Armari eXtreme Concept Prototype project
    Mar 2006
    Predefinito Armari eXtreme Concept Prototype project
    premesso che non sono stato molto dietro l'articolo (sono lontano da casa e da un'internet point non è la cosa più comoda da fare)
    comunque Hexus ha rilevato alcune inidscrezioni su questo progetto del produttore inglese Armari.
    Mi pare si tratti di un sistema LN2 integrato... lascio a voi aproffondire l'argomento ... e in caso spostare la discussione nella sezione adatta.
    Fonte Hexus
    Author: Tarinder Sandhu
    Primo articolo sul progetto
    First mooted as a concept PC around two years ago, Armari wanted the super-PC to be a fully-functioning model that would make it, ideally, into a low-volume production run.
    Effective and efficient cooling of the components was key, clearly, and the design concept, shown below, was how the company envisaged the system to look. A fusion of two styles, evidently.
    Supercomputer-cum-concept car, huh? The idea was to shoehorn a high-end system into the wholly custom chassis - where over 100 parts have been in-house-designed - and cool it via a variety of means, including LN2, liquid fluorocarbon immersion, TEC, and phase-change, depending upon model.
    The picture, below, shows the concept mock-up of the system - different to pretty much any other high-end system out there.
    Armari then spent six months working with The Product Works - a professional product-design consultancy - to get a complete SolidWorks CAD model, ensuring that the grounds-up cooling and component logisitics would work correctly.
    Want to see just how complex top-of-the-line, custom cooling can be, and just why responsible firms spend mucho dinero on computer-based modelling before wielding the hacksaw and torch?
    Above is a picture of the computer-aided design - one that 's closer to the final-specification model.
    Note the busy, industrial-looking nature of the cooling apparatus at the bottom? It's all there for a purpose, naturally.
    A further six months were spent on manufacturing a working prototype. The system was initially slated to use Intel's maligned V8 platform, but was later changed to the current Skulltrail - incorporating two quad-core CPUs natively running at 3.2GHz on a motherboard that supported four graphics cards - when the design became available.
    A little-known fact is that Armari's technical director, Dan Goldsmith, being the eccentric chap he is, bought a decommissioned Cray supercomputer - used in the Cold War - a while back. Cray's extra-large computers (by today's standards) required some serious cooling, as you would expect, and Cray engineered some class-leading liquid cooling to keep the voluminous beast operating within tolerances.
    Dan has used the inspiration from Cray's research, and indeed the coolant itself, which works in a temperature-range of -110C through to 90C, as a base for the XCP (eXtreme Concept Prototype) - the total immersion model.
    Armari's project means that almost everything is custom-designed for the purpose, including blocks, monitoring PCBs, piping, wiring and, of course, chassis. In fact, there's nothing much which isn't grounds-up, which is cool, if you'll excuse the pun.
    The LN2-equipped model will feature greater internal complexity as Armari seeks granular control over the exact temperatures of the CPUs.
    The XCP has been architected as a no-holds-barred performance PC that's also suitable for running on a 24/7 basis. Internal layout is such that performance is the most important criterion, with, currently, servicing and layout playing subservient roles.
    Strictly an engineering-sample machine at the moment, Armari reckons that there's a market for a limited number of systems to be sold in retail form, once qualification is complete. A liquid-cooled model, with appropriately extravagant hardware, will cost in the region of £10,000, we're told.
    We've given you a sneak peek in to an ongoing project that aims to revolutionise bespoke, high-end PCs.
    We will next look at exactly how the cooling works and when we'll see the finished model.
    Right now, it's almost impossible to say whether this is one man's failed foible or if there's significant merit in the design.
    Secondo articolo del 20 marzo sempre da Hexus.net
    Late last week, HEXUS exclusively revealed that Armari - a system integrator that focuses on high-end enthusiast and the server/HPC spaces - had been working on a top-secret, supercomputer-in-a-box project for two years. We recommend you have a read of our first-look article to familiarise yourselves with the XCP concept, background and all, found here
    The Armari XCP (eXtreme Concept Prototype) will be first released with total immersion (liquid fluorocarbon) cooling surrounding a heavily-overclocked Intel Skulltrail platform.
