Ripulire voyage mpd da vecchiume e installare falcon HELP
Pagina 2 di 21
1 2 3 4 5 6 7 8 9 10 11 12 ... ultimo
Visualizzazione dei risultati da 11 a 20 su 206
    Jul 2014
    ok se ti va proviamo, al massimo butto tutto nel cestino :-)
    sono andato con il comando
    root@voyage:/var/www# apt-get remove nfs-common nginx
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    Package 'nginx' is not installed, so not removed
    The following packages were automatically installed and are no longer required:
    libao-common libao4 libasyncns0 libaudiofile1 libavahi-glib1 libavcodec53
    libavformat53 libavutil51 libcdio-cdda1 libcdio-paranoia1 libcdio13
    libconfig++9 libdirac-encoder0 libfaad2 libffado2 libflac8
    libglibmm-2.4-1c2a libgsm1 libice6 libid3tag0 libiec61883-0 libiso9660-8
    libjack-jackd2-0 libjson0 libmad0 libmikmod2 libmms0 libmodplug1 libmp3lame0
    libmpcdec6 libmpg123-0 libogg0 libopenjpeg2 liborc-0.4-0 libpulse0
    libraw1394-11 libresid-builder0c2a libschroedinger-1.0-0 libshout3
    libsidplay2 libsidutils0 libsm6 libsndfile1 libspeex1 libsystemd-daemon0
    libtheora0 libva1 libvorbis0a libvorbisenc2 libvorbisfile3 libvpx1
    libwavpack1 libx11-6 libx11-data libx11-xcb1 libx264-123 libxau6 libxcb1
    libxdmcp6 libxext6 libxi6 libxml++2.6-2 libxtst6 libxvidcore4 libyajl2
    x11-common
    Use 'apt-get autoremove' to remove them.
    The following packages will be REMOVED:
    nfs-common
    0 upgraded, 0 newly installed, 1 to remove and 99 not upgraded.
    After this operation, 678 kB disk space will be freed.
    Do you want to continue [Y/n]? y
    perl: warning: Setting locale failed.
    perl: warning: Please check that your locale settings:
    LANGUAGE = (unset),
    LC_ALL = (unset),
    LANG = "it_IT.UTF-8"
    are supported and installed on your system.
    perl: warning: Falling back to the standard locale ("C").
    locale: Cannot set LC_CTYPE to default locale: No such file or directory
    locale: Cannot set LC_MESSAGES to default locale: No such file or directory
    locale: Cannot set LC_ALL to default locale: No such file or directory
    (Reading database ... 16767 files and directories currently installed.)
    Removing nfs-common ...
    [ ok ] Stopping NFS common utilities: idmapd statd.
    Jan 2013
    x11-common
    nfs-common
    LANGUAGE = (unset),
    LC_ALL = (unset),
    ah,io non ho problemi, massimo riformatti la scheda.
    questo è andato a buon fine.
    Ciao, Marco.
    Jan 2013
    Ciao, Marco.
    Jul 2014
    sempre lo stesso
    root@voyage:~# wget https://github.com/marcoc1712/instal...1.0.1/setup.pl
    --2017-03-24 21:48:45-- https://github.com/marcoc1712/instal...1.0.1/setup.pl
    Resolving github.com (github.com)... 192.30.253.112, 192.30.253.113
    Connecting to github.com (github.com)|192.30.253.112|:443... connected.
    ERROR: The certificate of `github.com' is not trusted.
    ERROR: The certificate of `github.com' hasn't got a known issuer.
    root@voyage:~#
  5. #15
    Jul 2014
    edit - messaggio doppio
  6. #16
    Jan 2013
    sempre lo stesso
    root@voyage:~#
    è quello che diceva Paolo, io non conosco il modo per aggornare il db dei certificati, speravo nell'apt-update, vuoi provare apt-get upgrade? magari risolve.
    Ciao, Marco.
  7. #17
    Jan 2013
    oppure proviam con GIT; ma prima devi riuscire a mettere il setup.pl sul sistema in qualche modo (magari lo scarichi su mac e poi lo copi con una chiavetta)
    Ciao, Marco.
  8. #18
    Nov 2016
    Per evitare che wget rompa le balle coi certificati puoi aggiungere l'opzione --no-check-certificates dopo il link da scaricare
  9. #19
    Jul 2014
    o ho sbagliato sintassi o non funziona
    root@voyage:~# wget https://raw.githubusercontent.com/ma...k-certificates
    --2017-03-24 22:06:40-- https://raw.githubusercontent.com/ma...k-certificates
    Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.112.133
    Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.112.133|:443... connected.
    ERROR: The certificate of `raw.githubusercontent.com' is not trusted.
    ERROR: The certificate of `raw.githubusercontent.com' hasn't got a known issuer.
  10. #20
    Jul 2014
    va messo prima ?
    ora ottengo questo
    root@voyage:~# remountrw
    root@voyage:~# wget --no-check-certificate https://github.com/marcoc1712/instal...1.0.1/setup.pl
    --2017-03-24 22:20:18-- https://github.com/marcoc1712/instal...1.0.1/setup.pl
    WARNING: The certificate of `github.com' is not trusted.
    WARNING: The certificate of `github.com' hasn't got a known issuer.
    HTTP request sent, awaiting response... 302 Found
    Location: https://github-cloud.s3.amazonaws.co...2Foctet-stream [following]
    --2017-03-24 22:20:19-- https://github-cloud.s3.amazonaws.co...2Foctet-stream
    Resolving github-cloud.s3.amazonaws.com (github-cloud.s3.amazonaws.com)... 54.231.49.138
    Connecting to github-cloud.s3.amazonaws.com (github-cloud.s3.amazonaws.com)|54.231.49.138|:443... connected.
    WARNING: The certificate of `github-cloud.s3.amazonaws.com' is not trusted.
    WARNING: The certificate of `github-cloud.s3.amazonaws.com' hasn't got a known issuer.
    HTTP request sent, awaiting response... 200 OK
    Length: 8758 (8.6K) [application/octet-stream]
    Saving to: `setup.pl'
    100%[======================================>] 8,758 --.-K/s in 0.004s
    2017-03-24 22:20:19 (1.95 MB/s) - `setup.pl' saved [8758/8758]
    root@voyage:~#
Pagina 2 di 21
