Best gaming monitor under $500?
    Dec 2017
    Predefinito Best gaming monitor under $500?
    I have a free upgrade from work to buy any monitor I want but it must be under $500 and I have no idea what to buy. I have a 1080ti gfx card as well so I can run pretty much any framerate or resolution.
    Thanks brahs
    Aggiornato: ho scelto Samsung CF591. il prezzo è sotto i 300 euro, questo articolo (https://pcora.org/miglior-monitor-pc-gaming/) lo consiglia, spero sia giusto.
    Ultima modifica di franker : 28-01-2018 a 03:57
    nibble L'avatar di DarX098
    May 2016
    Hi Franker, i hope you can buy a G-Sync Monitor then with 1080ti it's powerfull!
    My advice is to buy an Asus PG278QR, it's cheap becose is a TN Panel just for gaming. If the cost is so high, you can find a good used on Amazon shop and you will have the same warranty policy!!! Then 3 years of warranty with Asus e 2 years with Amazon.
