Ripulire voyage mpd da vecchiume e installare falcon HELP
Pagina 4 di 21
1 2 3 4 5 6 7 8 9 10 11 12 13 14 ... ultimo
Visualizzazione dei risultati da 31 a 40 su 206
  1. #31
    Jul 2014
    root@voyage:~# rm setup.*
    rm: cannot remove `setup.*': No such file or directory
    root@voyage:~#
  2. #32
    Jan 2013
    root@voyage:~#
    ? ( servono almeno 3 caratteri per postare...)
    Ciao, Marco.
  3. #33
    Jul 2014
    avevo errato ora sta "macinando" ma vedo che da molti errori
  4. #34
    Jul 2014
    *** INSTALL REPORT ****************************************************
    2017/03/24 22:50:19 Status::new line: 44 RESULT: Installer started ad 2017/03/24 22:50:19 in DETAILS mode
    2017/03/24 22:50:19 Linux:istro::prepare line: 84 DETAILS: directory:/var/www created
    2017/03/24 22:50:19 Linux:istro::prepare line: 84 DETAILS: directory:/var/www/backupFalcon created
    2017/03/24 22:50:19 Linux:istro::prepare line: 84 DETAILS: directory:/var/www/backupFalcon/before created
    2017/03/24 22:50:38 Linux:ebian:istro::prepare line: 96 DETAILS: package: liburi-perl installed
    2017/03/24 22:51:00 Linux:ebian:istro::prepare line: 96 DETAILS: package: libcgi-pm-perl installed
    2017/03/24 22:51:03 Linux:ebian:istro::prepare line: 96 DETAILS: package: alsa-utils installed
    2017/03/24 22:51:03 Installer::install line: 243 INFO: environment prepared
    2017/03/24 22:51:06 Linux::Falcon::install line: 89 DETAILS: falcon code downloaded
    2017/03/24 22:51:32 Linux::Falcon::install line: 89 DETAILS: falcon code installed
    2017/03/24 22:51:32 Installer::install line: 243 INFO: falcon code installed
    2017/03/24 22:51:32 Linux:ebian::Squeezelite::upgrade line: 188 DETAILS: squeezelite-R2 saved in backup and removed
    2017/03/24 22:51:34 Linux:ebian::Squeezelite::upgrade line: 188 DETAILS: squeezelite-R2 installed
    2017/03/24 22:51:35 Linux:ebian::Squeezelite::upgrade line: 188 DETAILS: squeezelite-R2 autostart configured
    2017/03/24 22:51:35 Installer::install line: 243 INFO: squeezelite-R2 installed
    2017/03/24 22:52:14 Linux:ebian::Apache2::install line: 89 DETAILS: apache2 installed
    2017/03/24 22:52:14 Linux:ebian::Apache2::install line: 89 DETAILS: apache2 configured
    2017/03/24 22:52:14 Linux:ebian::Apache2::install line: 89 DETAILS: apache2 service started
    2017/03/24 22:52:14 Installer::install line: 243 INFO: webserver installed
    2017/03/24 22:52:14 Installer::install line: 243 RESULT: falcon correctly installed!
    STATUS : RESULT
    MESSAGE: falcon correctly installed!
    ** CLEANUP ************************************************************
    Info: Installer moved to /var/www/falcon/falcon/src/Installer
    * END *****************************************************************
    root@voyage:~#
  5. #35
    Jan 2013
    sicuro siano errori? molti comandi mandano furi sbardellate di log (..che secondo i linuxiani sarebbero da leggere attentamente...), io ho cercato di riassumere tutto alla fine, vedi cosa ti dice.
    Ciao, Marco.
  6. #36
    Jan 2013
    STATUS : RESULT
    root@voyage:~#
    Perfetto, almeno ha installato, adesso vediamo se va...
    p.s.
    C'era già installato anche apache2...
    p.p.s.
    Belle le faccine sorridenti, se c'è un errore diventeranno tristi?
    Ciao, Marco.
  7. #37
    Jan 2013
    vai su un browser qualsiasi e richiama l'indirizzo IP, esce qualcosa?
    Ciao, Marco.
  8. #38
    Jul 2014
    faccio un reboot? e provo come?
  9. #39
    Jul 2014
    niente mi esce la solita pagina di voyage
  10. #40
    Jan 2013
    avevi cancellato la directory /var/www ?
    Ciao, Marco.
Pagina 4 di 21
