Salve ragazzi a chi interessato cedo una Zotac 680 sigillata sostituita dal produttore , NO garanzia
Chiedo 250€ + spedizione
ZOTAC GeForce GTX 680: ZOTAC - It's time to play!
Model
Model ZT-60101-10P
Interface
Interface PCI Express 3.0* x16 (Compatible with 1.1)
Chipset
Chipset Manufacturer
GPU GeForce GTX 680
Core clock 1006 MHz (base) - 1058 MHz (boost)
Cores 1536
Shader Clock na
Memory
Memory Clock 6008 MHz
Memory Size 2GB
Memory Interface 256-bit
Memory Type DDR5
3D API
DirectX DirectX 11
OpenGL OpenGL 4.2
Ports
DVI 2 (DVI-I and DVI-D)
HDMI
DisplayPort
VGA (With included DVI-to-VGA adapter)
General
Tuner None
RAMDAC 400 MHz
Max Resolution 2560 x 1600
RoHS Compliant Yes
SLI Supported Yes (3-way)
Cooler With fan (dual-slot)
Dual-Link DVI Supported Yes
Supported OS
Packaging
Package Contents Driver Disk User Manual DVI-to-VGA adapter 2 x Dual MOLEX to 6-pin PCIe power cable
Game Bundle ZOTAC Assassin’s Creed 3-Game Pack
- non inquinate esistono i pvt
- code brevi max 3 ore
- precenza a mano
- pagamento anticipato tramite ricarica postepay
- prezzo non trattabile
- non accetto pagamenti dopo prova
- postate solo se interessati concretamente all'acquisto
- non scambio con niente
- astenersi perditempo professori e bimbiminkia
- in vendita anche su altri lidi
