Bitspower presenta una nuova linea di raccordi e adattatori con curva da 45° della serie Rotary, quindi possono ruotare sulla loro base a 360°.
Le finiture sono sempre in nickel silver o black e sono tutti realizzati in ottone alta qualità.
BP-45R2I Silver Rotary 45° 1/2" Fitting
BP-BS45R2I Black Rotary 45° 1/2" Fitting Thread: G1/4"
Tubing Size : 1/2"
BP-45R2II Silver Rotary 45° 3/8" Fitting
BP-BS45R2II Black Rotary 45° 3/8" Fitting Thread : G1/4"
Tubing Size : 3/8"
BP-45R2III Silver Rotary 45° 1/4" Fitting
BP-BS45R2III Black Rotary 45° 1/4" FittingThread: G1/4"
Tubing Size : 1/4"
BP-45R2IV Silver Rotary 45° Compression
BP-BS45R2IV Black Rotary 45° Compression Compression Fitting For ID 8MM OD 10MM Tube Thread: G1/4"
Tubing Size : ID. 8MM OD.10MM
BP-45R2V Silver Rotary 45° Compression
BP-BS45R2V Black Rotary 45° Compression Compression Fitting For ID 8MM OD 11MM Tube Thread: G1/4"
Tubing Size : ID. 8MM OD.11MM
BP-45R2G Silver Rotary 45° G1/4" Adapter
BP-BS45R2G Black Rotary 45°G1/4" Adapter Thread : G1/4"
Thread No. : 2
