Aggiornamento RAM
Hybrid View
    Predefinito Aggiornamento RAM
    Buongiorno, ho un vecchio PC portatile ADVENT 7208 con solo 3 GB di RAM.
    Vorrei aumentare la RAM al massimo, pertanto chiedo un vostro consiglio su quanta RAM posso aggiungere (o sostituire se i banchi sono tutti occupati) e
    quali dati servono per l`acquisto.
    Grazie mille !
    I dati dell`hardware sono :
    CPU
    /0/4
    product: Intel(R) Core(TM)2 Duo CPU T7100 @ 1.80GHz
    vendor: Intel Corp.
    bus info: cpu@0
    version: CPU Version
    slot: U2E1
    capacity: 4096MHz
    width: 64 bits
    capabilities:
    mathematical co-processor,
    FPU exceptions reporting,
    wp,
    virtual mode extensions,
    debugging extensions,
    page size extensions,
    time stamp counter,
    model-specific registers,
    4GB+ memory addressing (Physical Address Extension),
    machine check exceptions,
    compare and exchange 8-byte,
    on-chip advanced programmable interrupt controller (APIC),
    fast system calls,
    memory type range registers,
    page global enable,
    machine check architecture,
    conditional move instruction,
    page attribute table,
    36-bit page size extensions,
    clflush,
    debug trace and EMON store MSRs,
    thermal control (ACPI),
    multimedia extensions (MMX),
    fast floating point save/restore,
    streaming SIMD extensions (SSE),
    streaming SIMD extensions (SSE2),
    HyperThreading,
    thermal interrupt and status,
    pending break event,
    fast system calls,
    no-execute bit (NX),
    64bits extensions (x86-64),
    constant_tsc,
    arch_perfmon,
    pebs,
    bts,
    rep_good,
    nopl,
    cpuid,
    aperfmperf,
    pni,
    dtes64,
    monitor,
    ds_cpl,
    vmx,
    est,
    tm2,
    ssse3,
    cx16,
    xtpr,
    pdcm,
    lahf_lm,
    pti,
    tpr_shadow,
    vnmi,
    flexpriority,
    dtherm,
    ida,
    CPU Frequency scaling
    SODIMM DDR2 Synchronous 533 MHz (1,9 ns)
    /0/12/0
    product: SODIMM000
    vendor: Mfg 0
    serial: 1234-B0
    slot: M1
    size: 2GiB + 1 GiB
    width: 64 bits
    clock: 533MHz (1ns)
    Apri lo sportellino in basso a destra previa rimozione della vite di blocco e accedi al comparto memorie per vedere se hai slot liberi.
    Qui trovi una guida:
    http://www.uktsupport.co.uk/advent/laptop/7208.htm
    nibble
    Sep 2017
    Originariamente inviato da cperciba
    max 4GB
