http://www.nexthardware.com/forum/ga...7934/1_Top.jpg
Grazie a un caro amico Joyghezzi per le foto
http://www.nexthardware.com/forum/ga...1_DPP_0004.JPGhttp://www.nexthardware.com/forum/ga...1_DPP_0006.JPG
http://www.nexthardware.com/forum/ga...00CL7__10_.jpghttp://www.nexthardware.com/forum/ga...600CL7__5_.jpghttp://www.nexthardware.com/forum/ga...600CL7__2_.jpghttp://www.nexthardware.com/forum/ga...1_DPP_0003.JPG
http://www.nexthardware.com/forum/ga...600CL7__1_.jpghttp://www.nexthardware.com/forum/ga...00CL7__11_.jpghttp://www.nexthardware.com/forum/ga...600CL7__7_.jpghttp://www.nexthardware.com/forum/ga...600CL7__8_.jpg
http://www.nexthardware.com/forum/ga...00CL7__15_.jpghttp://www.nexthardware.com/forum/ga...00CL7__12_.jpghttp://www.nexthardware.com/forum/ga...00CL7__13_.jpg
Series: Ripjaws Series
Model: F3-12800CL7D-8GBRH
Type: 240-Pin DDR3 SDRAM
Capacity: 8GB (2 x 4GB)
Speed: DDR3 1600 (PC3 12800)
Cas Latency: 7
Timing: 7-8-7-24
Voltage: 1.6V
Multi-channel Kit: Dual Channel Kit
Heat Spreader: Yes
Features: Compatible Chipset: Intel P55
Manufacturer Warranty
Parts: Lifetime limited
Labor: Lifetime limited
