[pd+sped]Hwlabs Black Ice Xtreme III,Primochill Dual Bay Res,Laing DCC Ultra - NUOVO
    kibibyte L'avatar di TeknŲ
    Jun 2006
    Localitą
    Padova
    Valutazione
    3 (100%)
    Predefinito [pd+sped]Hwlabs Black Ice Xtreme III,Primochill Dual Bay Res,Laing DCC Ultra - NUOVO
    Vendo:
    Typhoon dual bay reservoir 5.25" full plexi uv blu
    Vendo per cambio case.
    Solo testata, completa di raccorderia Ybris per 4 rientri e 2 uscite sigillati con Loctite 5331.
    Occhio che nn č la Danger den con una sola entrata e una sola uscita!
    Adatta a sistemi mono e doppia pompa.
    Completamente realizzata in plexi uv blu:
    Questa č la foto della vasca in funzione.
    Review:
    recensione 1
    recensione 2
    Prezzo € 60.00
    Pompa Laing DDC-Pump 12V Ultra - NUOVA - IMBALLATA
    This product has gone under new revision, with more power output.
    This pump is the first pump worldwide, which can be installed in mass-produced water-cooled workstations, and it is ideally suitable for the water cooling of processors and electronic components. Due to its size and output, a multitude of applications are available. This pump is an electronically commuted ball-motor pump, with running times of more than 50.000 hours at 12 V. The only flexible part of a ball-motor pump is a sphere-formed rotor-/runner unit, which is propped up against an extremely hard, wear-resistant ceramics bearing ball. A conventional axle with journal bearing and shaft sealing is not available. The spherical bearing of the rotor-/runner unit on the ceramics bearing ball provides a lot of advantages: a development of the bearing play – and thus a noise increase - is theoretically not possible. The pump is silent over the whole running time.
    The bearing is self-adjusting. It is lubricated directly by the delivery medium (wet-running pump). There is basically no need for maintenance. Since the rotor is always held magnetically in the intended position, smaller dirt particles are no problem. Blocking of the pump is not possible under normal conditions. Even after lengthy downtimes a safe approach is given. The permanent magnetic rotor/ runner unit is propelled by a magnetic field, which is produced by the surrounding stator. This is built entirely around the rotor. The entire pump is thus with 38 mm only a little higher than the stator itself. It easily fits into all conventional PC, Barebone and Mini PC cases. A separate magnetic shielding is not necessary under normal conditions. Normally, a separate magnetic shielding is not necessary. The ball motor principle enables an economical enterprise with comparatively high achievements. The tension variation can easily regulate the DDC direct current pump over a large capacity range. All medium-affecting parts are completely corrosion resistant.
    Technical data:
    Dimensions: (WxLxH) 62x62x38mm (without connections)
    Motor construction type: electronically commuted ball-motor
    Working voltage: 12 V DC Voltage
    Admissible voltage area: 6 to 13,2 V
    Delivery height: at 12V: 4,7m
    Max. delivery rate: 600L/h
    Delivery media: water, water-/glycol compounds
    Max. system temperature: 60° C
    Medium-affecting parts: stainless steel 1.4571, PPS-GF40, EPDM O-sealing rings, alumina, hard carbon
    Connections: 2x 1/4" hose connection
    Characteristics: Plexi cover, 5mm LED drilling, incl. uncoupling set for 3,5” slots.
    Prezzo € 85.00
    Radiatore Hwlabs Black Ice Extrem III BLU - NUO - IMBALLATO
    Il top dei radiatori.
    REVIEW
    2-pass Double-row Low Pressure Drop Radiator specifically developed for PC Watercooling based on the new high-performance Black Ice® Xtreme design.
    Xtreme performance: rated for 2445KCal per hour (9702 BTU per hour).
    Double Row 360 mm (9.44 inch) Copper-finned core consisting of flat tubes for maximum heat conductivity.
    High-density louvered copper fin configuration for enhanced heat dissipation.
    Built-in plenum chamber for increased performance and noise reduction.
    Self-tapping and case mounting holes for easy installation of 120mm fans.
    Now with 12.5 mm (1/2 inch) pre-angled inlet/outlet barbed hose connectors. *Available in 9.5 mm (3/8 inch) custom female 1/4" NPT/BSPT/BSPP compatible fittings. (dealer option).
    Optimal 397 x 133 x 40 mm (15.63 x 5.25 x 1.77 inch) dimensions allows it to fit inside most mid-tower cases.
    Designed to meet the performance demands of hardcore Xtreme Professional PC watercooling and case mod enthusiasts.
    Prezzo € 70.00
    COMUNICAZIONI DI PREZZI E ALTRO SOLO IN PVT.
