Ho questa nain con queste specifiche:
GA-MA69GM-S2H (Rev. 1.0)
* AMD Athlon™64 / Sempron socket AM2 platform
* Integrated ATI™ Radeon™ X1250-based graphics
* Supports Dual Channel DDR2 800 memory
* Experience revolutionary graphics with the PCI-Express x16 interface
* Integrated SATA 3Gb/s with RAID function
* Features Gigabit LAN and IEEE 1394 connection
* Audio controller from ALC 889A codec and DTS Connect, featuring 106 dB Signal to Noise ratio and supporting for both Blu-ray and HD DVD formats
* Supports Microsoft® Windows Vista™ Premium
* RoHS compliant motherboard for green computing
* Integrated DVI/ HDMI interface with HDCP
Link correlati
# Overview
# Specifiche
# BIOS
# Driver
# Manuale
# FAQ
# CPU supportate
# Tabella Comparativa
# Premi
# Dove acquistare
Specifiche
Processore
* Socket AM2 AMD Athlon™ 64 FX / Athlon™ 64 X2 Dual-Core / Athlon™ 64 / Sempron™
Chipset
* AMD 690G
* ATI SB600
* Super I/O: ITE IT8716
* Realtek RTL 8110
* 8 Channels ALC889A Audio controller
Memoria
* 4 x DDR2 DIMM memory slots (supports up to 16GB memory with Windows 64-bit operating system)
* Supports 1.8V DDRII DIMM
* Supports dual channel DDRII 800 / 667 / 533 / 400 DIMM
Connettori Interni I/O
* 1 x 24-pin ATX power connector
* 1 x 4-pin ATX 12V power connector
* 1 x CD in
* 1 x Chassis Intrusion connector
* 1 x COM
* 1 x CPU fan connector
* 1 x floppy
* 1 x front audio connector
* 1 x front panel connector
* 1 x IDE
* 1 x LPT connector
* 1 x power LED connector
* 1 x SPDIF in/out
* 1 x system fan connector
* 1 x TV out
* 2 x IEEE 1394a
* 3 x USB 2.0/1.1 (support 6 ports)
* 4 x SATA II 3Gb/s
Slot di Espansione
* 1 x PCI Express x 4 slot
* 1 x PCI Express x16
* 2 x PCI
Pannello Posteriore I/O
* 1 x D-Sub
* 1 x DVI-D
* 1 x HDMI port
* 1 x IEEE 1394a
* 1 x RJ45 LAN
* 1 x SPDIF out (optical)
* 4 x USB 2.0
* 6 x audio ports (Line In / Line Out / MIC In / Surround Speaker Out(Rear Speaker Out) / Center/Subwoofer Speaker Out / Side Speaker Out)
* PS/2 (Keyboard/Mouse)
Potenza
* ATX power connector and ATX 12V connector
Fattore di Forma
* microATX
* 244mm x 244mm
Monitoraggio H/W
* CPU fan failure warning
* CPU Smart Fan control
* CPU/System fan speed detect
* CPU/System temperature detection
* CPU/System warning temperature
* System voltage detection
BIOS
* 4 Mbit flash ROM
* Licensed AWARD™ BIOS
* PnP 1.0a, DMI 2.0, SM BIOS 2.3, ACPI 1.0b
Altre Caratteristiche
* @BIOS™
* Download Center
* Q-Flash™
* Xpress™ Install
* Xpress™ BIOS rescue
* Xpress™ Recovery 2
Note
* Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website
* Due to most hardware/software vendors no longer offer support for Win9X/ME. If some vendors still has Win9X/ME drivers available, we will publish on website.
Ho due maxtor sata 150 in raid 0 su win xp prof sp2 sui primi due connettori sata e due maxtor da 200 sata 2 su gli altri due.Questi ultimi o li metto in raid 0, o 1 o jbod o come dischi singoli ,come vorrei metterli, non me li vede ne il controller ne win , avete consigli su come fare ? Da bios non gestisce i canali separati o me li mette in ide o in raid o sata/ahci io ho scelto raid.
