NN SO SE SIETE GIà STATI QUA CMQ HO TROVATO UN LINK INTERESSANTE NELLA SEZIONE OVERCLOCK DATO DA CHETTO ( il quale ringrazio!): http://www.cdrinfo.com/tips/plextor_oc.shtml
Solo che nn ho capito cos'è sto sub-channel...
QUALCUNO SA DIRMI QUALCOSA DI +???
Enable SubChannel Data reading in PLEXTOR/CREATIVE/TDK/IOMEGA 12/10/32 CDR-W drives:
If you facing problems when try to read SubChannel Data with your Plextor based recorder there might be a solution for you. All the above drives have 2 jumpers next to the digital audio out. If you jumper them then you drive would recognized as UDMA33 and probably it will start reading SubChannel data. We tried it in our TDK CyClone 121032, which refused previously to read SubChannel data, and worked fine with latest CloneCD (2.8.4.2).
This is the official Plextor answer about jumper the drive:
"...The "Reserved jumper" (2 horizontal pins next to the digital audio out) is used for testing during production. If these jumper pins are shortened, some PC motherboard will work at Ultra DMA-33. But we do not guarantee the working..."
So if you face SubChannel problems please try the above trick and report back results.
