Visualizza i risultati del sondaggio: Quale Masterizzatore DVD DL preferite?
Chi ha votato
9. Non puoi votare questo sondaggio
  • Lg Gsa-4160B
    3 33.33%
  • Lite On 1633S
    1 11.11%
  • Pioneer Dvr108
    5 55.56%
  • Sony Dru710A
    0 0%
masterizzatori DVD DL
    Sep 2004
    Vicino al Cimitero.....
    Predefinito masterizzatori DVD DL
    Devo cambiare masterizzatore DVD, qualre mi consigliate fra questi disponibili?
    I prezzi sono molto ravvicinati con una differenza max di 15 euro.
    tebibyte L'avatar di asphalt
    Sep 2004
    Senza ombra di dubbio il Pioneer 108...sono presenti firmware in grado di eliminare il blocco di scrittura mx sui Dvd a 4X permettendo al masterizzatore di scrivere alla max velocità... in'oltre scrive sui Princo...il che ti dice tutto....
    Riporto un'old firmware....
    o RPC-1 (Region Free):
    Remember, patching your drive to region free is only half
    the job. A region free drive will not turn your system
    region free by itself.
    o 12xRip (Unlimited ripping speed):
    The official firmware from Pioneer limits the ripping
    speed on video discs. This limitation has been removed.
    12x is only the maximum THEORETICAL speed that the drive
    can achieve, but not the sustained speed you are likely to
    get when ripping. Most DVD's will start ripping around 2x
    to 4x and end up around 8x or 10x. THIS is normal.
    o nx4all : All speeds for -R/+R/+R9 media
    This firmware allows you to select ALL burning speeds on
    -R/+R/+R9 media. The official firmware from Pioneer only
    allows a limited set of Pioneer approved media to use these
    speeds but this patch removes that limitation. Write
    strategies for approved media should not be altered by the
    patch.
    PROPER BURN OF NON APPROVED MEDIA IS NOT GUARANTEED!
    Not patched: - Bitsetting ("Burn on -R media instead, people!!!")
    - nx4all on RW media. Tests have shown that burning RW media
    at higher than rated speed was a bad idea
    Release Notes: Consider this firmware as beta, especially on the +R/+R9 side
    AGAIN, HIGH SPEED BURN OF LOW GRADE MEDIA IS NOT GUARANTEED
    gibibyte L'avatar di beppe
    Feb 2002
    senza dubbio il pioneer 108.....con il firmware di NIL ho fatto ormai + di 50 dvd tutti masterizzati a 12x (sono dei ritek g04 a 4x)
    anche i dl li scrive a 4x anche se sono dei 2,4x
    mebibyte
    Mar 2005
    NEC ND3540
    kibibyte L'avatar di Filpel
    Feb 2005
    Quoto dj... I Nec sono ottimi e hanno ottimi prezzi. Sul lato prettamente tecnico non saprei dirti chi è il migliore. Se cerchi in giri ci sono sicuramente in giro delle recensioni e nei casi migliori dei confronti tra le varie velocità di lettura, masterizzazione etc.
    Comunque il Pioneer DVR-108 ha la stessa meccanica del NEC 3500. Quindi, se puoi, prenditi il Pioneer 109...
  1. Masterizzatori Dvd
    By ASTERIX in forum -= Hardware generico =-
  2. Tutti I Firmware Per Lettori Cd, Masterizzatori, Dvd R, Dvd Rw, Dvd Ram E Lettori Dvd
    By coolman in forum -= Periferiche di memorizzazione =-
  3. masterizzatori
    By N.A. in forum -= Acquisti : Hardware - Software =-
  4. Masterizzatori
    By jena.fuck in forum -= Hardware generico =-
    Risposte: 21
  5. Finalmente masterizzatori DVD da 4,7GB in vendita!
    By animaloss_OLD in forum -= La Piazza =-
