Originariamente inviato da
blueray
No, deve essere in quel modo se no squeezelite non parte.
Non credo Federico.
questo con il tuo comando
codice:
19:08:38.578380] stream_init:290 init stream
[19:08:38.578459] stream_init:291 streambuf size: 2097152
[19:08:38.579073] output_init_alsa:817 init output
[19:08:38.579098] output_init_alsa:846 requested alsa_buffer: 0 alsa_period: 20 format: p mmap: 1
[19:08:38.579114] output_init_common:346 outputbuf size: 3528000
[19:08:38.579148] output_init_common:370 idle timeout: 0
[19:08:38.581405] output_init_common:410 supported rates: 384000 352800 192000 176400 96000 88200 48000 44100
[19:08:38.582698] output_init_alsa:862 memory locked
[19:08:38.582822] output_thread:638 open output device: front:CARD=J20,DEV=0
[19:08:38.582825] output_init_alsa:885 set output sched fifo rt: 45
[19:08:38.583158] alsa_open:355 opening device at: 44100
[19:08:38.583404] alsa_open:406 opened device front:CARD=J20,DEV=0 using format: S32_LE sample rate: 44100 mmap: 1
[19:08:38.583424] alsa_open:485 buffer: 0 period: 20 -> buffer size: 160 period size: 8
[19:08:38.583936] decode_init:129 init decode, include codecs: exclude codecs:
[19:08:38.583980] register_dsd:624 using dsd to decode dsf,dff
[19:08:38.594173] load_ff:621 loaded libavcodec.so.56 (56.1.0)
[19:08:38.594200] load_ff:638 loaded libavformat.so.56 (56.1.0)
[19:08:38.594209] load_ff:652 loaded libavutil.so.54 (54.3.0)
[19:08:38.595524] register_ff:731 using ffmpeg to decode alc
[19:08:38.595544] register_ff:715 using ffmpeg to decode wma,wmap,wmal
[19:08:38.595665] load_faad:610 loaded libfaad.so.2
[19:08:38.595676] register_faad:640 using faad to decode aac
[19:08:38.595765] load_vorbis:300 loaded libvorbisfile.so.3
[19:08:38.595776] register_vorbis:329 using vorbis to decode ogg
[19:08:38.595934] load_flac:258 loaded libFLAC.so.8
[19:08:38.595945] register_flac:286 using flac to decode flc
[19:08:38.595951] register_pcm:392 using pcm to decode aif,pcm
[19:08:38.596037] load_mad:383 loaded libmad.so.0
[19:08:38.596050] register_mad:412 using mad to decode mp3
[19:08:38.596114] discover_server:756 sending discovery
[19:08:38.596933] discover_server:767 got response from: 192.168.178.21:3483
[19:08:38.596954] slimproto:849 connecting to 192.168.178.21:3483
[19:08:38.597661] slimproto:882 connected
[19:08:38.597673] sendHELO:124 mac: 50:e5:49:cc:b4:29
[19:08:38.597679] sendHELO:126 cap: Model=squeezelite,AccuratePlayPoints=1,HasDigitalOut=1,HasPolarityInversion=1,Firmware=v1.8,ModelName=SqueezeLite,MaxSampleRate=384000,dsf,dff,alc,wma,wmap,wmal,aac,ogg,flc,aif,pcm,mp3
[19:08:38.652315] process:494 strm
[19:08:38.652327] process_strm:256 strm command q
[19:08:38.652334] decode_flush:190 decode flush
[19:08:38.652339] output_flush:423 flush output buffer
[19:08:38.652346] sendSTAT:171 STAT: STMf
[19:08:38.652400] process:494 strm
[19:08:38.652409] process_strm:256 strm command q
[19:08:38.652414] decode_flush:190 decode flush
[19:08:38.652419] output_flush:423 flush output buffer
[19:08:38.652425] sendSTAT:171 STAT: STMf
[19:08:38.652456] process:494 setd
[19:08:38.652474] process:494 setd
[19:08:38.652507] process:494 aude
[19:08:38.652522] process_aude:395 enable spdif: 1 dac: 1
[19:08:38.652571] process:494 audg
[19:08:38.652580] process_audg:413 audg gainL: 65536 gainR: 65536 adjust: 0
[19:08:38.652588] set_volume:246 setting internal gain left: 65536 right: 65536
[19:08:40.098551] process:494 strm
[19:08:40.098564] process_strm:256 strm command t
[19:08:40.098570] sendSTAT:171 STAT: STMt
[19:08:45.098448] process:494 strm
[19:08:45.098463] process_strm:256 strm command t
[19:08:45.098470] sendSTAT:171 STAT: STMt
[19:08:50.098834] process:494 strm
[19:08:50.098849] process_strm:256 strm command t
[19:08:50.098857] sendSTAT:171 STAT: STMt
[19:08:52.180664] slimproto_stop:920 slimproto stop
[19:08:52.280757] decode_close:175 close decode
[19:08:52.303140] stream_close:322 close stream
[19:08:52.386616] output_close_alsa:890 close output
Questo con quello giusto:
codice:
