Vendo x passaggio x79
EVGA Z77 FTW fattura datata 30/12/2012 comperata da un noto rivenditore EVGA
PAGATA OLTRE 360 EURO
VENDO A 250 EURO SPEDITA
Scatola e budle completo
Performance
Based on Intel Z77 chipset
Supports Intel Socket 1155 Processors
100MHz+ BCLK
Memory
4 x 240-pin DIMM sockets
Dual Channel DDR3
Maximum of 32GB of DDR3 2133MHz+
Expansion Slot
5 x PCIe x16/x8, 1 x PCIe x1
Storage I/O
6 x Serial ATA 300MB/sec (4x Internal + 2x E-SATA) with support for RAID 0, RAID1, RAID 0+1, RAID5, RAID10 and JBOD
4 x Serial ATA 600MB/sec (4 Internal) with support for RAID 0 and RAID1
Integrated Peripherals
8 Channel High Definition
2 x 10/100/1000
Multi I/O
10 x USB2.0 ports (6 external + 4 internal headers)
6 x USB3.0 ports (4 external + 2 internal headers)
Audio connector (Line-in, Line-out, MIC)
FireWire 1394A (1 external)
Form Factor
EATX Form Factor
Length: 12in ? 304.8mm
Width: 10.375in ? 263.5mm
Product Warranty
This product comes with a 3 year limited warranty. Registration is recommended
Operating System Support
Windows 7 32/64bit, Windows Vista 32/64bit, Windows XP 32/64bit
Power
When it comes to power management EVGA seems to be near the top of the pile. Offering two CPU 8 pin power ports to get the power to the CPU for crazy overclocking, solid state POSCAP capacitors, 7+1 phase CPU PWM and 3 Phase memory PWM
mi riservo di toglere l'inserzione quando riterrò di farlo
massima serietà
Priorità a mano
no perditempo
prezzo non trattabile visto la qualità del materiale
accetto postepaynon scambio
