Scheda madre come nuova completa di tutto con accessori ancora in garanzia con scontrino del 22/05/2008. PREZZO 150€
Questa scheda è X48 e monta DDR3. Per il resto le manca solo di fare il caffè....è la scheda più completa che abbia mai avuto, molti accessori non sono stati mai utilizzati.
LINK ASUS
Foto reali
Specifiche
CPU Intel Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® Extreme/Pentium® D/Pentium® 4 Processors
Support Intel® next generation 45nm CPU
Chipset X48
Intel ICH9R
Intel Fast Memory Access Technology
Front Side Bus 1600/1333/1066/800 MHz
Memoria 4 x DIMM, 8 GB, DDR3 1800*/2000*/1600/1333/1066/800 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
Supports Intel® Extreme Memory Profile (XMP)
* Overclocking speed
** For the X.M.P. support, CPUs with FSB 1333 or above are recommended.
*** Refer to ASUSTeK Computer or this user manual for the Memory QVL (Qualified Vendors List).
Slot di Espansione (blue @PCIe2.0 x16 mode, black @PCIe x4 or x1 mode) supports CrossFire Technology
3 x PCIe x16 1 x PCIe x1
x PCI
Storage
Southbridge
6 xSATA 3 Gb/s ports 0,1,5,10 Intel Matrix Storage Technology Support RAID External SATA 3.0 Gb/s port (SATA On-the-Go)
2 x 1 xUltraDMA 133/100/66 for up to 2 PATA devices
Support RAID 0,1,JBOD
JMicron® JMB363 PATA and SATA controller
LAN Dual Gigabit LAN controllersMarvell 88E8056® PCIe Gigabit LAN controller featuring AI NET2
Realtek RTL8110SC® PCI Gigabit LAN controller featuring AI NET2
Wireless LAN ASUS WiFi-AP @n
- 300Mbps* IEEE 802.11n (Draft) and backwards compatible with IEEE 802.11g / b
- Software Access Point mode
*300Mbps is IEEE 802.11n draft specification. Actual throughput will vary depending on the wireless environment and other parameters
Audio ADI® AD1988B 8 -Channel High Definition Audio CODEC
Coaxial / Optical S/PDIF out ports at back I/O
AI Audio 2
Support Jack-Sensing, Enumeration, Multi-streaming
IEEE 1394 2 Agere® L-FW3227 1394a controller supports x 1394a ports (one at midboard; one at back panel)
USB 10 USB 2.0 ports (4 ports at mid-board, 6ports at back panel)
ASUS AI Lifestyle ASUS Quiet Thermal Solution
- ASUS Fanless Design: Pure Copper Heat-pipe solution
- ASUS Fanless Design: Stack Cool 2
- ASUS Q-Fan 2
- ASUS Optional Fan for Water-cooling or Passive-Cooling only
ASUS Power Saving Solution
- ASUS EPU (Energy Processing Unit)
- ASUS 3rd Generation 8-phase Power
- ASUS AI Nap
ASUS AI Lifestyle
- ASUS AI Direct Link
- ASUS Express Gate
- ASUS WiFi-AP @n
ASUS Crystal Sound
- ASUS Noise Filter
- ASUS AI Audio 2
ASUS EZ DIY
- ASUS Q-Connector
- ASUS Q-Shield
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS AI Slot Detector
Caratteristiche di Overclock Intelligent overclocking tools
- ASUS AI Booster Utility
5.1 Precision Tweaker - vDIMM: 25-step DRAM voltage control 65 -step DRAM voltage control
- vChipset (N.B.): 49-step voltage control
- vCore: Adjustable CPU voltage at 0.0125V increment 0.00625V - vFSB Termination: 16-step reference voltage control
- vCPU PLL: 65-step CPU PLL voltage control
SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 800MHz 1MHz increment
Memory tuning from 800MHz up to 3200MHz
- PCI Express frequency tuning from 100MHz 150MHz at 1MHz
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Caratteristiche Speciali Multi-language BIOS
ASUS MyLogo 3
Porte I/O Pannello Posteriore 2 x WiFi-AP @n antenna jack x PS/2 Keyboard
1 x External SATA
x S/PDIF Out 1 x IEEE 1394a
1 x RJ45 port
2 x USB 2.0/1.1
6 Channel Audio I/O
8
Connettori I/O Interni 2 x USB connectors support additional 4 USB ports
1 x COM connector
x Floppy disk drive connector
1 x IDE connector
1 x SATA connectors
6 x IEEE 1394a connector
1 x CPU Fan connector
1 x Chassis Fan connector
1 x S/PDIF Out connector
1 4-pin ATX 12V Power connector
2 x 24 Power connector
Front panel audio connector
CD/AUX audio in
System Panel(Q-Connector)
BIOS 16 Mb Flash ROM
AMI BIOS
PnP
DMI 2.0
WfM 2.0
SM BIOS 2.3
ACPI 2.0a
Multi-language BIOS
ASUS EZ Flash 2
Gestibilità PXE WfM 2.0,DMI 2.0,WOL by PME,WOR by PME
Accessori UltraDMA 133/100/66 cable
FDD cable
6 x Serial ATA cables
1 x 2-port Serial ATA power cable
ASUS Q-Shield
User's manual
ASUS WiFi-AP @n manual
3 in 1 Q-connector
1 x 2-port USB2.0 / 1-port IEEE1394 module
2 x Optional Fan for Water-Cooling or Passive-Cooling only
ASUS WiFi-AP @n omni-directional antenna
CD di Supporto ASUS WiFi-AP @n Wizard
Drivers
ASUS PC Probe II
ASUS AI Suite
Anti-virus software (OEM version)
ASUS Update
Image-Editing Suite
Dimensioni ATX Form Factor
12 inch x 9.6 inch 30.5 cm x24.4 cm )
Prezzi tendenzialmente non trattabili
Precedenza consegna a mano ma su blocco passa avanti la spedizione (come specificato sotto)
Precedenza a blocchi (con materiale in altri 3d)
Precedenza sui blocchi o le modalità di vendita per me più convenienti
In vendita altrove
Spedisco con imballi a prova di corriere ma non mi assumo nessuna responsabilità su eventuali danneggiamenti
Spese a carico del destinatario
Pagamento bonifico, postepay o paypal con maggiorazione
