[Ch+Spedizione]Mb-Wb-Pompe-Tolotti-Rame-Phase-Dissy-Mp3-Ecc
Pagina 1 di 4 1 2 3 4 ultimo
Visualizzazione dei risultati da 1 a 10 su 33
    byte L'avatar di Jeff
    Jun 2005
    Ortona/Italy
    Valutazione
    2 (100%)
    Predefinito [Ch+Spedizione]Mb-Wb-Pompe-Tolotti-Rame-Phase-Dissy-Mp3-Ecc
    Salve a tutti,causa inutilizzo vendo i seguenti componenti:
    Artic - Cooling Accelero X1 -€17
    Application:
    NVIDIA 6800 series
    NVIDIA 7800 series (just PCIe)
    NVIDIA 7900 GTX
    not compatible to most 7900 GT boards (passive cooler for 7900 GT will be available from 06/2006)
    Please check your board with the height restriction drawing to assure compatibility.
    Link AcceleroX1
    Artic - Cooling Accelero X2 -€17
    Application:
    ATI X1800 series
    ATI X1900 series
    ATI X1950 series
    Link Accelero X2
    JetStart VC1000 -€30
    VC1000 is a full covered VGA Cooler for NVIDA & ATI VGA Cards. Built in big size speed adjustable fan with blue LED and a movable fan above, especially designed for SLI VGA card. Easily it enhances the heat dissipating for no matter GPU or both side memory modules. Quiet, high performance and fancy outlook designed VC1000 satisfies your overclocking need and allow you enjoying silence and unique modding outcome.
    Link VC1000
    JetStart VC2000 -€25
    VC2000 is an universal Cooler compatible with most NVIDIA & ATI high-level VGA cards. Its pure aluminum shaped super conductive core satisfies your overclocking need; and the silent fan with blue LED, fancy outlook design, allow you enjoying a quiet and unique outcome from integration. It is the choice for all overclockers and modders.
    Link VC2000
    PolarFLO HDD46 Copper Dual Hard Drive Liquid Heat Sink -€85
    PolarFlo HDD Wb
    PolarFLO E Series CPU Liquid Heat Sink -€40
    PolarFlo E-Series
    EK Water Blocks -€35
    EK-Wave-Socket A
    Asetek DYO CPU Universal Cooler CPU01/P1 -€35
    Support for all CPU’s in one cooler: Intel P4 S478, AMD S754/S939/S940 (AMD 64).
    Asetek
    Hydor Seltz L40 -€45
    Tolotto Dal Pieno - €100
    Puro Rame Elettrolitico,dimensioni
    12cm Alto - 1,9cm Buffer - 4cm largo - 1cm di bordo per lato
    già coibentato con neoprene.
    Rame Vario :
    -Tubo 6cm di dametro alto 20cm Disponibili 4 -15€ l'uno
    -Base Per tolotto 6cm alto 1cm -5€
    -Base Per tolotto 6cm alto 2cm -10€
    -Base in rame 6cm alto 3cm -15€
    -Blocco rame pieno alto 6cm largo 6cm -30€
    Parti Phase:
    -Condensatore Mod Grande con Alloggio per ventola -30€
    -Capillare 5mt sezione 0,031 -€5
    -Filtri x3 -€5
    -Valvole x2 -€5
    Jun 2005
    Ortona/Italy
    Valutazione
    2 (100%)
    Tolotto dal pieno
    Rame
    COndensatore
    Filtri-Cap-Ecc
    Accelero X1
    Accelero X2
    Jun 2005
    Ortona/Italy
    Valutazione
    2 (100%)
    CODE:
    Speeze 600w:VENDUTO
    Mobo Epox:VENDUTO
    L45: VENDUTO
    Apogee : VENDUTO
    Iriver H10 : VENDUTO
    Rulez:
    Priorità
    -Blocco
    -Blocco In parti
    -Mio prezzo
    Features:
    -Postepay OK
    -Limatina OK,se in blocco o altro,
    -In Vendita Altrove
    -No Gare Ribasso
    Jun 2005
    Ortona/Italy
    Valutazione
    2 (100%)
    Up per il mio 3d
    tebibyte L'avatar di Morfeus
    Periferia del villaggio globale
    Valutazione
    2 (100%)
    un up per l'ottimo materiale, se scendi un pò sullo switech quasi quasi mi tolgo il capriccio
    Jun 2005
    Ortona/Italy
    Valutazione
    2 (100%)
    Originariamente inviato da Morfeus
    Si può fare 45 compreso un j+3....
    Che ne dici?
    Grazie per l'up
    AH:
    Mobo Epox:Venduta a Zippo [PCT]
    Accelero X2 :Venduto a Kikko_90[HWU]
    Ali 600w:Venduto a rompat[HWU]
    _FOX_
    Guest
    Un UP per l'ottimo materiale, usato una volta per vederne il funzionamento, e un UP per l'ottimo venditore, vai JEFFOLì
    Jun 2005
    Ortona/Italy
    Valutazione
    2 (100%)
    Un up per il 3d
    Jun 2005
    Ortona/Italy
    Valutazione
    2 (100%)
    uppppp
    Jun 2005
    Ortona/Italy
    Valutazione
    2 (100%)
    Originariamente inviato da Jeff
    Un up per il 3d
  1. Vendo 2 radiatori X2-Extreme rame 3 ventole+2 pompe Hydor Seltz 20 II [LUCCA + SS]
    By fr4nc3sco in forum -= Vendite : Hardware - Software =-
  2. [Ch+Sped.]Vga+Wb+L40+Tolotti+Rame+Phase+Dissy+Ps2+Ecc.
    By Jeff in forum -= Vendite : Hardware - Software =-
    Risposte: 34
  3. [BRINDISI + SPEDIZIONE] AMD64 3000 E 3200 VENICE lettori mp3 cellulari ecc
    By epikiss in forum -= Vendite : Hardware - Software =-
  4. [brescia] p5p800, gskill 4400, radeon8500, tolotti e pompe watercooling
    By Dimas in forum -= Vendite : Hardware - Software =-
  5. Roma + Spedizione DFI 939 - 3500+ Ecc Ecc
    By wasky in forum -= Vendite : Hardware - Software =-
