E' il momento di Leia, ovvero 'LA' library manager
Pagina 18 di 47
... 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 ... ultimo
Visualizzazione dei risultati da 171 a 180 su 467
  1. #171
    tebibyte L'avatar di bigtube
    May 2012
    cagliari
    Ho questo:
    ==== in MetaplayerController ===
    ==== in OsDriveListController Controller ====
    ==== in Login/stored () ====
    2017-12-14 09:30:19.222 WARN 1796 --- [nio-8080-exec-2] java.util.prefs
    : Could not open/create prefs root node Software\JavaSoft\Pref
    s at root 0x80000002. Windows RegCreateKeyEx(...) returned error code 5.
    ==== credentials false true ==
    Root element :root
    ==== in OsDriveList.getDriveList ====
    ==== in Drive.constructor ====
    ==== in OsDirectory init ==== path: C:\
    ==== in OsDirectory init ==== path: D:\
    ==== in OsDirectory init ==== path: E:\
    ==== in OsDirectory init ==== path: F:\
    ==== in OsDirectory init ==== path: G:\
    ==== in directory init ==== status: does not exists
    ==== in OsDirectory init ==== path: H:\
    ==== in OsDirectory init ==== path: J:\
    2017-12-14 09:30:21.191 INFO 1796 --- [nio-8080-exec-1] org.jaudiotagger.audio.
    flac : D:\DAC A1.flac BlockType:STREAMINFO DataLength:34 isLastBloc
    k:false
    flac : D:\DAC A1.flac BlockType:SEEKTABLE DataLength:360 isLastBloc
    k:false
    flac : D:\DAC A1.flac BlockType:VORBIS_COMMENT DataLength:40 isLast
    Block:false
    flac : D:\DAC A1.flac BlockType:PADDING DataLength:8192 isLastBlock
    :true
    2017-12-14 09:30:21.206 INFO 1796 --- [nio-8080-exec-1] org.jaudiotagger.audio.
    flac : D:\DAC A2.flac BlockType:STREAMINFO DataLength:34 isLastBloc
    k:false
    2017-12-14 09:30:21.222 INFO 1796 --- [nio-8080-exec-1] org.jaudiotagger.audio.
    flac : D:\DAC A2.flac BlockType:SEEKTABLE DataLength:360 isLastBloc
    k:false
    flac : D:\DAC A2.flac BlockType:VORBIS_COMMENT DataLength:40 isLast
    Block:false
    flac : D:\DAC A2.flac BlockType:PADDING DataLength:8192 isLastBlock
    :true
    2017-12-14 09:30:21.362 WARN 1796 --- [nio-8080-exec-1] .w.s.m.s.DefaultHandler
    ExceptionResolver : Failed to write HTTP message: org.springframework.http.conve
    rter.HttpMessageNotWritableException: Could not write JSON: org.jaudiotagger.tag
    .id3.TyerTdatAggregatedFrame cannot be cast to org.jaudiotagger.tag.id3.Abstract
    ID3v2Frame; nested exception is com.fasterxml.jackson.databind.JsonMappingExcept
    ion: org.jaudiotagger.tag.id3.TyerTdatAggregatedFrame cannot be cast to org.jaud
    iotagger.tag.id3.AbstractID3v2Frame (through reference chain: org.mc2.leia.servi
    ce.model.OsDriveList["driveList"]->java.util.ArrayList[1]->org.mc2.leia.service.
    model.Drive["root"]->org.mc2.leia.service.model.Directory["directoryAlbum"])
    2017-12-14 09:30:21.394 ERROR 1796 --- [nio-8080-exec-1] o.a.c.c.C.[.[.[/].[disp
    atcherServlet] : Servlet.service() for servlet [dispatcherServlet] threw exce
    ption
    java.lang.NoSuchMethodError: com.fasterxml.jackson.databind.ObjectWriter.forType
    (Lcom/fasterxml/jackson/databind/JavaTypeLcom/fasterxml/jackson/databind/Objec
    tWriter;
    at org.springframework.http.converter.json.AbstractJackson2HttpMessageCo
    nverter.writeInternal(AbstractJackson2HttpMessageConverter.java:279) ~[spring-we
    b-4.3.13.RELEASE.jar!/:4.3.13.RELEASE]
    at org.springframework.http.converter.AbstractGenericHttpMessageConverte
    r.write(AbstractGenericHttpMessageConverter.java:106) ~[spring-web-4.3.13.RELEAS
    at org.springframework.web.servlet.mvc.method.annotation.AbstractMessage
    ConverterMethodProcessor.writeWithMessageConverters(AbstractMessageConverterMeth
    odProcessor.java:231) ~[spring-webmvc-4.3.13.RELEASE.jar!/:4.3.13.RELEASE]
    at org.springframework.web.servlet.mvc.method.annotation.HttpEntityMetho
    dProcessor.handleReturnValue(HttpEntityMethodProcessor.java:203) ~[spring-webmvc
    at org.springframework.web.method.support.HandlerMethodReturnValueHandle
    rComposite.handleReturnValue(HandlerMethodReturnValueHandlerComposite.java:81) ~
    [spring-web-4.3.13.RELEASE.jar!/:4.3.13.RELEASE]
    at org.springframework.web.servlet.mvc.method.annotation.ServletInvocabl
    eHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:113) ~[spring-
    at org.springframework.web.servlet.mvc.method.annotation.RequestMappingH
    andlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:827) ~[sprin
    andlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:738) ~[spring-web
    at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapt
    er.handle(AbstractHandlerMethodAdapter.java:85) ~[spring-webmvc-4.3.13.RELEASE.j
    at org.springframework.web.servlet.DispatcherServlet.doDispatch(Dispatch
    erServlet.java:967) ~[spring-webmvc-4.3.13.RELEASE.jar!/:4.3.13.RELEASE]
    at org.springframework.web.servlet.DispatcherServlet.doService(Dispatche
