E' il momento di Leia, ovvero 'LA' library manager
Pagina 9 di 47
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 ... ultimo
Visualizzazione dei risultati da 81 a 90 su 467
  1. #81
    Jan 2013
    questo quando faccio una ricerca
    codice:
    == CatalogSearch. mapStateToProps {login: {…}, window: {…}, metaplayer: {…}, local: {…}, qobuz: {…},*…}
    qobuz\search.jsx:28 == CatalogSearch.constructor. ==  {query: undefined, selectedArtist: {…}, selectedAlbum: {…}, selectedTrack: {…}, isFetching: false,*…}
    qobuz\search.jsx:100 == CatalogSearch.render. ==  {query: undefined, selectedArtist: {…}, selectedAlbum: {…}, selectedTrack: {…}, isFetching: false,*…}
    qobuz\search.jsx:207 == SearchBar.render. ==  {query: undefined, onUserInput: ƒ, doSearch: ƒ}
    common\components\BodyR2.js:54 == BodyR2. mapStateToProps {login: {…}, window: {…}, metaplayer: {…}, local: {…}, qobuz: {…},*…}
    common\components\BodyR2.js:28 == BodyR2. render - heigth  700
    qobuz\components\catalogSideBar.js:78 == Catalog. mapStateToProps {login: {…}, window: {…}, metaplayer: {…}, local: {…}, qobuz: {…},*…}
    qobuz\search.jsx:190 == SearchBar.handleChange. ==  {query: undefined, onUserInput: ƒ, doSearch: ƒ}
    qobuz\search.jsx:85 == CatalogSearch.handleUserImput. ==  Marialy Pacheco
    qobuz\search.jsx:90 == CatalogSearch.doSearch. ==  Marialy Pacheco
    main\components\SinglePage.js:133 == SinglePage. mapStateToProps {login: {…}, window: {…}, metaplayer: {…}, local: {…}, qobuz: {…},*…}
    main\components\NavBar.js:142 == NavBar. mapStateToProps {login: {…}, window: {…}, metaplayer: {…}, local: {…}, qobuz: {…},*…}
    main\components\ModalLogin.js:206 == Login. mapStateToProps {login: {…}, window: {…}, metaplayer: {…}, local: {…}, qobuz: {…},*…}
    metaplayer\components\metaplayer.js:223 == Metaplayer. mapStateToProps {login: {…}, window: {…}, metaplayer: {…}, local: {…}, qobuz: {…},*…}
    metaplayer\components\metaplayer.js:238 == Metaplayer. mapStateToProps metaplayer {isFetching: true}
    qobuz\search.jsx:230 == CatalogSearch. mapStateToProps {login: {…}, window: {…}, metaplayer: {…}, local: {…}, qobuz: {…},*…}
    ..\node_modules\redux-logger\dist\redux-logger.js:1  action CLEAR_CATALOG @ 19:10:45.379
    ..\node_modules\redux-logger\dist\redux-logger.js:1  prev state {login: {…}, window: {…}, metaplayer: {…}, local: {…}, qobuz: {…},*…}
    ..\node_modules\redux-logger\dist\redux-logger.js:1  action     {type: "CLEAR_CATALOG"}
    ..\node_modules\redux-logger\dist\redux-logger.js:1  next state {login: {…}, window: {…}, metaplayer: {…}, local: {…}, qobuz: {…},*…}
    ..\node_modules\redux-logger\dist\redux-logger.js:1  action CLEAR_SELECTED @ 19:10:45.383
    ..\node_modules\redux-logger\dist\redux-logger.js:1  action     {type: "CLEAR_SELECTED"}
    ..\node_modules\redux-logger\dist\redux-logger.js:1  action REQUEST_CATALOG @ 19:10:45.387
    ..\node_modules\redux-logger\dist\redux-logger.js:1  action     {type: "REQUEST_CATALOG", query: "Marialy Pacheco", offset: 0, limit: 50}
    qobuz\actions\catalogActions.js:51  *** fetchCatalog   fetch ***  Marialy Pacheco 0 50
    qobuz\search.jsx:100 == CatalogSearch.render. ==  {query: "Marialy Pacheco", selectedArtist: {…}, selectedAlbum: {…}, selectedTrack: {…}, isFetching: true,*…}
    qobuz\search.jsx:207 == SearchBar.render. ==  {query: "Marialy Pacheco", onUserInput: ƒ, doSearch: ƒ}
    search:1 GET http://192.168.1.110:8080/qobuz/cata...set=0&limit=50 net::ERR_CONNECTION_TIMED_OUT
    common\components\FetchJSON.js:48 FETCH ERROR: TypeError: Failed to fetch
