Progetto CM 690 II adv. Silent in Ottica Risparmio Energetico
    hw hupgrade esule
    Feb 2010
    Predefinito Progetto CM 690 II adv. Silent in Ottica Risparmio Energetico
    09/05/2011
    Last New:
    ECCO LA CONFIGURAZIONE DEFINITVA
    • CPU: Intel Xeon L3110 (3Ghz, 45 Watt TDP)
    • MOBO: Msi p45 Diamond
    • RAM: Kingston LoVo ddr3 4 giga kit 1,25 vram
    • PSU : Scythe Stronger 600W plug-in modulare
    • GPU: MSI-Ati Radeon R5450-MD1GH (dissi passivo)
    • APU Standard: MSI-Creative SB X-Fi Xtreme H/W PCI-ex Sound Card (MS-4132 in bundle con la MSI)
    • APU Pro: ESI ESP1010e PCI-ex Sound Card Pro (new)
    • Hdd1: WD Velociraptor WD740HLFS 74Gb - 10000rpm - 16mb
    • Hdd2: WD Velociraptor WD1500HLFS 150Gb -10000rpm - 16mb
    • Hdd3: WD Caviar Green WD10EARS 1Tb - IntelliPower - 64mb
    • Dvd Reader: Samsung SH-D163B black sata
    • Dvd Record: Samsung SH-S223C black sata
    • Floppy disk: Scythe Card Reader Combo Floppy
    • Monitor: HANNS-G HL231DP 23" LCD LED Wide 1920x1080 0,26Dp 5ms Full HD Nero (new)
    • Speakers:
      • Creative Inspire 5.1 T6060 (new)
      • Creative i-trigue 2200
      • Creative i-trigue 2300
    • Audio Rack
      • ESI ESP1010e Remote 19" Sound Card Unit
      • Numark RM6 19" Line Mixer Unit
      • Alto HPA4 19" Headphones Splitter/Amplifier Unit
    • Case: Cooler Master 690 II Advanced + finestra laterale in plexiglass
    • Dissipatore: Noctua NH-U9B SE2
    • Rheobus:
      • Cooler Master Wind Rider PWM hub
      • Nanoxia PwmX Controller (per una o entrambe le ventole Noctua NH-U9B SE2 del dissipatore)
      • Sunbeam Theta pci controller (per monitorare i giri delle ventole collegate al Wind Rider)
    • Ventole:
      • Enermax Cluster UCCL12 PWM - 120mm (frontale)
      • Noiseblocker Multiframe M12-P PWM - 120mm (sotto)
      • Akasa Apache 120mm PWM Fan - camou (top I)
      • Arctic Cooling Arctic F12 Pro PWM - 120mm (top II)
      • Scythe Kama DFS122512L-PWM 120mm (back)
      • Silverstone Nitrogon NT07 AM2 PWM 80x80x15 (lato dx dietro mobo)
      • Arctic Cooling Arctic F12 PWM - 120mm (lato sx pannello I) Moddata Trasparente (new)
      • Scythe Slip Stream PWM - 120mm (lato sx pannello II) (sacrificata con la paratia in plexiglass che ne può ospitare solo una)
      • Coolink SWiF2-120P Retail 120mm - PWM (centro-interno case)
      • SilenX Fan Ixtrema Pro IXP-74-14T Thermistor - Tachi 120mm (autoregolata indipendente, sugli Hdd)
      • Silverstone Suscool 81 80mm Thermal control (autoregolata indipendente, sul NorthBridge)
    • Accessori principali:
      • Scythe Kama stay (per la Coolink interna)
      • Sunbeam Wherever Pci Rack staffa laterale
      • Akasa fan adapter 60>80 (per la silverstone termoregolata sul NB)
      • Demciflex filtri magnetici
      • Disaccoppiatore in silicone per la PSU
      • Viti in silicone su tutte le ventole
      • Revoltec double withe neon 10cm
      • Revoltec single withe neon 30cm
      • NZXT Prolunga ATX / EPS 25cm - premium sleeved black
      • prolunghe tachimetriche e pwm a profusione
    Ultima modifica di maxmax80 : 16-05-2011 a 23:41
    Msi p45Diamond | Intel XeonL3110 | Kingston LoVo ddr3 |CoolerMaster 690II | Noctua NH-U9BSE2 | CM Wind Rider PWM fan hub+Nanoxia PwmX | Scythe Stronger 600W plugin | MSI-Ati Radeon R5450-MD1GH | MSI-Creative SBX-FiXtremePCI-ex | Focusrite Saffire Firewire SoundCard Pro | Velociraptor 74Gb & 160Gb - CaviarGreen 500Gb | PWM Fans:Enermax Cluster,Noiseblocker,Akasa,Arctic Cooling Arctic,Scythe,Silverstone,Coolink,SilenX Fan Ixtrema | Dvd Read Samsung SH-D163B & Rec SH-S223C | Scythe Combo Floppy |
    hw hupgrade esule
    Feb 2010
    Ecco i protagonisti principali:
    si notano:
    la splendida P45 Diamond con la Creative extreme Audio Pci-ex in bundle, il tris low power Xeon L3110+hyperx lo.vo+Msi hd5450
    qui invece si notano:
    CM Wind rider fan hub, Nanoxia pwmx (per le due noctua del dissipatore), il sunbam theta per la monitoria di temperature & velocità delle ventole (controllate dal Wind rider), le 9 ventole pwm+le 2 termocontrollate
    riguardo alla scelta dell' hardware -per registrare & mixare musica- 1 anno e mezzo fa mi ero orientato al vecchio caro socket 775.
