Afterburner v.1.6.0. beta 2 release
novità :mrgreen:
http://www.nexthardware.com/forum/ga...4/2_beta_2.jpg
changelog:
- Manually selected screenshot folder path is saved properly now
- Screen capture and On-Screen Display hotkey events are now being processed via direct connection to the On-Screen Display server instead of command line. Due to this change Screen capture and On-Screen Display visibility control hotkeys are being processed faster now
- Updated OSD server 3.7.0 beta 8 includes the following changes:
- Removed stealth mode auto disabling feature
- Fixed resource allocation issue causing abnormal performance drop in D11 OSD codepath
- DirectX screen capture engine is no longer using DirectX runtimes to capture and compress screenshots. Screen capture and compression to PNG/JPG formats in DirectX applications is now handled by own more effective LIBPNG/JPEGLIB based library
- PNG and JPG screen capture support for desktop and OpenGL applications
- Improved race condition protection system for multithreaded 3D engines (e.g. Age of dragons : Origins)
- Updated Ukrainian localization
l'archivio quì sotto comprende anche la v.1.0.4. di Kombustor
Download:http://event.msi.com/vga/afterburner...up160Beta2.rar
PS
http://www.nexthardware.com/forum/ga.../2_voltage.jpg
