Catalyst 11.1 release
    Predefinito Catalyst 11.1 release
    update
    Package Content
    The AMD Catalyst software suite 11.1 contains the following:
    • AMD display driver version 8.812
    • HydraVision™ for Windows XP, Windows Vista and Windows 7
    • Southbridge/IXP Driver
    • AMD Catalyst Control Center version 8.812
    Performance highlights of the AMD Catalyst™ 11.1 release includes:
    • F1 2010:
      • Performance increases up to 12% on AMD Radeon HD 6900 and AMD Radeon HD 6800 Series single card configurations with anisotropic filtering and anti-aliasing disabled.
      • Performance increases up to 10% on ATI Radeon HD 5800 Series single card configurations with anisotropic filtering and anti-aliasing disabled.
    • Left 4 Dead 2:
      • Performance increases up to 17% on AMD Radeon HD 6800 Series single and Crossfire configurations with anisotropic filtering and anti-aliasing disabled.
      • Performance increases up to 8% on AMD Radeon HD 6900 Series single configurations with anisotropic filtering and anti-aliasing disabled.
    Resolved Known Issues for the Windows 7 Operating System
    This section provides information on resolved known issues in this release of the AMD Catalyst 11.1 software suite for Windows 7. These include:
    • Aliens vs. Predator game no longer fails to load with quad Crossfire enabled..
    • Text is no longer missing randomly in Nostradamus- The Last Prophecy demo.
    • Graphical corruption is no longer seen occasionally in Nostradamus- The Last Prophecy demo.
    • The Protoss Pylon Matrix is now rendered correctly in Starcraft 2.
    • Task switching in Dirt2 with Vsync enabled no longer causes a dual link monitor to go black.
    • System no longer crashes when enabling Crossfire with 2 monitors connected to the primary card and 2 monitors connected to the secondary card.
    • List of supported TV resolutions now includes 1080p 24Hz (if supported by the TV display).
    • Cyberlink PowerDVD no longer randomly exits when playing a blu-ray title with the “Aero-on” option enabled in the player.
    • An error message is no longer intermittently displayed when viewing a slideshow using Windows Live Photo Gallery.
    • Windows Media Player no longer displays a black screen when continuously playing several VC1 format files over a 4 hour period.
    • “Host Application not responding” error message is no longer randomly displayed when launching the AMD Catalyst™ Control Center.
    Resolved Known Issues for the Windows Vista Operating System
    • Video corruption is no longer randomly seen during DVD playback using Windows Media Player.
    • Progressive scan DVD content no longer causes Windows Media Center to hang.
    • Interlaced DVD content no longer exhibits frame drops and jerky playback.
    Resolved Known Issues for the Windows XP Operating System
    • Frame drops are no longer observed when playing HD interlaced content in Windows Media Center.
    • Call of Duty – Black Ops no longer randomly hangs on AMD Radeon HD 57xx series products.
    • Crossfire using AMD Radeon HD 68xx series products no longer hangs intermittently when running 3dMark 2006.
    • “Host Application not responding” error message is no longer randomly displayed when launching the AMD Catalyst Control Center.
    Known issues under the Windows 7 operating system
    The following section provides a summary of open issues that may be experienced under the Windows 7 operating system in the latest version of AMD Catalyst. These include:
    • Blocky video corruption may be displayed randomly when playing back SD DVD content using Windows Media Player.
    • Video may flicker randomly when using PowerDVD to play the blu-ray edition of “Iron Man 2”.
    • Screen may flicker and objects may be duplicated in Medal of Honor under DirectX 11 with Crossfire enabled on AMD Radeon HD 69xx series products.
    • Objects may be duplicated in Dead Rising 2 when Super Anti Aliasing is enabled on AMD Radeon HD 69xx series products.
    Known Issues Under the Windows Vista Operating System
    The following section provides a summary of open issues that may be experienced under the Windows Vista operating system in the latest version of AMD Catalyst. These include:
    • AVIVO options do not take effect on WinDVD 10 blu-ray playback.
    • Doom 3 and Quake 4 may display corruption when running on a AMD Radeon HD 47xx series product.
    Known Issues under all Windows Operating Systems
    The following section provides a summary of open issues that may be experienced under all supported Windows operating systems in the latest version of AMD Catalyst. These include:
    • An error message may be displayed if the power plan is changed several times (from Power Save to High Performance) when the AMD Catalyst Control Center is open.
    • The AMD Catalyst Control Center may flicker when adjusting brightness using a hotkey.
    Release Notes: http://support.amd.com/us/kbarticles...easeNotes.aspx
    link ATI Radeon? Video Card Drivers
    Ultima modifica di brugola.x : 26-01-2011 a 18:49
    prevedo l'uscita a breve di un hotfix per i nuovi driver WHQL 11.1
    se andiamo a vedere i dettagli, quì la versione 11.1 è riportata in modo corretto
    quì non lo è perchè rimane riconosciuta come v.10.12
    i problemi comunque non sono tutti quì, ho provato a disintallarli e due volte su due mi è andato in crash il sistema rendendomi un blue screen con l' errore Atihdw76.sys.
    La terza volta che ho provato a disintallarli ci sono riuscito
    Ho rimesso i 10.12 e gira tutto a meraviglia, ho ritiratò sù i nuovi 11.1 e gira tutto ok anche con questi ma quando ho riprovato a disinstallarli è rispuntato l'errore Atihdw76.sys con il blue screen.
    Da cosa può dipendere questo problema?? Da dove spunta quel Atihdw76.sys??
    infatti eccolo
    AMD Catalyst Driver 11.1a Hotfix Features:
    • Performance improvements for AMD Radeon™ HD 6900 & AMD Radeon HD 6800 series graphics cards
    • AMD Catalyst Control Center – New Tessellation controls
      • Gives users control over the tessellation levels used in applications
    • AMD Catalyst AI Texture Filtering updates
      • The High Quality setting remains unchanged: This setting provides reference quality filtering from AMD hardware
      • The Quality setting now matches the High Quality setting in all respects but one: it enables an optimization that limits tri-linear anisotropic filtering to areas surrounding texture mipmap level transitions, while doing bilinear anisotropic filtering elsewhere. This optimization offers a way to adjust filtering performance without visibly affecting image quality
      • The Performance setting has also been updated. It now provides a smooth filtering option that is designed to eliminate most shimmering while preserving the detail provided by anisotropic filtering.
    ecco un paio di screen che mettono in evidenza le differenze che ci sono tra i nuovi Catalyst 11.1 ed il nuovo hotfix datato 26 gennaio
    Nome File: AMD_Catalyst_11.1a_Win7_Jan26
    Data Rilascio: 26 gennaio 2010
    Dimensione: 104MB
    download diretto: AMD_Catalyst_11.1a_Win7_Jan26
    info: http://support.amd.com/us/kbarticles...11aHotfix.aspx
    Ultima modifica di brugola.x : 27-01-2011 a 19:27
  1. Catalyst 10.6 release
    Risposte: 17
  2. Catalyst 10.1 beta release
  3. Catalyst v.9.4 beta release
  4. ATi Catalyst 8.11 release
