questi radiatori non compaiono ancora sul sito hwlabs
queste 2 versiono ospitano ventole da 140 invece che 120
fter the already very successful ICE GT Stealth radiators for 120mm fan shows Black ICE now a new version for 140mm fan. Larger fan, higher throughput and better performance! Perfect for all overclocking projects and Silent PCs.
"The new arrangement of the blades enables optimum cooling in a confined space. By using 45% thinner copper slats one with 50% less pressure - with a double-laminated density. 30 lamellae per inch dramatically increase the surface area and ensure a heat transfer, seeking his peers.
Compared to the Black ICE Pro can heat up to 20% faster closes. The improved heat exchange capacity slowly rotating fan can be used. The cooling performance of the system is preserved, and the noise level can once again significantly reduced.
The processing, and in particular the painting of radiators is first class. M4 thread and the G 1 / 4 "thread connecting holes for easy installation and maximum compatibility. Through the small dimensions, the Radiators also used there, where it is closely times ..."
confronto misure
GT Stealth 420
Dimensions: 460 x 153 x 31.3 mm
GT Stealth 280
Dimensions: 316 x 153 x 31.3 mm
confronto con i "vecchi" Stealth e il GTX 480
GT Stealth 360
Dimension: 397 x 133 x 29.6 mm
GT Stealth 240
Dimension: 277 x 133 x 29.6 mm
GTX480
Dimensions: 517 x 133 x 54mm
