BIOSTAR T-POWER i45 [Thread Ufficiale]
Pagina 1 di 16 1 2 3 4 5 6 7 8 9 10 11 ... ultimo
Visualizzazione dei risultati da 1 a 10 su 151
    Predefinito BIOSTAR T-POWER i45 [Thread Ufficiale]
    SCHEDA TECNICA:
    * Intel LGA775 Platform
    * Support latest Intel Socket 775 Core 2 Extreme/Core 2 Quad/Core 2 Duo Processors
    * Support Intel 45nm CPU processors
    * Intel P45+ICH10R chipset
    * FSB 1600/1333/1066
    * Dual-Channel DDR2 -1200(OC)/1066/800
    * Support AMD CrossFire X Technology
    * Biostar Exclusive Tpower utility
    * Biostar Hybrid Space-Pipe Thermal solution
    * 100% Japanese Solid Capacitors design
    Chipset:
    Intel P45 / Intel ICH10R
    CPU SUPPORT
    # Intel® Core™2 Extreme Processor
    # Intel® Core™2 Quad Processor
    # Intel® Core™2 Duo Processor
    # Intel® Pentium® Dual-Core Processor
    # Intel® Celeron® Dual-Core Processor
    # Intel® Celeron® Processor 400 Sequence
    FSB
    # Support FSB 800/1066/1333/1600MHz
    MEMORY
    # Support Dual Channel DDR2 667/800/1066/1200(OC) MHz
    # 4 x DDR2 DIMM Memory Slot
    # Max. Supports up to 16GB Memory
    EXPANSION SLOT
    # 2 x PCI Slots
    # 2 x PCI-E x1 Slot
    # 2 x PCI-E x16 2.0 Slot (CFX x8)
    STORAGE
    # 6 x SATA2 3Gb/s Connector
    # 2 x eSATA Connector
    # 1 x IDE Connector
    # Support SATA RAID: 0,1,5,10
    USB
    # 6 x USB 2.0 Port
    # 3 x USB 2.0 Header
    GbE
    # Realtek RTL8111C - 10/100/1000 Controller
    CODEC
    # Realtek ALC888S 8+2 Channel HD Audio
    REAR I/O
    # 1 x PS/2 Mouse
    # 1 x PS/2 Keyboard
    # 2 x eSATA2 3Gb/s Connector
    # 6 x USB 2.0 Port
    # 1 x RJ-45 Port
    # 6 x Audio Connector
    INTERNAL I/O
    # 1 x IDE Connector
    # 1 x Floppy Connector
    # 1 x Front Audio Header
    # 1 x Front Panel Header
    # 1 x CD-IN Header
    # 1 x S/PDIF-IN Header
    # 2 x S/PDIF-OUT Header
    # 1 x CPU FAN Header
    # 2 x System FAN Header
    # 1 x Serial Header
    DIMENSION
    # ATX Form Factor Dimension: 30.5 cm X 24.4 cm ( W x L )
    OS SUPPORT
    # Support Windows 2000 / XP / XP 64 / Vista / Vista 64
    ACCESSORIES
    # 1 x IDE Cable
    # 6 x SATA Cable
    # 6 x SATA Power Cable
    # 1 x S/PDIF Cable
    # 1 x I/O Shield
    # 1 x CD Driver
    # 1 x User Manual
    # 1 x DIY Thermal Kit
    LA SCATOLA ED IL BUNDLE:
    PARTICOLARI DEL LAYOUT:
    Zona socket
    Dissipatore del chipset
    Slot dimm
    Pulsantini onboard e display Led ( fa la diagnostica e una volta finita, segna la temperatura della CPU)
    Porte I/O
    Retro mainboard
    Ultima modifica di pippo369 : 18-07-2008 a 13:08
    BIOS:
    UFFICIALI
    P45AA710 del 10-07-2008
    P45AA620 del 20-06-2008
    P45AA619 del 19-06-2008
    P45AA530 del 30-05-2008
    BETA
    P45AA708 DEL 08-07-2008
    UTILITY PER FLASH BIOS:
    VERSIONE DOS
    AFUDOS4.23
    VERSIONE WIN
    UPDATE BIOS
    DRIVERS:
    CHIPSET
    AUDIO
    WinXp
    Win Vista
    LAN
    WinXp
    WinVista
    UTILITY PER OVERCLOKING:
    Biostar T-Power II
    Questa utility permette di :
    Overcloccare il sistema regolando, la frequenza ed anche i voltaggi da Windows!
