Forse sono rimasto un pò indietro, avete mai usato questa utility per zappare completamente i detonator? Fantastica!
http://guru3d.com/detonator-destroyer/
You have this really cool nVidia based graphics card and try to keep up-to date with the tremendous amount of driver leaks and install them all the time ? Did you ever wonder if there are remains of previous driver builds somewhere stacked in the registry or windows system ? Ever simply wanted to change video drivers with your nVidia based card?? Worried about bits being left over and not doing a complete uninstall affecting performance? No need to worry anymore just use this great tool and it will do it for you.
Detonator Destroyer is the only tool that completely removes detonator drivers from your Windows 95 (All versions),Windows98,Windows 98SE,Windows ME system. It removes all versions of detonators from 6.XX up!
è un po vecchiotta...cmq funge!
rimuovendoli dal pannello di controllo-installa disinstalla applicazioni va benissimo!! :)