    RuleZ Mercatino:
    :: prezzi ss escluse
    :: postare se realmente interessati
    :: astenersi perditempo
    :: in vendita altrove
    :: preferenza consegna a mano
    Modalitą di Consegna / Spedizione
    ** CONSEGNA A MANO **
    preferenza consegna a mano zona Padova / Vicenza
    in caso di spedizione:
    ** SPEDIZIONE **
    a carico dell'acquirente nelle modalitą concordate in sede di trattativa
    in caso di spedizione solo pagamento anticipato mezzo:
    :: poste pay
    :: bonifico bancario
    Le mie 100+ trattative positive nei forum.
    Jun 2006
    Localitą
    Padova
    Valutazione
    3 (100%)
    Aggiungo:
    Waterblock Lunasio L4E CROMO - NUOVO
    Mai usato.
    Vendo per cambio piattaforma.
    Il Lunaforce Luna4Ever č in grado di mettere a liquido il Chipset senza interferire con le schede video anche se queste usano il loro ingombrante dissipatore originale.
    Saldatura professionale di qualitą
    Rettifica di tutti i lati del WB
    Cromatura e lucidatura
    Compatibilitą tubi: Silicone 10x14 - Silicone 12x17 - Cristal 10x14 - Cristal 12x17 - Cristal14x19
    Portata flusso: 481 litri/h con Eheim 1200 e tubo da 12x17
    PREZZO € 40.00
    N° 10 PEZZI VENTOLA COOLERMASTER 120 MM ULTRASILENT UV BLU
    CARATTERISTICHE:
    Fan Dimension 120x120x25mm
    Voltage (Volt) 12 VDC
    Current (Ampere) 0.05 A±0.01A
    Input Power (Watt) 0.60 W±10%
    Speed (R.P.M.) 1220 R.P.M.±10%
    Air Flow (CFM) 42.73 CFM
    Air Pressure (mmH2O) 1.56 mmH2O
    Noise (dB-A) 22 dB-A
    Weight 120 g
    Life (hour) 30,000 hours
    Bearing Type Sleeve
    Speed Senser Yes
    NUOVE ANCORA IMBALLATE.
    PREZZO € 8.00 CAD.
    DVD LITE ON 16X BLACK
    PERFETTO IN GARANZIA.
    PREZZO € 15.00
    DVD PLEXTOR 16X BEIGE
    PERFETTO NO GARANZIA.
    PREZZO € 10.00
    NEON BIANCHI SHARKOON
    PREZZO € 8.00
    CAVO IDE FX AC RYAN 30 CM UV BLU
    PREZZO € 7.00
    Ram Sink Cooler Master nuovi
    PREZZO € 6.00
    display grafico 256x128 DA CABLARE
    nuovo - imbustato
    pellicola protettiva sul display
    retroilluminazione verde
    chipset oki m5298/5299
    compatibile con controller sed1330/1335 non fornito (il controller č facilmente reperibile in internet).
    fornisco il solo display.
    PREZZO € 20.00
    Sheet e specifiche per il cablaggio:
    SPEC
    DRAW
    esempi di display interfacciato:
    Jun 2006
    Localitą
    Padova
    Valutazione
    3 (100%)
    Pompa Venduta
    Localitą
    Etą
    34
    Valutazione
    4 (100%)
    sono interessato a 2 ventole e quanto viene l' lcd piccolo
    Get Rich or Die Tryin'
    Jun 2006
    Localitą
    Padova
    Valutazione
    3 (100%)
    hai pvt.
    Jun 2006
    Localitą
    Padova
    Valutazione
    3 (100%)
    l4e e vasca primochill venduti.
    Sep 2004
    Localitą
    PISA
    Etą
    Valutazione
    1 (100%)
    edit
  1. Laing DCC 500 12V 1PlusT + TOP/RES XSPC
    By KURTZ in forum -= Vendite : Hardware - Software =-
  2. EK lancia la nuova EK-BAY Spin RES DUAL Loop - [NEWS]
    By giampa in forum -= Water Cooling =-
  3. waterstation lc17, fuzion, ybris k7, c3, mcp 655, dual bay, black ice pro 2[fi+sped]
    By drive97 in forum -= Vendite : Hardware - Software =-
  4. [pd+sped]kit A Liquido Lunasio Xr1-revo1215-black Ice Xtreem Iii-mcp655-crystal Trap
    By TeknŲ in forum -= Vendite : Hardware - Software =-
    Risposte: 11
  5. [PT+SPED] Laing DDC350 + Top , Vaschetta single bay , Black Ice micro II
    By vkbms in forum -= Vendite : Hardware - Software =-