    Now, we've been able to coax a few more details regarding the on-going project that will see even more esoteric cooling, such as LN2, being implemented on upcoming XCP models.
    The total immersion model needs perform well, of course, but also has to be easy to service, should the need arise. For example, you might want to upgrade the CPUs or change the graphics cards at some point in the future.
    Once put in service mode, the XCP's main tank, holding the special coolant, can be auto-emptied into the side reservoir tanks, shown above, in just two minutes.
    The side tanks are larger than the main, eliminating the possibility of the coolant flowing back into the main hold when you're busy changing components.
    Once the component-upgrade process is complete, the XCP's side tanks can be emptied back into the main hold by putting the machine in normal mode.
    LINKad un video del sistema
    [SIGPIC][/SIGPIC]
    Mar 2006
    da gizmondo.com
    Armari's eXtreme Concept Prototype (XCP) super computer is made of some 100 uniquely designed parts, is either cooled by liquid nitrogen, liquid flurocarbon immersion or thermoelectric cooling and phase change, depending on the model's configuration and has the ability to run 24/7 without needing to shutdown. The XCP will happily function through a temperature range of -110°C to 90°C and being built on Intel's Skulltrail platform, the XCP happily packs quite some power under its Lost in Space-esque hood.
    Currently, the XCP is at concept stage, but the final production model is expected to house two quad-core CPUs (3.2GHz) on a motherboard that supports four graphics cards. Nice. We understand that the uber geeks among us are probably sweating profusely in eager anticipation of the XCP. Well, you can stop now, as an expected price tag of $20,000 says this will remain a thing of geek utopia.
    [SIGPIC][/SIGPIC]
    Da quello che ho capito è praticamente è un sistema a immersione in liquido dielettrico, come si usa in alcuni supercomputer. Il liquido può essere refrigerato con un sistema termoelettrico (peltier), a compressore o a LN2 a seconda della configurazione che si acquista.
    Basato su piattaforma skullrail, il costo totale del sistema dovrebbe aggirarsi sui 20.000$.
    Decisamente assurdo.
    Mi piace!!
    Zola Predosa (BO)
    Esattamente come dice frakkino... ma un pc del genere è davvero inumano. Non penso che molta gente comune sia disposta ad acquistare un sistema del genere...
    Certo uno come Brugola.x ci navigherebbe su internet con un gingillino così...
    Mi piace!!
    Se serve il diavoletto tentatore fammi uno squillo...
    My HPE MicroServer:
    Configurazione e Setup
    Ma che diavoletto tentatore... Hai letto il prezzo?? 20.000$...
    Neppure la foto mi posso comprare!!
    byte L'avatar di Lucariello
    Jan 2008
    Mi piace!!
    Francamente, mi sembra una gran boiata!!!
    A quel prezzo sono pochissime le persone che possono farci un pensierino...
    Sicuramente non è un giocattolo destinato alla grande distribuzione, dubito che lo vedremo mai nei Carrefour.
    E' anche un sistema che non comprerei mai, potendo scegliere. Ma se avessi veramente tanti soldi da buttare mi piacerebbe metterci le mani sopra. Non tanto per l'hw ma per la particolarità del giocattolino.
  1. Flip Phone, un nuovo concept di palmare - [NEWS]
    By ziotidus in forum -= PocketPC e Smartphone =-
  2. Mozilla Labs presente il Concept di palmare Seabird - [NEWS]
  3. Windows Phone 7 Concept by XDA - [NEWS]
  4. Shanghai World Expo 2010, Canon Wonder Camera Concept - [BLOG]
    By MAN in forum -= Fotografia Digitale =-
  5. D-Uranium Turret Prototype 1.0
    By ^SiRtA^ in forum -= Water Cooling =-
    Risposte: 64
