Ho testato il mio pc con Sandra 2000 e alla voce PCI & AGP mi ha dato questi WARNING mi potete dire il significato e come risolverli? forse gli scatti mei games dipendono da questi errori?
Confido in voi
Il mio sistema è:
Athlon 550 MOBO ms-6167 chipset 751 skedavideo creative geforce2 mx mem 64Mb
1° Warning 1207 - AGP 2.0 devices may be incompatible with early AGP 1.0 mainboards and may need later drivers (e.g. AGP miniport, video drivers).
Fix: Make sure you have updated your System BIOS and Video BIOS. If you're using Windows 95 with the AGP/USB patch, consider upgrading to Windows 98. If you're not using an Intel chipset, download the latest version of the miniport driver for your chipset.
2° Warning 1206 - Device latency is high - the higher the latency, the more data a device can transfer in one go. The device may be hogging the bus for too long. Some video card drivers set the latency high in order to perform faster. The problem is that other devices (especially sound cards, network) won't have enough time to transfer their data resulting in lower performance (e.g. sound drop outs, lockup). Generally all devices should have latency around 32, with high performance devices (e.g. video card, sound) with 64.
Fix: Go to BIOS Setup\Settings\PCI & AGP Devices and reduce PCI latency to 128 or 64. Contact the mainboard manufacturer or video card manufacturer for more details.
