ne ho 4 nuovi, ancora sigillati. Chiedo 15 euro l'uno, oppure se li prendete tutti e 4, faccio 48 euro totali + 8 spedizione con corriere executive.
The Aqua RX Series R1 block can cool either a DDR or an SDRAM memory module. The Aluminum heatsink wicks away the heat via the thermal pad and is cooled by the copper tube with the liquid coolant passing through. The quick connect fittings ease installation and allow the block to be used in either 3/8" ID or 1/4" ID liquid cooling circuits.
- Universal application for all memory modules. The standard size fits on all motherboards.
- An artful Integration of Liquid cooling and air cooler
- Aluminum heatsink dissipates the heat generated from the memory more efficiently.
- Copper tubing transfers the heat to the liquid cooling system immediately.
- User Friendly Quick Install Connector saves you time and energy.
P/N: CL-W0102 Compatibility: DDR Memory
SDRAM MemoryMaterial: Aluminum heatsink
Copper tubeDimensions: 125 mm X 40 mm X 8.2mm
(L x W x D)Quick install connectors: For 6.4mm ID (1/4”) tubing
For 9.5mm ID (3/8”) tubingThermal pads: 124 mm X 22.5 mm X 0.5mm
124 mm X 22.5 mm X 1.0mm
(L x W x D)Weight: 204(g)