    Salvare i profili di overclock
    Flashare il bios da Windows
    Monitorare temperature e voltaggi
    Setfsb Version 2.1.69.2
    (Usare il PLL ICS9LPRS919BKL)
    IL BIOS
    SETTING PER OPERARE OVER 600mHZ
    [BIOS SETUP] O.N.E
    Over-Clocking Navigator [Manual OverClock]
    Intel(R) SpeedStep(tm) : Disabled
    Ratio CMOS Setting : ×6 (change higher for benching subzero obviously)
    CPU Frequency Setting : 570(boot)
    Over Clock Retry Count : 2
    FSB Compensation: Disabled
    FSB(Bsel) To NorthBridge Latch : 1333
    DRAM Frequency : DDR2-1140
    DDR2 Enhance Mode : Disabled
    DRAM Timing Configuration
    DDR2 RCOMP Configuration : 2 (con alcuni kit va meglio il 4)
    Static tREAD Value : AUTO
    Configure DRAM Timing by SPD : Enabled
    [EDIT] this will give you CAS5 clocks and PL10 past 600MHz FSB
    for PL9 past 600MHz FSB you need to manually set CAS4 timings
    Clock Gen Configuration
    PCIE Frequency Setting : 100
    CPU Clock Skew Control : 200ps
    (G)MCH Clock Skew Control : 100ps
    CPU Clock Driving Control : Auto
    Voltage Configuration
    CPU Voltage : quelli richiesti dalla vostra cpu
    DDR Voltage : +0.600v o comunque quelli richiesti dalla vostre ram
    Chipset Voltage : +0.400v - 0.500v (raffreddare almeno con ventola il chipset)
    FSB Voltage : +0.30v
    CPU Core1 GTL Ref Voltage : 0.63*VTT
    CPU Core2 GTL Ref Voltage : 0.67*VTT
    MCH GTL Ref Voltage : Auto
    CPU PLL Voltage : 1.5v
    Con questi settaggi la mia boota fino a 615Mhz
    Ultima modifica di pippo369 : 10-09-2008 a 23:32
    MODIFICHE POSSIBILI:
    OVP_MOD
    Riguardo le mod al momento esiste solo la OVP_mod ritratta sopra.
    I voltaggi selezionalbili arrivano fino a +1,3V, nel mio caso particolare la mainboard già a +0,8V erogava 1,965V, quindi non so fino a che punto la OVP_mod sia necessaria, forse serviva soltanto con le prime revisioni di bios.
    V_Drop mod (questa mod è in fase di testing)
    Questa mod è in fase di testing, l'autore Johnny Bravo ha così scritto:
    "I45 Vdroop mod by me - work in progress as I still haven't found the time to do the mod. My measurements were off as the traces are so small actual resistance is more like 2.2Kohm so a 20Kohm variable resistor will suffice".
    Ultima modifica di pippo369 : 16-08-2008 a 20:59
    Reserved For Pippo
    meglio abbondare che deficere
    resitere devo resistere!!!!!! L'avatar di dinamite2
    Jul 2006
    CATANIA REGNA
    Iscrittissimo, da possessore di tale scheda non posso che essere felice di questo trad.
    Peccato che in italia siamo solo io e pippo ad avercela....
    qualche impressione?
    Il bios ad es. com'è?
    Originariamente inviato da nidecker
    Arriveranno anche le foto del bios, il tempo di organizzarmi.
    Il bios è molto ben organizzato, per quanto riguarda i voltaggi funziona un pò come quelli DFI si dà un tot che va ad aggiungersi al default.
    C'è anche la possibilità di salvare le configurazioni, anche se ancora devo provarlo.
    Jul 2006
    CATANIA REGNA
    Ecco che arrivo..........
    Particolare del display post code, dopo aver finito di eseguire il post il display segna la temperatura della cpu, e stranamente coincide con quella rilevata da Real temp......
    Altra figata il Software propietario Biostar, permette di fare tutto, si possono cambiare pure i voltaggi di cpu,ram,nb oltre che variare l'fsb....
    compatibile pure con le ultime schede Nvidia, anche x queste è possibile visualizzare le frequenze e cambiarle a piacimento
    I love Biostar
    Ultima modifica di dinamite2 : 18-07-2008 a 13:56
    tebibyte L'avatar di Morfeus
    Periferia del villaggio globale
    Disponibilità e prezzi ita, se ne sa qualcosa? L'alimentazione è a 4 fasi?
  1. Biostar Tpower I45 + E8600
    By Delex in forum -= Vendite : Hardware - Software =-
  2. Vendo Biostar T-Power I45
    By Maxxpower in forum -= Vendite : Hardware - Software =-
  3. Vendo Biostar tpower I45 [Taranto]
    By lallabell in forum -= Vendite : Hardware - Software =-
  4. Vendo Biostar Tpower I45 [TS+s.s]
  5. [N.B.C.L.] Biostar Tpower i45+ E8500@Ln2
    Risposte: 20
