COOLER EXPRESS Dual Evaporators Hyper-Cooling Unit (2GPUs)
|  | CHARACTERISTICS:
| ‧ Strong cooling performance, reaching the maximum cooling effect of the CPU core.
| ‧ Dual Evaporators, synchronous cooling of two GPUs.
| ‧ Low power consumption, low noise and High-performance freezing compressor is used.
| A PURPOSE:
| 1.For computer overclocking.
| 2.Cooling of Educational computer or Laboratory's computer.
COOLER EXPRESS Dual Evaporators Hyper-Cooling Unit (2GPUs)Main Structure |
Back Sidel | Inside Structure |
Black coated box for great looks. | High Performance-Low Noise Compressor |
Instant ventilating fan with rev regulator | Considerate master power switch design |
COOLER EXPRESS Dual Evaporators Hyper-Cooling Unit (2GPUs)Standard Accessories |
Multi-function Control card : 1. Auto and manual modes 2. Overload power down protection 3.Revolutionary CPU or GPU drying before shutdown.4.May be used as power expansion board. | Blue-Backlight LCD panel |
GPU's Kit -Support : Nvidia6800,7800,7900 series and ATI x850,1800,1900 series |
GPU's Anti-Dew Electrothermal Plate | GPU's Anti-Dew Heat-insulation Foam |
OS Auto Starting Connective Line&Power Line | Fixing Screw of GPU's Kit –Support Nvidia&ATI |
COOLER EXPRESS Dual Evaporators Hyper-Cooling Unit (2GPUs)Choosing-purchase Accessories |
| Temperature-measuring Lines of T2&T3 |