    ( col senno di poi sarebbe stato da aspettare adesso per passare direttamente al P67, ma magari per questo se ne riparlerà l' anno prossimo con uno dei prossimi Xeon E3-1240 socket 1155..)
    visto che alla base del progetto c'era -oltre all' idea di fare qualcosa di diverso dal solito- la ricerca del risparmio energetico e della silenziosità, dopo una ricerca estenuante, ho deciso per la MSI P45 Diamond per 4 motivi:
    - Esteticamente stupenda
    - Scheda Audio Creative pci-ex in bundle (ideale per l' ascolto normale con 5.1...quando lavoro sulla musica uso la Esi che è una scheda prosumer..)
    - Può scendere con il Vram fino a 1.25 volt per pilotare le ddr3 Low voltage
    - Ottimizzazione del discorso ventole/risparmio energetico fantastico con il GreenPowerGenie & il DualCoreCenter
    Insieme alla Radeon HD5450 (la scheda che fino all' avvento della HD6450 era la più low power di tutte quelle di nuova generazione),
    per il risparmio energetico lo Xeon L3110 con i suoi 45 watt TDP
    & le Kingston lo.vo 1.26v Vram erano i componenti che facevano al caso mio
    detto questo, dopo aver infestato di richieste di pareri, i forum di mezzo mondo, circa la compatibilità (MSI, Intel & soprattutto Kingston ovviamente non me l' hanno garantita), ho incrociato le dita e....è andato tutto bene, per fortuna!
    lo Xeon L3110 fra l'altro sono andato fino in piemonte a prenderlo perchè di tutti i rivenditori ufficiali Intel del nord-italia, solo un super-rivenditore di Alessandia è riuscito a ordinarmelo
    (senza scuse campate in aria come gli altri...mi chiedo io, se sei sul sito ufficiale Intel e ti ordino un processore che è ancora in produzione, perchè non riesci ad averlo? è raro? ok, io pago e lo voglio!!!..giusto?..)
    Ultima modifica di maxmax80 : 17-05-2011 a 00:55
    hw hupgrade esule
    Feb 2010
    riservato 2
    hw hupgrade esule
    Feb 2010
    riservato 3
    hw hupgrade esule
    Feb 2010
    riservato 4
    hw hupgrade esule
    Feb 2010
    riservato 5
    hw hupgrade esule
    Feb 2010
    riservato 6
    hw hupgrade esule
    Feb 2010
    riservato 7
    Jan 2006
    Bergamo
    mmmm, due velociraptor e due dvdrecorder? Ma non era meglio un SSD è un solo lettore dvd?
    hw hupgrade esule
    Feb 2010
    per il singolo dvd no no...sono tradizionalista...
    per l' ssd la prenderò nel 2012 con la tecnologia a 25 o 22nm quando i prezzi crolleranno (e saranno può durature) e magari cambierò anche tutta la configurazione hardware...
    ora come ora (o meglio, allora come allora) dal mio punto di vista, non aveva senso buttare i soldi nelle ssd..
  1. problema col risparmio energetico
    By taxon in forum -= Hardware generico =-
  2. risparmio energetico toshiba
    By quebec in forum -= Sistemi Operativi Windows e software generale =-
  3. controllo risparmio energetico
    By superpacman in forum -= Sistemi Operativi Windows e software generale =-
  4. Alimentazione Risparmio Energetico
  5. Risparmio Energetico
    By Besk in forum -= Hardware generico =-
