Originariamente inviato da
marcoc1712
I messagi di wget li hai tolti o non è prorpio andato wget? (nel caso, come ha fatto il download)?
Pardon, ho stupidamente usato "tee" per salvare l'ouput. Ecco quello completo
codice:
root@ubuntu-Squeeze:/opt# ./setup.pl --clean
* FALCON INSTALLER SETUP **********************************************
Options: --clean
Started in: /opt
** PREPARE ************************************************************
--2017-03-23 00:38:48-- https://github.com/marcoc1712/installFalcon/archive/master.tar.gz
Risoluzione di github.com (github.com)... 192.30.253.113, 192.30.253.112
Connessione a github.com (github.com)|192.30.253.113|:443... connesso.
Richiesta HTTP inviata, in attesa di risposta... 302 Found
Posizione: https://codeload.github.com/marcoc1712/installFalcon/tar.gz/master [segue]
--2017-03-23 00:38:49-- https://codeload.github.com/marcoc1712/installFalcon/tar.gz/master
Risoluzione di codeload.github.com (codeload.github.com)... 192.30.253.120, 192.30.253.121
Connessione a codeload.github.com (codeload.github.com)|192.30.253.120|:443... connesso.
Richiesta HTTP inviata, in attesa di risposta... 200 OK
Lunghezza: 17931 (18K) [application/x-gzip]
Salvataggio in: "master.tar.gz"
master.tar.gz 100%[===================>] 17,51K --.-KB/s in 0,1s
2017-03-23 00:38:49 (133 KB/s) - "master.tar.gz" salvato [17931/17931]
Info: master.tar.gz unpacked in /opt
Info: installFalcon-master renamed to Installer
** EXECUTE ************************************************************
*** CLEAN INSTALL *****************************************************
mkdir /var/www
mkdir /var/www/backupFalcon
mkdir /var/www/backupFalcon/before
--2017-03-23 00:38:52-- https://github.com/marcoc1712/falcon/archive/master.tar.gz
Posizione: https://codeload.github.com/marcoc1712/falcon/tar.gz/master [segue]
--2017-03-23 00:38:53-- https://codeload.github.com/marcoc1712/falcon/tar.gz/master
Lunghezza: 361949 (353K) [application/x-gzip]
master.tar.gz 100%[===================>] 353,47K 547KB/s in 0,6s
2017-03-23 00:38:54 (547 KB/s) - "master.tar.gz" salvato [361949/361949]
mkdir /var/www/falcon/exit
mkdir /var/www/falcon/data
mkdir /var/log/falcon
mkdir /var/www/backupFalcon/20170323003850
mkdir /var/www/backupFalcon/20170323003850/usr
mkdir /var/www/backupFalcon/20170323003850/usr/bin
mkdir /var/www/backupFalcon/20170323003850/etc
mkdir /var/www/backupFalcon/20170323003850/etc/init.d
mkdir /var/www/backupFalcon/20170323003850/etc/default
--2017-03-23 00:38:59-- https://github.com/marcoc1712/squeezelite-R2/releases/download/v1.8.4-(R2)/squeezelite-R2-deb-i386
Risoluzione di github.com (github.com)... 192.30.253.112, 192.30.253.113
Connessione a github.com (github.com)|192.30.253.112|:443... connesso.
Posizione: https://github-cloud.s3.amazonaws.com/releases/43764736/1f5a8416-0f17-11e7-9893-f59abc4c6756?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAISTNZFOVBIJMK3TQ%2F20170322%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20170322T233900Z&X-Amz-Expires=300&X-Amz-Signature=637c3a6ee4c2c10a3036396366ca8d6ee03230e6e33674b972708a295c4faa0a&X-Amz-SignedHeaders=host&actor_id=0&response-content-disposition=attachment%3B%20filename%3Dsqueezelite-R2-deb-i386&response-content-type=application%2Foctet-stream [segue]
--2017-03-23 00:39:00-- https://github-cloud.s3.amazonaws.com/releases/43764736/1f5a8416-0f17-11e7-9893-f59abc4c6756?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAISTNZFOVBIJMK3TQ%2F20170322%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20170322T233900Z&X-Amz-Expires=300&X-Amz-Signature=637c3a6ee4c2c10a3036396366ca8d6ee03230e6e33674b972708a295c4faa0a&X-Amz-SignedHeaders=host&actor_id=0&response-content-disposition=attachment%3B%20filename%3Dsqueezelite-R2-deb-i386&response-content-type=application%2Foctet-stream
Risoluzione di github-cloud.s3.amazonaws.com (github-cloud.s3.amazonaws.com)... 52.216.65.112
Connessione a github-cloud.s3.amazonaws.com (github-cloud.s3.amazonaws.com)|52.216.65.112|:443... connesso.
Lunghezza: 152256 (149K) [application/octet-stream]
Salvataggio in: "squeezelite-R2-deb-i386"
squeezelite-R2-deb- 100%[===================>] 148,69K 225KB/s in 0,7s
2017-03-23 00:39:01 (225 KB/s) - "squeezelite-R2-deb-i386" salvato [152256/152256]
mkdir /var/log/squeezelite-R2
*** INSTALL REPORT ****************************************************
- Time : 2017/03/23 00:38:50
- Package : main
- Filename : ./setup.pl
- Line : 235
- Subroutine : Installer::remove
- Command : remove Webserver
- Gravity : INFO
- Message : ok
- Details :
- Time : 2017/03/23 00:38:52
- Package : main
- Line : 235
- Command : remove Squeezelite
- Gravity : INFO
- Message : ok
- Details :
- Package : main
- Line : 235
- Command : remove falcon code
- Gravity : INFO
- Message : ok
- Details :
- Package : main
- Line : 235
- Command : remove falcon data and backups
- Gravity : INFO
- Message : ok
- Details :
- Package : main
- Line : 235
- Command : remove
- Gravity : INFO
- Message : falcon removed!
- Details :
- Package : main
- Line : 235
- Subroutine : Installer::install
- Command : prepare
- Gravity : INFO
- Message : ok
- Details :
- Time : 2017/03/23 00:38:59
- Package : main
- Line : 235
- Command : install falcon code
- Gravity : INFO
- Message : ok
- Details :
- Time : 2017/03/23 00:39:02
- Package : main
- Line : 235
- Command : install squeezelite-R2
- Gravity : INFO
- Message : ok
- Details :
- Time : 2017/03/23 00:39:06
- Package : main
- Line : 235
- Command : install webserver
- Gravity : INFO
- Message : ok
- Details :
- Package : main
- Line : 235
- Command : install
- Gravity : INFO
- Message : falcon correctly installed!
- Details :
STATUS : INFO
MESSAGE: falcon removed!
** CLEANUP ************************************************************
Info: Installer moved to /var/www/falcon/falcon/src/Installer
* END *****************************************************************
