    Bergamo
    Una delle schede più belle e complete sul mercato, prezzo non alla portata di tutti ma adatta per chi vuole il top con i dual!
    Bella recensione e bella scheda!
    Concordo sul fatto che il prezzo non è alla portata di tutti.
    Ultima modifica di v_parrello : 07-09-2008 a 12:31
    ancora qualche problemino di gioventù con i QUAD (si spera risolvibile con i prossimi bios) ma nel complesso è una ottima mobo ...
    recensione semplice e completa ...
    Bannato L'avatar di GioS
    Sep 2007
    Matrix
    Datemi una mano a capire cosa gli prende a sta mobo!
    http://www.nexthardware.com/forum/sh...107#post665107
  1. Cerco LCD POSTER Asus Rampage Gene 2 o Rampage Extreme 2
    By giukey in forum -= Acquisti : Hardware - Software =-
  2. Vendo Asus Rampage II extreme e core I7 965 Extreme Box tutto Fatturato Italia
    By Naka in forum -= Vendite : Hardware - Software =-
  3. Asus Rampage II Extreme - [RECENSIONI]
    By Chicco85 in forum -= MotherBoards =-
    Risposte: 14
  4. Asus Rampage Extreme [MI+SS]
    By gandalfone in forum -= Vendite : Hardware - Software =-