[[19:12:15.267174] stream_init:290 init stream
[19:12:15.267259] stream_init:291 streambuf size: 2097152
[19:12:15.267845] output_init_alsa:817 init output
[19:12:15.267869] output_init_alsa:846 requested alsa_buffer: 20 alsa_period: 3 format: 24 mmap: 1
[19:12:15.267881] output_init_common:346 outputbuf size: 3528000
[19:12:15.267902] output_init_common:370 idle timeout: 0
[19:12:15.270124] output_init_common:410 supported rates: 384000 352800 192000 176400 96000 88200 48000 44100
[19:12:15.271424] output_init_alsa:862 memory locked
[19:12:15.271533] output_thread:638 open output device: front:CARD=J20,DEV=0
[19:12:15.271535] output_init_alsa:885 set output sched fifo rt: 45
[19:12:15.271844] alsa_open:355 opening device at: 44100
[19:12:15.272097] alsa_open:411 unable to open audio device requested format: S24_LE
[19:12:15.272110] decode_init:129 init decode, include codecs: exclude codecs:
[19:12:15.272154] register_dsd:624 using dsd to decode dsf,dff
[19:12:15.281812] load_ff:621 loaded libavcodec.so.56 (56.1.0)
[19:12:15.281840] load_ff:638 loaded libavformat.so.56 (56.1.0)
[19:12:15.281849] load_ff:652 loaded libavutil.so.54 (54.3.0)
[19:12:15.283107] register_ff:731 using ffmpeg to decode alc
[19:12:15.283122] register_ff:715 using ffmpeg to decode wma,wmap,wmal
[19:12:15.283235] load_faad:610 loaded libfaad.so.2
[19:12:15.283246] register_faad:640 using faad to decode aac
[19:12:15.283333] load_vorbis:300 loaded libvorbisfile.so.3
[19:12:15.283344] register_vorbis:329 using vorbis to decode ogg
[19:12:15.283482] load_flac:258 loaded libFLAC.so.8
[19:12:15.283493] register_flac:286 using flac to decode flc
[19:12:15.283501] register_pcm:392 using pcm to decode aif,pcm
[19:12:15.283578] load_mad:383 loaded libmad.so.0
[19:12:15.283588] register_mad:412 using mad to decode mp3
[19:12:15.283653] discover_server:756 sending discovery
[19:12:15.284538] discover_server:767 got response from: 192.168.178.21:3483
[19:12:15.284558] slimproto:849 connecting to 192.168.178.21:3483
[19:12:15.285275] slimproto:882 connected
[19:12:15.285286] sendHELO:124 mac: 50:e5:49:cc:b4:29
[19:12:15.285293] sendHELO:126 cap: Model=squeezelite,AccuratePlayPoints=1,HasDigitalOut=1,HasPolarityInversion=1,Firmware=v1.8,ModelName=SqueezeLite,MaxSampleRate=384000,dsf,dff,alc,wma,wmap,wmal,aac,ogg,flc,aif,pcm,mp3
[19:12:15.337493] process:494 strm
[19:12:15.337505] process_strm:256 strm command q
[19:12:15.337511] decode_flush:190 decode flush
[19:12:15.337516] output_flush:423 flush output buffer
[19:12:15.337522] sendSTAT:171 STAT: STMf
[19:12:15.337583] process:494 strm
[19:12:15.337591] process_strm:256 strm command q
[19:12:15.337596] decode_flush:190 decode flush
[19:12:15.337602] output_flush:423 flush output buffer
[19:12:15.337607] sendSTAT:171 STAT: STMf
[19:12:15.337646] process:494 setd
[19:12:15.337666] process:494 setd
[19:12:15.337740] process:494 aude
[19:12:15.337748] process_aude:395 enable spdif: 1 dac: 1
[19:12:15.337815] process:494 audg
[19:12:15.337823] process_audg:413 audg gainL: 65536 gainR: 65536 adjust: 0
[19:12:15.337829] set_volume:246 setting internal gain left: 65536 right: 65536
[19:12:20.101210] process:494 strm
[19:12:20.101221] process_strm:256 strm command t
[19:12:20.101227] sendSTAT:171 STAT: STMt
[19:12:20.272114] output_thread:638 open output device: front:CARD=J20,DEV=0
[19:12:20.272151] alsa_open:355 opening device at: 44100
[19:12:20.272371] alsa_open:411 unable to open audio device requested format: S24_LE
[19:12:25.101606] process:494 strm
[19:12:25.101618] process_strm:256 strm command t
[19:12:25.101623] sendSTAT:171 STAT: STMt
[19:12:25.272382] output_thread:638 open output device: front:CARD=J20,DEV=0
[19:12:25.272406] alsa_open:355 opening device at: 44100
[19:12:25.272578] alsa_open:411 unable to open audio device requested format: S24_LE
[19:12:28.869250] slimproto_stop:920 slimproto stop
Il perché non funziona non saprei dirti (neanche a me funziona)...non riesce ad aprire il device con i 24 bit
forse qua ci puó aiutare Paolo
