Eh sì signori, questa è la migliore rom per il nostro 9600!
Non ancora in italiano, anche se non dovrebbe tardare ad arrivare, dimostra potenza e bellezza non equiparabili alle altre versioni.
Main features:
* Official Hermes WM6 build (OS 5.2.1437 build 17944.0.3.1)
* Newest OEM components
* 100% Translated user interface (OS & OEM apps)
* Localized hardware & software keyboard layout
* HSDPA enabled
* Video call enabled (New build)
* Smart dialing enabled (New build)
* VOIP enabled
* Windows Update enabled
* Office Mobile 2007 (New build)
* OneNote Mobile 2007
* Office Zip and Fax viewers
* Windows Live (Official build)
* Remote Desktop Mobile
* All bugs from the previous versions should be fixed!
OEM applications:
* Camera app 4.0 (New version)
* Comm Manager 1.7 (new version)
* Comm vibrate button
* SIM Manager 6.16 (New version)
* Bluetooth FTP 1.2 (New build)
* SAP Settings 2.02 (New build)
* Task Manager 1.51 (new build)
* Audio Manager 1.2 (New version)
* HTC Bluetooth QuickLink (new version)
* HTC Home 1.5 (New 6-tabs version)
* Today Music Plug-in (New build, compatible with Audio Manager and WMP)
* Voice Recorder 1.10 (New version)
* ArcSoft MMS 4.0 (New version)
* Streaming Player 2.10h (New version)
* GIF Player 1.10
* Adobe Acrobat Reader LE 2.0 (New version)
* Adobe Flash Lite 2.1
* Pocket RAR 3.60
* Jbed Java Midlet Manager 2007.04.25
* Jeyo SMS Backup 1.1
* SuperBright (VJLumosIII)
* FlashLight (VJCandelaLite)
* FieldTest 1.57
* Advanced configuration tool (New version)
* Automatic operator settings configuration (new version)
* VoIP configuration (New version)
Some tweaks:
* OS only ROM
* Free extended ROM
* 4MB pagepool
* Big storage
* Optimized cache
* Best Bluetooth A2DP settings
* Bluetooth DUN support
* Avoid MicroSD issues
* SDHC support
* Improved power management
* Automatic network time/zone synchronization
* Supports new GSM/UMTS bands
* Error report disabled
* Customer feedback removed
* Integration with Vista WMDC
* Date on single line
* 3G icon & prefix
* Nicer 3G icon
* Nicer PINpad
* Nicer font
* Nicer keyboard
* New official bootscreen
* New shortcuts keys (New SMS, battery, Task Manager, soft-reset,...)
* Button 5 mapped to New SMS
* Subfolders in Start menu
* Schap's theme
* Schap's Comm Manager (12 functions)
* Schap's battery indicator
* Schap's Power & Wireless service Manager (shows Bluetooth/Wi-Fi on traybar)
* Schap's Vista look icons
Release notes:
# 28-07: WWE & FRA ROMs updated - Some changes & bug fixes:
* All bugs related to HTC Home should be solved
* Backlight button in HTC Home now works, updated some icons
* New button commands (New SMS, Task Manager,...) fixed in French ROMs
* Send picture/video via MMS should work now on WWE Lite ROM
* Bluetooth DUN added to WWE Lite ROM
* Official Windows Live build
* Error opening GIF images solved
* Some codecs updated
* Some other fixes that I don't remember...
# 30/07: 3G Video patch
MERAVIGLIOSA! Finché non uscirà la rom ufficiale in italiano per htc 9600, questa rimarrà inchiodata sul mio smartphone!
Scarica in wwe: http://rapidshare.com/files/45635293...28-07.exe.html
