DSD in LMS con SOX
Pagina 60 di 115
... 10 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 110 ... ultimo
Visualizzazione dei risultati da 591 a 600 su 1145
  1. #591
    Jan 2013
    Confermo.
    dal log leggo DSD rate 0
    codice:
    [Thu Feb 23 08:18:37 2017] INFO: Running as Transcoder
    [Thu Feb 23 08:18:37 2017] INFO: $maxsamplerate :384000
    [Thu Feb 23 08:18:37 2017] INFO: sampleRates :{
      8000   => 1,
      11025  => 1,
      12000  => 1,
      16000  => 1,
      22050  => 1,
      24000  => 1,
      32000  => 1,
      44100  => 1,
      48000  => 1,
      88200  => 1,
      96000  => 1,
      176400 => 1,
      192000 => 1,
      352800 => 1,
      384000 => 1,
      705600 => undef,
      768000 => undef,
    [Thu Feb 23 08:18:37 2017] INFO: $maxDsdrate :0
    [Thu Feb 23 08:18:37 2017] INFO: dsdrates :undef
    [Thu Feb 23 08:18:37 2017] INFO: testfile: E:\Musica\DA_CANCELLARE\DJ Krush - Zen\(03) [DJ Krush] Danger Of Love Featuring Zap Mama.flac
    [Thu Feb 23 08:18:37 2017] INFO: AudioScan: {
      info => {
                audio_md5         => ("0" x 32),
                audio_offset      => 32_772,
                audio_size        => 34_682_105,
                bitrate           => 819_104,
                bits_per_sample   => 16,
                channels          => 2,
                file_size         => 34_714_877,
                jenkins_hash      => "1817261284",
                maximum_blocksize => 4096,
                maximum_framesize => 12_315,
                minimum_blocksize => 4096,
                minimum_framesize => 14,
                samplerate        => 44_100,
                song_length_ms    => 338_732,
                total_samples     => 14_938_112,
      tags => {
                ALBUM       => "DJ Krush   Zen",
                APPLICATION => { "1181311841" => "Medieval CUE Splitter (www.medieval.it)\0" },
                ARTIST      => "DJ Krush",
                COMMENT     => "Track 2",
                GENRE       => " ",
                NOTES       => "Medieval CUE Splitter (www.medieval.it)",
                TITLE       => "Danger Of Love Featuring Zap Mama",
                TRACKNUMBER => "03",
                VENDOR      => "reference libFLAC 1.2.1 20070917",
    [Thu Feb 23 08:18:37 2017] INFO: file samplerate: 44100
    [Thu Feb 23 08:18:37 2017] INFO: bits Per Sample: 16
    [Thu Feb 23 08:18:37 2017] INFO: is runtime :                 1
    [Thu Feb 23 08:18:37 2017] INFO: forced Samplerate :
    [Thu Feb 23 08:18:37 2017] INFO: resampleWhen :               A
    [Thu Feb 23 08:18:37 2017] INFO: resampleTo :                 S
    [Thu Feb 23 08:18:37 2017] INFO: Max syncrounus sample rate :
    [Thu Feb 23 08:18:37 2017] INFO: isDsdOutput :                1
    [Thu Feb 23 08:18:37 2017] INFO: maxDsdrate :                 0
    [Thu Feb 23 08:18:37 2017] INFO: maxsamplerate :              384000
    [Thu Feb 23 08:18:37 2017] INFO: Target Sample rate :          0
    [Thu Feb 23 08:18:37 2017] INFO: execute command  : C":\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\sox.exe" -q -t flac "E:\Musica\DA_CANCELLARE\DJ Krush - Zen\(03)
    Ance selezionando MANUALMENTE per player le frequenze abilitate?
    Se è così, provate a cancellare le prefs che sono nella cartella prefs parallela a .../cache (.../prefs/plugin/C3PO.prefs), la migrazione da 1.0.6 le imposta, ma se le trova già non lo fa ed è giusto così, tranne che per chi ha usato le versioni beta.
    Vedrò di risolverlo nel codice, ma visto che non siamo 1000... meglio farlo a mano una volta per tutte.
    Ciao, Marco.
  2. #592
    Jan 2013
    Nota a margine:
    prima che me ne dimentichi... ci sono un paio di opzioni (globali) di sox che potrebbero essere importanti:
    --buffer
    --multi-threaded
    quest'ultima abilita l'uso di più thread, cioè la possibilità di suddividere le diverse operazioni svolte internamente da sox tra più CPU/cores diversi: se non è presente quella opzione, per default sox usa sempre un solo "thread", cioè un solo core/CPU.
    Questa è un'arma a doppio taglio: da un lato permette di sfruttare meglio le risorse disponibili e quindi di affrontare operazioni più gravose ma, dall'altro, specie se si hanno pochi cores, rischia di "saturare" la CPU, sottraendo risorse alle altre operazioni (e quindi potrebbe rallentare e rendere poco "reattiva" l'interfaccia, o perfino causare "underrun").
    La prima opzione imposta invece la dimensione dei buffer (di ingresso, di uscita ed interni) di sox. Il default è 8192 (8k). Se si usa "--multi-threaded" deve essere aggiunta "obbligatoriamente", portando la dimensione dei buffer (come minimo) a quella di default moltiplicata per il numero complessivo di cores/CPU presenti. Ma potrebbe essere vantaggioso aggiungerla (per aumentare la dimensione dei buffer) anche se si usa un solo thread.
