...non mi sembra di vedere elencato squeezelite eppure è funzionante
Forse perché ora non è collegato un dac?
Questo è il risoltato di top e di seguito il comando che mi avevi indicato però questa volta con un dac connesso. (prima senza dac squeezelite non era tra i processi quando davo top.
Last login: Fri Mar 24 11:07:34 2017 from airdimabookair4.station
root@voyage:~# top
top - 11:22:07 up 2 min, 1 user, load average: 0.64, 0.51, 0.21
Tasks: 72 total, 1 running, 71 sleeping, 0 stopped, 0 zombie
%Cpu(s): 1.1 us, 12.6 sy, 0.0 ni, 81.3 id, 0.0 wa, 0.0 hi, 4.9 si, 0.0 st
KiB Mem: 254532 total, 64812 used, 189720 free, 520 buffers
KiB Swap: 0 total, 0 used, 0 free, 38732 cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1045 root -51 0 0 0 0 S 10.5 0.0 0:09.44 irq/12-ehci_hcd
1298 root -51 0 0 0 0 S 3.3 0.0 0:02.93 irq/12-ohci_hcd
3468 root 20 0 2900 1140 840 R 2.2 0.4 0:00.20 top
3 root -2 0 0 0 0 S 1.7 0.0 0:01.79 ksoftirqd/0
2585 root -51 0 0 0 0 S 0.6 0.0 0:00.04 irq/10-eth0
3353 root 20 0 10088 9896 3664 S 0.6 3.9 0:00.91 squeezelite-mc2
1 root 20 0 2196 604 512 S 0.0 0.2 0:04.37 init
2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd
4 root 20 0 0 0 0 S 0.0 0.0 0:00.03 kworker/0:0
5 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0H
6 root 20 0 0 0 0 S 0.0 0.0 0:00.10 kworker/u2:0
7 root rt 0 0 0 0 S 0.0 0.0 0:00.00 posixcputmr/0
8 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kclksetdelayd
9 root -2 0 0 0 0 S 0.0 0.0 0:00.00 rcub/0
10 root 20 0 0 0 0 S 0.0 0.0 0:00.35 rcu_preempt
11 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_sched
12 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_bh
root@voyage:~# ls /etc/rc*.d
/etc/rc0.d:
K01nocatsplash K02ebtables K02resolvconf K06rpcbind K11live
K01voyage-util K02hostapd K02urandom K07hwclock.sh K12halt
K01watchdog K02ifplugd K03inetutils-syslogd K07networking README
K02alsa-utils K02lirc K04sendsigs K08voyage-sync
K02avahi-daemon K02nginx K05umountnfs.sh K09umountfs
K02dnsmasq K02php-fastcgi K06nfs-common K10umountroot
/etc/rc1.d:
K01nocatsplash K02dnsmasq K02nginx README
K01voyage-util K02ebtables K02php-fastcgi S01bootlogs
K01watchdog K02hostapd K03inetutils-syslogd S01killprocs
K02alsa-utils K02ifplugd K06nfs-common S01motd
K02avahi-daemon K02lirc K06rpcbind S02single
/etc/rc2.d:
README S16hostapd S17dnsmasq S18rsync
S01bootlogs S16ifplugd S17lirc S19nocatsplash
S01motd S16inetutils-syslogd S17nginx S19rc.local
S01php-fastcgi S16sudo S17ssh S19voyage-util
S13rpcbind S16wd_keepalive S18avahi-daemon S19watchdog
S14nfs-common S17dbus S18cron
/etc/rc3.d:
/etc/rc4.d:
/etc/rc5.d:
/etc/rc6.d:
K01nocatsplash K02hostapd K03inetutils-syslogd K08voyage-sync
K01voyage-util K02ifplugd K04sendsigs K09umountfs
K01watchdog K02lirc K05umountnfs.sh K10umountroot
K02alsa-utils K02nginx K06nfs-common K11live
K02avahi-daemon K02php-fastcgi K06rpcbind K12reboot
K02dnsmasq K02resolvconf K07hwclock.sh README
K02ebtables K02urandom K07networking
/etc/rcS.d:
README S07mtab.sh S11voyage-sync
S01live-config S08checkfs.sh S12networking
S02hostname.sh S09mountall.sh S13rpcbind
S02mountkernfs.sh S10mountall-bootclean.sh S14nfs-common
S03udev S11ebtables S15mountnfs.sh
S04mountdevsubfs.sh S11pppd-dns S16mountnfs-bootclean.sh
S05hwclock.sh S11procps S17alsa-utils
S06checkroot.sh S11resolvconf S17bootmisc.sh
S07checkroot-bootclean.sh S11udev-mtab S17x11-common
S07kmod S11urandom S18live
root@voyage:~#
c3po mi dice che la versione di squeezelite non è compatibile (sicuramente è una delle tue prime versione perché è tantissimo che non uso la alix)
forse perchè non lo fai partire in automatico con un init.d script.
Nell'elenco c'è NGINX, ma ho visto che qualcuno consiglia di installare lighttpd (senza preoccuparsi di rimuovere NGINX) per l'uso con MPD.
Non so come venga configurato NGINX, ma se è attivo ed in ascolto sulla porta 80 (quella che risponde alle chiamate del browser per default, se non indichi una porta specifica) rischia di andare in conflitto con lighttpd usato allo stesso fine.
Puoi provare a rimuovere tutto manualmente, ma non è più semplice installare VOYAGE da zero? alla fine per far funzionare Squeezelite basta alsa, se tutto va bene risolvi con la sola installazione di falcon.
Non credo ci siano particolari 'ottimizzazioni' in voyage Mpd...
Mi faccio una VM con Voyage e provo Falcon.
Ciao, Marco.
intanto ho provato a fare qualche disastro in autonomia ma non ci riesco eheheh
root@voyage:~# remountrw
root@voyage:~# wget https://raw.githubusercontent.com/ma...aster/setup.pl
--2017-03-24 11:36:04-- https://raw.githubusercontent.com/ma...aster/setup.pl
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.112.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.112.133|:443... connected.
ERROR: The certificate of `raw.githubusercontent.com' is not trusted.
ERROR: The certificate of `raw.githubusercontent.com' hasn't got a known issuer.
root@voyage:~#
Reinstallare Voyage non é propio una passeggiata...
puó rimuovere tutto quello che non gli serve con
apt-get purge nome-pacchetto
tipo
apt-get purge mpd mpc
ecc
in effetti la vedo meglio come soluzione :-)
quali pacchetti mi consigliate di eliminare?
ps falcon non si vuole installare
edit
ho provato così, l'ho fatta troppo semplice??
root@voyage:~# apt-get purge nginx
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package 'nginx' is not installed, so not removed
root@voyage:~# apt-get purge squeezelite
E: Unable to locate package squeezelite
root@voyage:~#
Ultima modifica di DacPassion : 24-03-2017 a 12:54
Ciao, Marco.
Ciao, Marco.
io ho copiato il link, non è questo?
ho fatto tasto destro copia link e poi ho incollato
--2017-03-24 12:00:11-- https://raw.githubusercontent.com/ma...aster/setup.pl
root@voyage:~#
