Guida alla disinstallazione driver ATI
    pebibyte
    Mar 2001
    Predefinito Guida alla disinstallazione driver ATI
    Ottima, trovata su Rage3D
    quoto
    1. Go into the Control Panel and under the ADD/REMOVE SOFTWARE icon uninstall the ATI MultiMedia software and/or the ATI DVD software.
    2. Uninstall the ATI drivers also found in the Add/Remove section. Once removed, it will prompt you to reboot....do so.
    3. When returning to windows, the NEW HARDWARE FOUND wizard will come up and will tell you that it has found a new VGA card and will prompt you for drivers. Hit CANCEL!
    4. Now, go to START - SEARCH - FOR FILES OR FOLDERS and do a search for all files and folders using the filename ati*.*
    This search will normally give you 3 to 4 files found in your c:/windows directory and subdirectories (including the Windows/System directory). Select these files and erase them. Now go to your Recycle Bin and Empty your bin.
    5. Next...time to go to your Registry. Go to START -- RUN -- regedit
    Here go to key HKEY_LOCAL_MACHINE -- SYSTEM -- ControlSet001 -- Control -- Video . Here there should be 4 entries. 3 of them are default Windows XP entries and the 4th one is put in by the ATI drivers. Expand each one by one until you see ATI entries. Once found, erase the entire key.
    Now repeat the same step above for the ControlSet002 key and the CurrentControlSet Key. Normally, whenever you erase a key in the ControlSet001, XP automatically deletes it in the CurrentControlSet section too. So if the ATI key is not found in the CurrentControlSet section, don't worry about it.
    Once all keys are deleted, proceed to the next step.
    6. While still in the registry, go to the key HKEY_LOCAL_MACHINE -- SOFTWARE section. Here you should find an ATI Technologies key. Select it and delete it. In that same section, look for an Installed Options key. Expand it and there you should find another ATI Technologies key. Select it and erase it.
    7. Still in the registry, go to HKEY_CURRENT_USER -- Software and there you should find another ATI technologies key. Select it and erase it. Once all this is done, close the registry. the registry is now clean.
    8. Close all windows and reboot.
    9. When in windows after the reboot the NEW HARDWARE FOUND WIZARD will pop up again. Cancel that. Now find the new ATI drivers that you have downloaded and extracted and run the SETUP file. Once complete, reboot and you are done. You may want to reinstall your ATI MMC software and DVD software if you use them. DONE!
    Brescia
    ottimo!!
    grande musmax
  1. Risposte: 31
  2. Alcune modifiche alla Guida
    By bibo01 in forum cMP² = cMP + cPlay
  3. Disinstallazione corretta driver
    By Patrick25 in forum Assistenza tecnica
  4. guida alla gigabyte DS4
    By dinamite2 in forum -= MotherBoards =-
    Risposte: 22
