"GeForce 3D Vision" occhiali magici da Nvidia
    Predefinito "GeForce 3D Vision" occhiali magici da Nvidia
    cosa ne pensate di questo nuovo prodotto presentato da Nvidia??
    High Tech Design
    Custom engineered active LCD shutter glasses with built-in electronics to support the latest pure 120 Hz LCDs and DLP® HDTVs.
    GeForce 3D Vision Specifications
    Glasses
    Signal
    IR receiver Receive signal up between 1.5 and 15 feet Wireless
    Infrared receiver Receive signal between 1.5 and 15 feet Power
    Battery Life 40 hours of stereoscopic 3D Power button On/off button Rechargeable battery connector USB 2.0 mini-B power connector Indicator Lights
    Battery Level Green and red indicator lights Charging Amber light Dimensions
    Product Dimensions, 20.3’’x 16.6’’x 8.2’’ Weight
    Product Weight 50 grams/1.76 ounces
    IR Emitter
    Wireless
    Infrared transmitter Transmit signal between 1.5 and 15 feet Buttons
    NVIDIA backlit button GeForce 3D Vision on/off Depth Adjustment Thumbwheel on the back of IR emitter Connectors
    USB 2.0 mini-B Connect to the PC for enabling GeForce 3D Vision VESA Stereo Cable Port For use with DLP HDTV only Dimensions
    Product Dimensions 2.5” X 2.5” X 1.5” tall Weight
    Product Weight 47 grams/1.66 ounces
    Minimum system requirements
    • Microsoft® Windows® Vista 32-bit or 64-bit
    • Intel® Core™2 Duo or AMD Athlon™ X2 CPU or higher
    • 1GB of system memory. (2GB is recommended)
    • 100 MB free disk space
    GeForce 3D Vision-Ready displays devices
    • Desktop Displays
      • Samsung® SyncMaster 2233RZ 120 Hz LCD display
      • ViewSonic® FuHzion™ VX2265wm 120 Hz LCD display
      • 100 Hz and higher analog CRTs
    • DLP HDTVs
    • Projectors
    NVIDIA GeForce GPUs
    • GeForce GTX 200 Series
      • GeForce GTX 295
      • GeForce GTX 285
      • GeForce GTX 280
      • GeForce GTX 260
    • GeForce 9 Series
      • GeForce 9800 GX2
      • GeForce 9800 GTX+
      • GeForce 9800 GTX
      • GeForce 9800 GT
      • GeForce 9600 GT
    • GeForce 8 Series
      • GeForce 8800 Ultra
      • GeForce 8800 GTX
      • GeForce 8800 GTS
      • GeForce 8800 GT
    Note: GeForce 3D Vision currently supports 2-way NVIDIA SLI®. A future driver update will support 3-way and Quad SLI.
    non mi dispiacerebe provarli....
    ulteriori informazioni sul prodotto si possono trovare a questo link GeForce 3D Vision Kit
    gibibyte L'avatar di Hyradus
    Aug 2006
    Roma (RM), Cori (LT)
    ma che figaaaaaata!!!!
    “Non dimenticarti che non sei mai a più di mezzo tono dalla nota giusta”
    Nov 1999
    Foggia
    Ci vuole un monitor/tv apposita che attualmente non penso abbia nessuno (almeno come lcd, i crt per me sono ormai passati a miglior vita e cmq non ne ho mai avuti a buone risoluzioni a 120hz...).
    Gli occhiali di questi tipo non sono i primi (e non saranno gli ultimi certo) a cercare di sfondare, in passato è andata sempre male. Non so se oggi cambi qualcosa a dire il vero, molto meglio un tris di monitor per una visione più ampia e "simil-avvolgente".
    Iscritto dal 12-11-1999 o_O
    no Salvatore, Beta li ha provati in una dimostrazione fatta da NVDIA e hai un 3D reale, sono stratosferici ed i monitor da 120 Hz o superiori già ci sono, Mi sembra i TV LCD Sony della linea Z che dovrebbero essere @200 Hz
    Nov 1999
    Foggia
    No cosa?
    I monitor lcd da 120hz so bene che ci sono, ma quanto costano?
    Ad esempio Tv come queste qui:
    The "3D Ready" HDTV List
    Servirà quindi un tv "3d ready".
    Inoltre... per la renderizzazione di entrambi i semiquadri è richiesta una potenza enorme che attualmente chi può gestire a 60fps e, soprattutto, con quali giochi?
    La risposta è attualmente: nessuno.
    In futuro chissà, con 8-12-16 core sulla cpu magari ci saranno compiti precisi per il rendering parallelo delle immagini, ma siamo ancora nelle congetture.
    La tecnologia dello sfalsamento delle 2 immagini (quella che danno l'impressione di avere le immagini che tu chiami 3d reale) esiste e questa sembra essere la naturale evoluzione (in positivo ovviamente).
    Diciamo che tra 2 anni qualche gioco ne potrà usufrire in maniera adeguata, sempre che si voglia spendere un bel pò di soldi, perchè gli shutter glass usati con dispositivi sotto i 100hz fanno venire il mal di testa.
    L'effetto è sì avvolgente, ma è sicuramente ancora troppo presto.
    no al fatto di liquidarli come il solito approccio simil avvolgente; qui l' esperienza 3D sembra reale e avvolgente veramente e l' HW utilizzato è quello in commercio, quindi niente a che vedere con i 3 monitor per un effetto palliativo ...
    inoltre, se fossero compatibili, è da verificare, i Sony Z pur cari sono abbordabili per la fascia alta ...
    Nvidia ha pensato anche al monitor presentando un offerta che include entrambi i prodotti
    il pacchetto prevede un Samsung SyncMaster 2233RZ
    GeForce 3D Vision Bundle
    Nov 1999
    Foggia
    Aggiungo una cosa:
    io ho parlato di TV (i cui costi sono ancora molto alti) perchè i 20-22'' che consentano i 120hz o superiore li vedo un pò riduttivi (piccoli) per un effetto realmente "immersivo" come sembra riescano a dare.
    Nov 1999
    Foggia
    Cmq amico mio, se mi garantisci un effetto davvero CREDIBILE anche su un 22'' mettili a listino che un acquirente lo trovi al 101%
    E' sempre stato un mio sogno dai tempi di quelli di carta che uscivano con "Gente"..
    frena ... bundle o non bundle anche io come te sono scettico all' utilizzo di un 22", NVDIA la dimostrazione l' ha fatta sui 30" di altissima qualità, non a caso anche io ho parlato di Sony TV LCD serie Z 200 Hz perchè alla fine costeranno quanto un monitor 30" come queli usati in presentazione cn la differenza di essere 40/50" ...
    si va comunque oltre i 2000 € ...
    MA LI SPENDEREI VOLENTIERI ...
  1. [MI] Vendo PC CD "Mohaa Dlx." "Commandos 3 Berlin" "Age of Mitho"
    By f3dfx in forum -= Acquisti : Hardware - Software =-
  2. [Milano] Vendo PC CD "Mohaa Dlx." "Commandos 3 Berlin" "Age of Mitho"
  3. 1 delle 2: Asus GeForce 2 Ti "7700Ti "64 Deluxe (garanzia)/Creative GeForce 2 Pro
    By Dave in forum -= Acquisti : Hardware - Software =-
  4. CERCO "GLOBALWIN VOS 32" O "ALPHA" PER ATHLON "SLOT A"!!