    rServlet.java:901) ~[spring-webmvc-4.3.13.RELEASE.jar!/:4.3.13.RELEASE]
    at org.springframework.web.servlet.FrameworkServlet.processRequest(Frame
    workServlet.java:970) ~[spring-webmvc-4.3.13.RELEASE.jar!/:4.3.13.RELEASE]
    at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServl
    et.java:861) ~[spring-webmvc-4.3.13.RELEASE.jar!/:4.3.13.RELEASE]
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:635) ~[tomcat
    -embed-core-8.5.23.jar!/:8.5.23]
    at org.springframework.web.servlet.FrameworkServlet.service(FrameworkSer
    vlet.java:846) ~[spring-webmvc-4.3.13.RELEASE.jar!/:4.3.13.RELEASE]
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:742) ~[tomcat
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Appl
    icationFilterChain.java:231) ~[tomcat-embed-core-8.5.23.jar!/:8.5.23]
    at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationF
    ilterChain.java:166) ~[tomcat-embed-core-8.5.23.jar!/:8.5.23]
    at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDisp
    atcher.java:728) [tomcat-embed-core-8.5.23.jar!/:8.5.23]
    at org.apache.catalina.core.ApplicationDispatcher.processRequest(Applica
  2. #172
    Aug 2011
    Ma il file XML , non penso centri, com´é? lo riesci a postare?
  3. #173
    May 2012
    cagliari
    COSI'
    codice:
    <?xml version="1.0" encoding="UTF-8"?>
    <root>
        <leia>
            <server>
                <local>
                    <players>
                        <squeezebox-player id= "1" >
                                <name>Giovanni</name>
                                <server>192.168.1.21</server>
                                <port>9000</port>
                                <mac>2c:27:d7:1d:e2:b4</mac>
                                <statusQueryPort>9090</statusQueryPort>
                                <drives>
                                <drive key="J:" value="/media/muzak"/>
                               </drives>
                           </squeezebox-player>
                         </players>
                       </local>
                  </server>
              </leia>
            </root>
    Ultima modifica di bigtube : 14-12-2017 a 12:04
  4. #174
    Aug 2011
    A parte quello spazio tra mac e Status, sembra tutto ok....provala a togliere quella riga vuota..., ma il problema protrebbe essere legato a winserver...
  5. #175
    Jan 2013
    Ho questo:
    ID3v2Frame
    sei incappato in un errore della libreria che utilizzo per i TAG. Ma prima non usciva? Strano.
    Devo farne il debug e capire perchè.
    Il file D:\DAC A2.flac o quello immediatamente successivo in ordine alfabetico nella directory ha qualcosa di particolare? Riesci a farmene avere una copia (solo a scopo di debug, poi la cancello).
    Ciao, Marco.
  6. #176
    May 2012
    cagliari
    @Filippo...piccolo errore nel trasferire la copia....nel file config. non c'è spazio....
    Marco
    il file D:\DAC A2.flac è appunto un flac di 69Kb......e potrei anche liquidarlo senza problemi....dimmi tu?
  7. #177
    Jan 2013
    Marco
    mandamelo, per favore, così capisco dove si genera l'errore, poi prova ad eliminarlo dalla cartella (basta metterlo inunsa sottodir) e vediamo se va.
    Ciao, Marco.
  8. #178
    Jan 2013
    Non ho capito a cosa sia dovuto il problema di Giovanni, quindi non posso risolverlo.
    Intanto al solito link ho caricato una nuova versione che 'scarta' i files, directory e drive su cui incontra problemi, ma riportando comunque quelli validi (se ce ne sono). In versione definitiva ci sarà qualcosa a video che segnalerà il problema, per adesso bisogna guardare nel log a terminale.
    @Giovanni, dovrebbe segnalare esattamente l'elemento che provoca l'errore (che non comparirà) se lo individui, segnalamelo, così posso provare a risolvere il problema specifico.
    ATTENZIONE se è un file tra altri in una directory, l'immagine dell'album sarà sbagliata, mancherà una traccia, quindi non potrà funzionare il riconoscimento in MB.
    Ciao, Marco.
  9. #179
    Aug 2011
    Nuova versione caricata nel solito posto.
    Risolve il problema segnalato da filippo con i files Flac (sbagliava a leggere la durata), adesso dovrebbe funzionare correttamente.
    Si adesso é OK!!
    Marco che dici c'é/ci sará qualche modo per sfruttare i metadati? per creare tipo playlist?
    Comunque in questa schermata a me taglia a destra..
    PS: non capisco la barra di scorrimento sotto
  10. #180
    Jan 2013
    Si adesso é OK!!
    bene!
    Dici in automatico? Come se la cava con i servizi on line?
    E' un carusell con scorimento (freccette a sx e dx o i puntini sotto) per 'centrarlo', dovrei farlo partire dalla slide n=m/2 di m (es. 3 di 7) e non dalla 1, nella prossima release la metto così e vediamo se ti piace di più.
    Non capisco nemmeno io a cosa ti riferisci... quale barra e sotto a cosa?
    Ciao, Marco.
Pagina 18 di 47
