And Multi links ( BP-MBEML)
Once connected it looks like this
To be continued!!!
To be continued!!!
OMG! very very good! compliments
Thank you so much for the comments... love it!!!
For this another update my friends
Another Update!!!
It's holiday time so did a lot of work on the Banchetto mod, and took lots of photos. Therefore, another updated for you guys![]()
After some puzzling and excessive use of adapters... pretty happy regarding the completion of the loops.
The adapters that I have used includes:
2x Multi-F Block (BP-MBMTFMB)
The mini valves (BP-MVV-MBK)
Small adapters to create the right heights to connect everything
The adapters are:
Extenders BP-MBWP-C40, BP-MBWP-C60, BP-MBWP-C62 and some Mini Dual G1/4" Extenders
In order to get some more green details, ordered a green plate UV green
Next step was to create a back plate, so cut to the right size and made some openings
The square holes on the right side are for the extension and the on/ off button from the PSU
Removed the tape
Also cut the plate for the upper section.
And placed it
Meanwhile, added some more small details... bought some nice UV green bars which I found in the shop where I've got the UV green plate from. Bend with a heat gun
Mounted this with acrifix glue
Think it's to much green now so I will add more black accents. More on this later.
Thanks to Highflow I've got the perfect UV green liquid
For this build, the choice is Mayhems X1 UV Green
Here's a little preview of the filling vid... full movie coming your way this summer
I have no words ...
really fantastic
How many VGA do you mind to assemble ?
two or ?
"Scusate, ma se quest'anno in Texas ci avete spedito questo deficiente, vuol dire che c'č speranza per tutti?"
Thanks, yes, there will be two... think two Titan Blacks should be enough
Very very impressive!!!i like these clean job
Thank you very much
Cover-up Update!!!
Another updateonly this time I'm going to hide some things ...
The reason is too much green. It is much better to add more black now the liquid is in.
Also I don't like the frosted green parts anymore. That's why I replaced the side strips with clear UV green ... and cutout some shapes.
To hide some green, I have sawn a new plate 1cm smaller than the original
And copied everything that was in the original
Removed the tape
First pasted white and then black vinyl. White is for better light distribution so the edges will glow nicely.
Kept a small distance between the panels.
Result:
Same story with the top plate
Also did some things to the front to get more black accents But first sawn a cover UV green.
Which will be placed like this.
Made the shape of the black plate like this after some puzzling.
