(TREVISO)Vendo Powercolor Radeon 9800PRO 128Mb. 256BIT DDR -
    mebibyte
    Mar 2005
    Valutazione
    2 (100%)
    Predefinito (TREVISO)Vendo Powercolor Radeon 9800PRO 128Mb. 256BIT DDR -
    Come da Oggetto vendo Praticamente nuova (Con scatola,cavi ecc.. e 2 giochi originali: Tomb Raider the angel of darkness e Rainbow Six 3).
    Allego le caratteristiche della scheda video:
    Chipset
    -RADEON 9800PRO
    Support Memory/Memory bandwidth
    -128MB DDR SDRAM
    -256bit
    Connectors
    -VGA
    -TV-out (S-Video connector)
    -DVI Connector ¡@
    Cinematic Rendering
    Immerse yourself in the world¡¦s fastest and most compelling game play, courtesy of the unprecedented speed and control of RADEON™ 9800 family of visual processors
    128MB DDR memory generates breath-taking frame rates
    256-bit memory interface delivers the bandwidth for real time 3D graphics and barrier free performance
    8-pixel pipeline architecture doubles the rendering power of other graphics processors
    Maximum 3D
    Brace yourself for feature film quality on your PC, the new standard in 3D entertainment.
    SMARTSHADER™ 2.1 technology supports the latest Microsoft® DirectX® 9.0 feature sets, enabling more complex and cinematic-quality lighting effects
    SMOOTHVISION™ 2.1 technology delivers the sharpest, clearest textures, removes jaggies and brings out fine texture details without sacrificing frame rates
    128-bit full floating point precision enables billions of color variations to render the same lighting and effects as Hollywood studios
    Generation Now Technology
    Advanced stability meets revolutionary features in the RADEON™ 9800 Series, the only 8-pipeline graphics solution in its 2nd generation.
    ATI¡¦s award-winning Visual Processing Unit (VPU) is optimized to run the most demanding 3D and 2D next-generation games and applications
    Supports the latest Microsoft® DirectX® 9.0 and OpenGL® 2.0 feature sets.
    FULLSTREAM™ and VIDEOSHADER™ produce smoother looking, higher quality video and streaming Internet content without putting extra strain on the CPU.
    Contenudo della confezione : scheda video, set di cavi e adattatori, altro.
    Compresa di garanzia. Io la scheda l’ho presa 02/03/2004. La garanzia è di 3 anni.
    Dò la precedenza alla consegna a mano altrimenti spedisco in contrassegno.
    La scheda regge tranquillamente le frequenze dalla 9800xt.(412-730) e anche di più.
    La scheda la vendo a 165 euro.
    A chi interessa compreso con la scheda vendo anche MicroCool Northpole.
    Qui di seguito riporto le caratteristiche tecniche del dissipatore e della ventola:
    • Dimensioni: 46 x 43 x 51 mm
    • Peso: 195g
    • Materiale guscio superiore: alluminio anodizzato
    • Sistema d'aggancio: a staffe con viti
    • Materiale interno: rame
    • Tecnologia: skiving
    • Numero alette di raffreddamento: 26
    • Dimensioni ventola: 40 x 40 x 20mm
    • Voltaggio operativo: 12VCD
    • Voltaggio di partenza: 5VCD
    • Velocità di rotazione: 8200 ± 1000 RPM
    • Portata d'aria: 10.8 CFM
    • Pressione statica: 0.27 Inch-H20
    • Corrente assorbita: 0.13 A
    • Potenza assorbita: 1.6 W
    • Rumore: 27,5 dB (A)
    • Connettore: a 3 poli
    Vendo Scheda video e MicroCool Northpole (se volete ve lo monto direttamente io) a 185 Euro.
    Io sono di Treviso.
    Per maggiori informazioni o altro scrivetemi in E-mail:dj883u2@yahoo.it
    Ciao.
    Aug 2001
    Provincia di Caserta
    Valutazione
    0
    Sai se monta il Core R360 per caso?
    Le memorie che Chip montano?
    A quanto l' hai tirata al max?
    mebibyte
    Mar 2005
    Valutazione
    2 (100%)
    ciao,allora monta come Core r350 con memorie Hynix 2.8. Al massimo sono riuscito a tirarla senza antefatti a 440 per il core e 385 per la ram,la stabilità è assoluta.Questa stabilità l'ho ottenuta montando il MicroCool Northpole.La scheda in defolt riesce a tenere 412/365 ovvero le frequenze della radeon 9800XT.Sei interessato alla scheda?
    Spero di essere ststo abbastanza esaustivo nelle mie risposte.
    Aug 2001
    Valutazione
    0
    Ciao E' un ' ottima R350 , non c'e' ke dire.
    Io cercavo una R360. Sono indeciso, su cosa fare.
    Se riesci a concludere con altri per me non ci sono problemi.
    Vorrei pensarci un po'
    mebibyte
    Mar 2005
    Valutazione
    2 (100%)
    Ci mancherebbe pensaci tranquillamente. Devo dire che quella volta sono stato molto fortunato nel trovare questa scheda grafica che sale cosi' bene.R360 effettivamente ha il sensore x la temperatura e non è poca cosa.Comunque se ci ripensi io sono qui,se ce l'ho ancora disponibile sarà tua.
    Aug 2001
    Valutazione
    0
    Ti ringrazio, in effetti una R350 ke senza VMOD fa 440 di CORE ad Aria senza Artefatti non e' poco
  1. [VC-TO-NO+sped] Powercolor 9800pro AGP - 128Mb 256bit
    By MRG in forum -= Vendite : Hardware - Software =-
  2. [verona + sped]cerco 9800pro 128mb 256bit
    By cpuburn in forum -= Acquisti : Hardware - Software =-
  3. [TORINOeMILANO]VENDO RADEON 9800PRO 256BIT NUOVA
    By ToXSysDwn in forum -= Vendite : Hardware - Software =-
  4. VENDO PowerColor 9600Pro 128mb e Ali 500w
    By Figus in forum -= Acquisti : Hardware - Software =-
    Risposte: 23
  5. [TREVISO] Vendo ATI RADEON AIW 32Mb DDR Retail + Regali
    By Cybergigio in forum -= Acquisti : Hardware - Software =-
