GMP v.2.0. Informazioni Varie
GiveMePower (GMP) is a tool that will give you "System Level" privilege for the application you will open with it.
"System Level" privilege are similar to "Root" under Linux system and by so, it is higher than Administrator.
Typical usage :
- Can help installing a driver that have access denied problem.
- Accessing previously inaccessible registry region with "regedit".
- System files edit. ETC...
GMP is a powerful and dangerous utility. It should only be used by users who known what they are doing.
Some application were not made to have this kind of system privilege and may do react unexpectedly; so be careful.
