Abit AB9 pro [Thread ufficiale]
http://www.atris.it/Forum/photoplog/..._ab9_pro_1.JPG
Altre immagini: (cliccare per ingrandire)
http://www.atris.it/Forum/photoplog/..._ab9_pro_2.JPG http://www.atris.it/Forum/photoplog/..._ab9_pro_3.JPG http://www.atris.it/Forum/photoplog/..._ab9_pro_4.JPG
Link abit ---> ABIT AB9 PRO
CARATTERISTICHE TECNICHE
CPU
Support Intel® Core™ 2 Quad, Core 2 Duo Extreme, Core 2 Duo, Pentium® D and Pentium® 4 processors with1066/800MHz FSB Support Intel® 2006FMB Conroe CPU
Chipset -> Intel® P965 / ICH8R Chipset
Memory
4 X 240-pin DIMM sockets support max. memory capacity 8GB Supports Dual channel DDR2 800/667/533 Un-buffered Non-ECC memory
LAN -> On board Dual PCI-E Gigabit LAN controller supports 10/100/ 1000M Ethernet
Audio
On board 7.1 CH HD Audio CODEC
Supports auto jack sensing and optical S/PDIF Out
Expansion Slots
1 x PCI-E X16
2 x PCI-E X1
2 x PCI
Internal I/O
1 x Floppy Port supports up to 2.88 MB
1 x Ultra DMA 133/100/66/33 IDE connector
9 x SATA 3Gb/s connector
3 x USB header (support 6 ports)
1 x FP-Audio, 1 x CD-In
Back Panel I/O
1 x PS/2 Keyboard
1 x PS/2 Mouse
abit Silent OTES™
1 x S/P DIF In
1 x S/P DIF Out
1 x eSATA
7.1 CH Audio connector (Front, Line-in, MIC-in, Center/Subwoofer, Surround, Rear Surround)
4 x USB 2.0
2 x RJ-45 LAN connector
Serial ATA
6 x SATA 3Gb/s offer by Intel® ICH8R support Intel® Matrix Storage Tech(AHCI & RAID 0/1/5 /10)
2 x SATA 3Gb/s offer by JMicron® JMB363 support up to 0,1,0+1,JBOD RAID function
1 x SATA 3Gb/s offer by Silicon Image 3132
Form Factor -> ATX form factor 305 x 245mm
PCB Color -> Orange
RoHS -> 100% lead-free process and RoHS compliant
abit Engineered ->abit SoftMenu™ Technology, abit µGuru™ Technology, abit Silent OTES™ Technology
BIOS
16 ---> ftp://ftp.abitshop.com/pub/bios/ab9//ab916.zip
1. JMB363 now works as intended after resuming from S3.
2. Fixed the issue that the HDD LED will always light when disabling JMB363.
3. Update JMicron RAID BIOS to V1.06.57.
(Please update both JMicron SATA driver and installation disk)
4. BIOS compiled date: 12/19/2006
15 ---> ftp://ftp.abitshop.com/pub/bios/ab9//ab915.zip
1. Supporto funzione multiplier adjusting per i CPU Core 2 Duo.
2. Aggiornato AHCI BIOS ROM.
3. Migliorata la compatibilità con alcune memorie.
4. Aggiunto l'item "Thermal control".
5. Supporto funzione adjusting DRAM tRFC.
6. Supporto Conroe L CPU.
7. L'audio ora funziona come dovrebbe dopo aver ricominciato dal S3.
8. La funzione "wake on LAN" ora funziona come dovrebbe.
9. Data di compilazione del BIOS: 10/19/2006
14 ---> ftp://ftp.abitshop.com/pub/bios/ab9//ab914.zip
1. Supporta la funzione IDE/ RAID mode adjusting sul JMicron363
2. Migliorata la compatibilità di memoria con alcune memorie
3. Data di compilazione del BIOS: 09/08/2006
13 ---> ftp://ftp.abitshop.com/pub/bios/ab9//ab913.zip
1. Aggiustato il problema del CAS Latency che non si può impostare su 5 e 6.
2. Data di compilazione del BIOS: 08/09/2006
MANUALE ---> ftp://ftp.abitshop.com/pub//manual/e...ab9_series.zip
RECENSIONI
Abit AB9 Pro: A sneak peek at Intel's new P965 chipset
P.s.: posizione infelice quella dell'ata 133... :s1
