Swiftech Apogee™ Drive 350
    Mar 2006
    Predefinito Swiftech Apogee™ Drive 350
    che ne pensate di questo wb con pompa integrata?
    The farthest or highest point; the apex; a final climactic stage
    In the world of water-cooling, the Apogee™ CPU Waterblocks and MCP350 pumps have become legends, proving themselves to be among the best available to the enthusiast and professional users alike.
    Enter the patent pending Apogee™ Drive 350 self-powered series of waterblocks which consolidate both technologies into one convenient package capable of handling today and tomorrow's most extreme processors on the market.
    From a technological standpoint, the Apogee Drive combines the best characteristics of both products:
    * Derived from the MCP350 pump:
    o Small form factor
    o High Reliability
    o High head pressure
    o Quiet operations
    * Derived from the Apogee™ water-block
    o Low thermal impedance
    o Low pressure drop
    From the user standpoint, the Apogee Drive provides the following direct benefits:
    * Extreme simplicity of installation
    * True High Performance characteristics
    * Substantial cost savings
    * Internal structure: the CNC machined C110 copper base plate is at the heart of Apogee™ Drive thermal efficiency. Designed using Computational Fluid Dynamics, the Patent Pending Diamond Pin Matrix is optimized to increase wet surface area, coolant velocity, while minimizing pressure drop.
    Patent Pending Diamond Pin Matrix Copper base plate
    identical to that of the Apogee™ GT
    * The patent pending housings are injection molded for mass production and economies of scale.
    * The Pump housing, internals, and specifications derive from the MCP350 pump:
    o Motor: Electronically commutated, brushless DC, spherical motor.
    o Nominal Voltage: 12 VDC
    o Nominal current: .69A to 1A
    o Nominal Power: 8.3 to 12W
    o Head Pressure: 10.8 ft (3.3 mH20)
    o Flow Rate: 1.45 gpm (330 Lph)
    o MTBF (Mean Time Between Failures) 50,000 Hours.
    * Thermal Design: Diamond Pin Matrix copper base plate.
    * Fittings Style: Built-in 3/8” (10mm) barbs fittings.
    * Weight: 10.1 oz (285 g)
    la base è la solita
    With the 10 ft (over 3m) of head pressure produced by its motor, the Apogee™ Drive is also capable of sustaining high flow rates in complex loops where chipset(s), and single or dual VGA are also liquid cooled.
    Test su VrZone con il kit che include un radiatore con vaschetta integrata
    (In parallel to the Apogee Drive, we have also developed a new line of radiators featuring an integrated reservoir. This allows us to offer a revolutionary high performance liquid cooling kit composed of two components only: the H20-Compact series.)
    [SIGPIC][/SIGPIC]
    Jan 2005
    Sarebbe un apogee Gt fuso con una ddc350....
    Sinceramente sono un po scettico.... la pompa vibra e non credo sia proprio un bene ....
    Il prezzo dovrebbe essere di 99$ sul mercato americano....mettiamo che siano 90€ sul mercato europeo alla fin fine.... non proprio una sciocchezza insomma...
    Per avvicinarsi al watercooling può rivelarsi un buon prodotto... come può essere interessante in sistemi compatti dove lo spazio è poco...
    Ma dato che il costo di una ddc350 abbinata ad un waterblock è di poco superiore imho non conviene a noi "smanettoni"....
    Mar 2006
    magari per un sistema tipo htpc ,dove c'è il rischio che lo spazio sia irrisorio per un sistema a liquido, può essere un'idea.
    senza dover cosi impazzire per trovare un buco o con troppi tubi in giro per il case.
    ovviamente questo per chi punta ad eliminare ventolame vario e non certo per chi cerca prestazioni.
    [SIGPIC][/SIGPIC]
    Jan 2005
    Sicuramente in un Htpc può essere interessante....anche perchè credo che le prestazioni non siano proprio da buttare....
    Alla fine è pur sempre un Apogee abbinato ad una Ddc....
    Certo che Gabe (Mr. Swiftech) ogni tanto dovrebbe pure pensare a quel che dice.... afferma che la versione con radiatore biventola è in grado di tenere a bada un Quad Core B3 overcloccato e due Gtx in Sli ....
    gibibyte
    May 2005
    Mn
    è ottimo a livello di integrazione,però io se spendo dei soldi per delle cose nn voglio essere vincolato ad accoppiare per sempre due oggetti fra loro o a doverli modificare per usarli separatamente
    Mar 2006
    Originariamente inviato da Gioz
    ovvio che se uno ha esigenze diverse non va a prendere un wb con pompa integrata (anche perchè se poi si rompe la pompa credo il wb diventi inutilizzabile con altre pompe esterne), cosi come chi prende i wb per le vga studiati solo per un determinato tipo di scheda.. sono scelte fatte in base a eisgenze diverse.
    a questo punto mi chiedo se potrebbero mettere anche una vaschetta integrata (tipo i top alphacool per la 350) cosi si avrebbe solo un blocco più rad.
    [SIGPIC][/SIGPIC]
    Jan 2006
    Bergamo
    Mar 2006
    si, è il kit con il radiatore/vaschetta
    [SIGPIC][/SIGPIC]
    gibibyte
    May 2005
    Mn
    Originariamente inviato da stoner
    hai ragione,giustamente è questione di esigenze e scelte.
    per la vasca dubito che convenga realizzarla,in alcuni case o in sistemi alle strette rischierebbe di non starci,inoltre poi per riempire l'impianto sarebbe un problema anzichè un vantaggio....a meno che eventualmente nn venga sviluppato qualcosa di diverso rispetto alla alphacool.
    Jan 2005
    Come ti capisco....
    Per integrare tutto nel cubetto ci diventai letteralmente scemo.... con la vaschetta Alphacool si fa una fatica immensa a spurgare l'impianto....
  1. Swiftech Apogee XT (Rev2) - [NEWS]
    By stoner in forum -= Water Cooling =-
  2. Swiftech Apogee™ XT - [NEWS]
  3. Swiftech Apogee GTZ - [NEWS]
    Risposte: 11
  4. Wb Waterblock Swiftech Apogee [va+co]
    By TROJ@N in forum -= Vendite : Hardware - Software =-
    Risposte: 14
  5. Swiftech Apogee GTX
    By vkbms in forum -= Water Cooling =-
