Nuovi Catalyst 5.2
Sono disponibili i nuovo drivers per le schede ATI, ecco il link
http://www.ati.com/home/online/CatalystCCCdriver.html
http://www.ati.com/home/online/CatalystXPdriver.html
ed ecco un elenco delle modifiche:
4x4 Evolution2: Attempting to play the game under Windows XP with an ATI RADEON™ X300/X600 series installed no longer results in the operating system failing to respond when the screen is set to 1600x1200 32bpp and OpenGL Renderer is enabled
4x4 Evolution 2: Display corruption is no longer noticed when having the display set to 1600x1200 32bpp along with the texture detail set to high and split screen rendering enabled
Serious Sam: Playing the game under Windows XP results in the display flashing when TRUFORM is enabled
Sims 2: Playing the game Veronaville under Windows XP while having the desktop set to 1024x768 32bpp along with AA set to 6X no longer results in corruption being noticed in the fields
Selecting the option; Enable Video Mode, results in the CATALYST™ CONTROL CENTER not being able to return to the default setting for the Enable Video Mode option
Switching language support for the CATALYST™ CONTROL CENTER no longer results in the slider bar for the engine clock being enabled when the option found in OVERDRIVE™ is locked
Navigating to View->Define a Custom View and deselecting all options found in the 3D option of the Edit Custom View tab, no longer results in the Standard Settings option remaining selected
Intermittent failure of the VPU Recover report not being sent is now resolved
Double-clicking the slider bar found in CATALYST™ A.I. no longer results in the Disable CATALYST™ A.I. option becoming de-selected
Disabling 3D preview no longer results in the preview continuing to run on a secondary display device
Having the 3D preview running on the secondary display adapter and attempting change display modes, no longer results in the primary display device displaying a black screen and error messages appearing
English is no longer the default language when installing the CATALYST™ CONTROL CENTER under Windows XP Japanese version
The CATALYST™ CONTROL CENTER Version number is now displayed correctly in all localized languages
The Display Manager Notification dialog box is now displayed in the correct localized language
The OpenGL driver is no longer disabled after boot up when both AGP Read and PCI Read are disabled
Sono segnalati aumenti di prestazioni in FarCry e 3dmark05 per i possessori di X800pro e X700pro/XT di circa il 7%.
Ciao e buon download!!!
Da test eseguiti non ci sono amumenti così rilevanti :(
Quello che mi preoccupa che tra breve(nei prossimi mesi) ATI rilascerà i futuri drivers Catalyst con il solo Control Center, cosa che sinceramente a me non piace visto la maggiore pesantezze...
concordo, comunque sicuramente ci saranno gli omega, dna ed altri che li faranno moddati anche senza ccc....
