Catalyst 5.5
sono disponibili er il download i nuovi catalyst
control panel:
http://www2.ati.com/drivers/5-5_xp-2k_dd_cp_wdm.exe
control center
http://www2.ati.com/drivers/5-5_xp-2...cc_wdm_enu.exe
ecco uno spaccato delle fix:
Issues Resolved in Catalyst™ Software Suite 5.5
The following section provides a summary of the issues that have been resolved in the latest version of Catalyst™. These include:
3DMark05: Running the application under Windows XP for extended periods of time no longer results in the operating system failing to respond when using an ATI Radeon™ X700 PRO
Ashli Viewer sample Wood: Display corruption is no longer noticed when Anisotropic Filtering set to 4x or above
Ashli Viewer v1.6.0: Running the application under Windows 2000 and launching a sample item found in the Programs & Shaders no longer results in corruption being displayed in the sample item
City of Heros: Playing the game under Windows XP with an ATI Radeon™ Xpress 200 series installed no longer results in the characters in the game appearing corrupted
Freedom force VS The 3rd Reich: Playing the game under Windows XP with an ATI Radeon™ 8500 installed no longer results in the super hero character attributes appearing blank
Imperial Glory Demo: Playing the game under Windows XP with an ATI Radeon™ X800 installed no longer results in the game failing to respond
Star Wars Knights of the Old Republic 2: Setting the graphic option in the Catalyst™ Control Center to Optimal Quality, followed by launching the game and setting the resolution option to 1600x1200, no longer results in a performance drop being noticed
Star Wars Knights of the old republic: Loading the Dantooine level of the game under Windows XP no longer results in slow game performance
Setting the desktop display to 800x600 or 1600x1200 16/32bpp no longer results in the incorrect display resolution information being provided when checking the video control panel in the Catalyst™ Control Center
Setting the display device to 1080i no longer results in the text on the custom format being illegible
Setting a customized resolution for 720p now works properly when maintaining the aspect ratio
Moving the TV to desktop2 and selecting swap device or double up no longer results in the CRT being in panning mode and display corruption being seen on the TV
Having a TV connected as the only display device and clicking the OK button in the ATI displays tab found in the Advanced section of the Display Properties results in a flash of the TV image being noticed
Connecting and enabling an HDTV and entering the properties page for the HDTV no longer results in the D3/D4 options being available in the D-Connector Control Panel
The occasional Windows error messages no longer occurs when booting into extended desktop under Windows XP when using an ATI Radeon™ X300 or X600
Corruption is no longer seen when connecting a secondary display device and moving the primary display device to the left of the secondary device, followed by disconnecting the primary display device and then reconnecting it
Previewing or launching the aquarium screen saver under Windows XP Media Center Edition no longer results in the operating system failing to respond
RF online game compatibility issue with all ATI Radeon™ series
Launching the Catalyst™ Control Center help files from the Start->All Programs->Catalyst™ Control Center now results in the localized version of the help file being displayed
Catalyst™ Control Center: Running the French custom install no longer results in a NewFeature1 component being listed
The link found in the second and third help page for the Change Desktop Settings found in the Japanese version of the Catalyst™ Control Center no longer cross-references to an incorrect help page
A black screen is no longer displayed when launching AMCap and attempting to view video from the tuner when using either the svideo or composite inputs
Display corruption is no longer noticed on the TV when setting the TV format to PAL-B and attempting to adjust the flicker removal in the TV Advanced option
Having a TV and CRT connected and clicking on Preview Automatic adjustment in the Optimize Media Center no longer results in both display devices displaying a black screen
Known Issues for Catalyst™ Software Suite 5.5
The following section provides a brief description of known issues associated with the latest version of Catalyst™. These include the following:
Doom3 Resurrection of Evil: Loading the saved game Medical Labs, may result in hesitation being noticed for a brief moment when moving through the door that is displayed in front of the character. Topic number 737-19379
Farcry: Playing the game under Windows XP SP2 with the display set to 1024x76832bpp along with AA disabled results in flashing textures being noticed when setting the game's video options to high detail. This issue is know to occur when using an ATI Radeon™ 9100 or 8500 series product. Topic number 737-10089
Half-Life 2: Having the display set to 1024x768 32bpp and setting the video options in the game set to 1600x1200 and all other options set to their maximum values results in sluggish performance and missing textures. Topic number 737-10086
Rainbow six3: Athena Sword: Playing the game under Windows 2000 with an ATI Radeon™ X700 installed results in the game failing to retain its resolution option of 1600x1200 if you Alt-tab out of the game and then Alt-tab back to the game. Topic number 737-535
Serious Sam: The Second Encounter: Playing the game for approximately 5 to 10 minutes under Windows XP with the game quality set at normal/default, results in display corruption being seen in the menu. Topic number 737-10090
Star Wars Knights of the Old Republic 2: Playing the game under Windows XP with an ATI Radeon™ 9800 series installed, results in display corruption being noticed when changing the in-game options from low to maximum Topic number 737-10091
Star Wars Knights of the Old Republic 2: Running the Dantoonie level of the game may result in hesitation being noticed. Topic number 737-19378
World of Warcraft: Enabling Full-Screen Glow in the game may result in a blue screen image being displayed when walking under water. Topic number 737-19075
Assigning a hotkey to increase the overlay gamma results in the hotkey not functioning properly when playing an MPEG using the Windows Media Player. Topic number 737-494
The Apply button in the Custom settings of the Advanced mode found under the Catalyst™ Control Center Video standard settings is grayed out when playing a media file. Topic number 737-497
Installing the display driver and the Catalyst™ Control Center, results in a runtime error and the system tray failing to start when attempting to create multiple user accounts and enabling fast user switching. Topic number 737-10084
The Catalyst™ Control Center installation currently does not check for the installation of Microsoft .Net Framework before preceding with the install, resulting in an error message being displayed when attempting to launch the Catalyst™ Control Center. Topic number 737-10085
Changing the DPI setting found in the General tab of the display properties to Large size (120 DPI) results in the change not taking effect when launching the Catalyst™ Control Center. Topic number 737-18885
The Scale to Full Screen option found in the Theater Mode settings of the Catalyst Control CenterE is currently unavailable when using multiple display devices and enabling clone mode. Topic number 737-19380
buon DL!
I soliti fix... Azz però! Quanta roba...
Sì, ci hanno dato dentro...
io non ho notato differeze dai precedenti, per lo meno non nei giochi che faccio, però onestamente se non benchmarki con la x800 non ti rendi conto se migliori di qualche frames... ne fa sempre abbastanza...
Io con la x850xt turbo mi sono trovato malissimo :( Cmq ho tirato dentro i 5.6 che sto testando ... vedrem come va :)
