ATi Tray Tools v.1.6.9.1484 release
E' disponibile in rete il download della nuova beta di ATi Tray Tools :smt023
Software highlights:
- Support for ATI Control Center
- Support for TV Out and displays with profiles
- Options to change Theater mode together with TV Out
- Overclocking with templates including FAN Control
- Automatic overclocking when application required 3D mode
- Temperature monitoring
- Artifact Tester with ability to find maximum stable clocks for GPU and Memory.
- Game profiles with desktop shortcut creation.
- Direct3D settings with templates, GUI form and tray popup menu
- OpenGL settings with templates, GUI form and tray popup menu
- Hardware low level color correction
- Hardware tweaks. Setting PCI latency timer
- Radeon Information Show information about memory type, active rendering pipe lines and more
- System wide Hot Keys. (Load profiles any profiles/work with colors/run any application)
- Refresh Lock system with ability to set separate refresh rates for each resolution.
- Tweak for overriding Pixel and Vertex Shaders
- Speed improvement tweaks for Anisotropic/Trilinear Filtering. Support for Catalyst A.I.
- Support for system options, VPU Recover, DMA Copy and so on
- Support Display Rotation.
- Support for MMC applications
- Support for HYDRAVISION applications
- Monitoring Graphs. (GPU/Env temperature. GPU/Mem speed, Main CPU Usage).
- A lot of useful things. Like Save/Restore Desktop icon positions and more
- Audio Recorder
- Screenshots system
- Powerful Plug-Ins support. (API for VC++/Delphi included)
- PCI Register Set. Allow to program any registers in any PCI device at start up time. For advanced users only!
- Source code for plugins as examples.
ATi Tray Tools 1.6.9.1484 Beta