    --buffer l'ho sperimentata ampiamente nelle versioni precedenti, io non mi sono mai accorto di differenze 'sostanziali' nemmeno nell'utilizzo della memoria, comunque è già un parametro, anche se non esposto. E' una di quelle opzioni attualmente 'nascoste' di cui parlavo.
    --multi-threaded L'ho valutata, ma subito scartata... può provocare problemi che difficilmente l'utente medio sarebbe in grado di ricondurre a sox, sempre per i soliti problemi di manutenzione ed assitenza preferisco evitare., almeno per il momento.
    Ciao, Marco.
  3. #593
    Aug 2011
    Fatto, e riavviato lms.
    ma rimane come sopra.
    se il percorso é giusto C:\ProgramData\Squeezebox\prefs\plugin\C3PO.prefs
    codice:
    [Thu Feb 23 10:48:47 2017] INFO: sampleRates :{
      8000   => 1,
      11025  => 1,
      12000  => 1,
      16000  => 1,
      22050  => 1,
      24000  => 1,
      32000  => 1,
      44100  => 1,
      48000  => 1,
      88200  => 1,
      96000  => 1,
      176400 => 1,
      192000 => 1,
      352800 => 1,
      384000 => 1,
      705600 => undef,
      768000 => undef,
    [Thu Feb 23 10:48:47 2017] INFO: $maxDsdrate :0
    [Thu Feb 23 10:48:47 2017] INFO: dsdrates :undef
    [Thu Feb 23 10:48:47 2017] INFO: testfile: E:\Musica\DA_CANCELLARE\DJ Krush - Zen\(03) [DJ Krush] Danger Of Love Featuring Zap Mama.flac
    [Thu Feb 23 10:48:47 2017] INFO: AudioScan: {
      info => {
                bitrate           => 819_104,
                channels          => 2,
      tags => {
                GENRE       => " ",
    [Thu Feb 23 10:48:47 2017] INFO: file samplerate: 44100
    [Thu Feb 23 10:48:47 2017] INFO: bits Per Sample: 16
    [Thu Feb 23 10:48:47 2017] INFO: is runtime :                 1
    [Thu Feb 23 10:48:47 2017] INFO: forced Samplerate :
    [Thu Feb 23 10:48:47 2017] INFO: resampleWhen :               A
    [Thu Feb 23 10:48:47 2017] INFO: resampleTo :                 S
    [Thu Feb 23 10:48:47 2017] INFO: Max syncrounus sample rate :
    [Thu Feb 23 10:48:47 2017] INFO: isDsdOutput :                1
    [Thu Feb 23 10:48:47 2017] INFO: maxDsdrate :                 0
    [Thu Feb 23 10:48:47 2017] INFO: maxsamplerate :              384000
    [Thu Feb 23 10:48:47 2017] INFO: Target Sample rate :          0
    [Thu Feb 23 10:48:47 2017] INFO: execute command  : C":\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\sox.exe" -q -t flac "E:\Musica\DA_CANCELLARE\DJ Krush - Zen\(03) [DJ Krush] Danger Of Love Featuring Zap Mama.flac" -t dsf -b 1 -  gain -h rate -v -I -b 90.7 -f  sdm
  4. #594
    Aug 2011
    e confermo che non si prende subito le impostazioni...bisogna fare piú volte applica...
    tipo il cambio di formato di uscita, cambiando da wav a dsf->applica continua a uscire in pcm per un paio di applica poi va in dsf
    cioé va nella situazione di sopra
  5. #595
    Jan 2013
    ahimé, temo ce ne siano ancora parecchi...
    In realtà sono stupito di quanti pochi siano...
    Siamo in fase di sviluppo e debug, vi sto rilasciando versioni NON testate al fine di trovare ed eliminare bachi, sarebbe probabilmente stato più efficace se invece di usare il meccanismo dei plugin (che comunque va testato anche lui) vi foste clonati il mio repository ed aggiornaste da quello, avrei evitato la procedura di rilascio e l'incremento di versione, che ormai prende almeno 1 ora per volta e basta sbagliare una picoclissima cosa e devi ripeterla...
    Adesso io conto solo Paolo e Filippo, ci sono altri che stanno seguendo/provando?
    Probabilmente non ha più molto senso, ma che ne dite di passare a questo metodo?
    Ciao, Marco.
  6. #596
    Jan 2013
    Cacchio, questa è una cosa che avevo sistemato tempo fa ed adesso si ripropone...
    Su tutti i settings?
    Ciao, Marco.
  7. #597
    Aug 2011
    Si mi ricordo....
    su quello di sopra sicuro....poi per vedere se lo facesse anche su altri ho provato a cambiare riduzione di guadagno manuale, e si lo fa anche con quello...
    presumo che sia generico
  8. #598
    Jan 2013
    Si mi ricordo....
    Allora non riportate più bugs legati al cambiamneto dei settings, devo prima risolvere questo, altrimenti rischiamo di confondere altri problemi con questo.
    ... tipico caso di regressione, ma ho già un'idea.
    Ciao, Marco.
  9. #599
    Jan 2013
    Si mi ricordo....
    Ma stai parlando dei settings 'generali' o per player?
    Ciao, Marco.
  10. #600
    Aug 2011
    sto parlando delle impostazioni in Avanzate>C-3PO...
    quelle in Lettore>C-3po sembrano OK
    a parte risoluzioni DSD supportate (rate = 44100*)....che sembra che non vadano
Pagina 60 di 115