    localhost/:1 Uncaught (in promise) TypeError: Failed to fetch
    Promise rejected (async)
    (anonymous) @ qobuz\actions\catalogActions.js:53
    (anonymous) @ ..\node_modules\redux-thunk\lib\index.js:11
    value @ qobuz\search.jsx:94
    value @ qobuz\search.jsx:195
    r @ ..\node_modules\react-dom\lib\ReactErrorUtils.js:26
    o @ ..\node_modules\react-dom\lib\EventPluginUtils.js:85
    s @ ..\node_modules\react-dom\lib\EventPluginUtils.js:108
    d @ ..\node_modules\react-dom\lib\EventPluginHub.js:43
    m @ ..\node_modules\react-dom\lib\EventPluginHub.js:54
    r @ ..\node_modules\react-dom\lib\forEachAccumulated.js:24
    processEventQueue @ ..\node_modules\react-dom\lib\EventPluginHub.js:257
    r @ ..\node_modules\react-dom\lib\ReactEventEmitterMixin.js:17
    handleTopLevel @ ..\node_modules\react-dom\lib\ReactEventEmitterMixin.js:28
    i @ ..\node_modules\react-dom\lib\ReactEventListener.js:72
    perform @ ..\node_modules\react-dom\lib\Transaction.js:140
    batchedUpdates @ ..\node_modules\react-dom\lib\ReactDefaultBatchingStrategy.js:62
    i @ ..\node_modules\react-dom\lib\ReactUpdates.js:97
    dispatchEvent @ ..\node_modules\react-dom\lib\ReactEventListener.js:147
    Ma hai sacricato la nuuova versione? continua a cercare sul mio indirizzo IP...
    Ciao, Marco.
  2. #82
    Aug 2011
    Ah ecco!!! e dove l hai postata?
  3. #83
    Jan 2013
    Solito posto. v. https://www.nexthardware.com/forum/p...tml#post983318
    Ciao, Marco.
  4. #84
    Jan 2013
    Non è il problema dell’indirizzo ip?
    ottimo occhio!
    Ciao, Marco.
  5. #85
    Aug 2011
    Sicuro? perché ottengo la medesima cosa
    codice:
    ..\node_modules\redux-logger\dist\redux-logger.js:1  action REQUEST_CATALOG @ 19:44:25.508
    ..\node_modules\redux-logger\dist\redux-logger.js:1  action     {type: "REQUEST_CATALOG", query: "cecilia bartoli", offset: 0, limit: 50}
    qobuz\actions\catalogActions.js:51  *** fetchCatalog   fetch ***  cecilia bartoli 0 50
    qobuz\search.jsx:100 == CatalogSearch.render. ==  {query: "cecilia bartoli", selectedArtist: {…}, selectedAlbum: {…}, selectedTrack: {…}, isFetching: true,*…}
    qobuz\search.jsx:207 == SearchBar.render. ==  {query: "cecilia bartoli", onUserInput: ƒ, doSearch: ƒ}
    search:1 GET http://192.168.1.110:8080/qobuz/catalog/search?query=cecilia%20bartoli&offset=0&limit=50 net::ERR_CONNECTION_TIMED_OUT
  6. #86
    tebibyte L'avatar di bigtube
    May 2012
    cagliari
    Propio Nisba o vedi quello che ha postato Filippo? Che Browser? p.s. prova ad usare l'IP invece di localhost, non dovrebbe essere ma...
    uso Firefox
    nisba anche con l'IP del server
  7. #87
    Jan 2013
    uso Firefox
    stessa domanda anche a te: hai sacricato la nuova versione o usi sempre quella di ieri?
    In ogni caso, se non vedi nulla il problema è diverso.
    nel terminale vedi comparire qualcosa che termina con ...Application started?
    Ciao, Marco.
  8. #88
    Aug 2011
    Qualcosa si é mosso all´improvviso, senza che io abbia fatto niente...
    ma mi ha fatto l´analise di tutte le unitá? io avevo messo solo d/musica
  9. #89
    May 2012
    cagliari
    e dov'è quella aggiornata?
    ne ho il sospetto....non vedo un beneamato.....
    il terminale lo vedo per un istante....non posso leggerlo
  10. #90
    Aug 2011
    al vecchio post https://www.nexthardware.com/forum/p...tml#post983318
    per il terminale:
    vai nella cartella>scrivi nella barra degli indirizzi cmd>invio
    e poi digiti
    leia-service.bat > invio
Pagina 9 di 47
