Like Tree184Likes
DSD in LMS con SOX
Pagina 11 di 114
... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 61 111 ... ultimo
Visualizzazione dei risultati da 101 a 110 su 1134
  1. #101
    Nov 2016
    Da me sembra convertire ma non va in play
    Log server:
    codice:
    [17-02-05 21:54:15.2584] Slim::Player::TranscodingHelper::checkBin (252)   Found command: [sox] -q  -t flac - -t dsf  -b 1 - rate -v 2822400
    [17-02-05 21:54:15.2585] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [sox] -q  -t flac - -t dsf  -b 1 - rate -v 2822400
    [17-02-05 21:54:16.0494] Slim::Player::StreamingController::_eventAction (271) b8:27:eb:3f:43:12: StatusHeartbeat in STOPPED-IDLE -> Slim::Player::StreamingController::_NoOp
    [17-02-05 21:54:20.0543] Slim::Player::StreamingController::_eventAction (271) b8:27:eb:3f:43:12: StatusHeartbeat in STOPPED-IDLE -> Slim::Player::StreamingController::_NoOp
    [17-02-05 21:54:24.0501] Slim::Player::StreamingController::_eventAction (271) b8:27:eb:3f:43:12: StatusHeartbeat in STOPPED-IDLE -> Slim::Player::StreamingController::_NoOp
    Log squeezelite
    codice:
    [21:54:14.108952] codec_open:255 codec open: 'd'
    [21:54:14.108978] codec_open:272 closing codec: 'p'
    [21:54:14.109028] stream_sock:393 connecting to xxx.xxx.xxx.xxx:pppp
    [21:54:14.160662] stream_sock:422 header: GET /stream.mp3?player=b8:27:eb:3f:43:12 HTTP/1.0
    [21:54:14.160728] sendSTAT:184 STAT: STMc
    [21:54:14.160765] process_strm:377 set fade mode: 0
    [21:54:14.160807] process:521 audg
    [21:54:14.160831] process_audg:433 audg gainL: 3840 gainR: 3840 adjust: 1
    [21:54:14.160856] set_volume:229 setting internal gain left: 3840 right: 3840
    [21:54:14.282501] process:521 strm
    [21:54:14.282565] process_strm:269 strm command q
    [21:54:14.282591] decode_flush:227 decode flush
    [21:54:14.282612] output_flush:424 flush output buffer
    [21:54:14.282684] sendSTAT:184 STAT: STMf
    [21:54:16.033216] process:521 strm
    [21:54:16.033290] process_strm:269 strm command t
    [21:54:16.033315] sendSTAT:184 STAT: STMt
    [21:54:20.037624] process:521 strm
    [21:54:20.037709] process_strm:269 strm command t
    [21:54:20.037739] sendSTAT:184 STAT: STMt
    [21:54:24.032787] process:521 strm
    [21:54:24.032885] process_strm:269 strm command t
    [21:54:24.032913] sendSTAT:184 STAT: STMt
    [21:54:28.035631] process:521 strm
    [21:54:28.035692] process_strm:269 strm command t
    [21:54:28.035718] sendSTAT:184 STAT: STMt
    [21:54:32.279169] process:521 strm
    [21:54:32.279235] process_strm:269 strm command t
    [21:54:32.279262] sendSTAT:184 STAT: STMt
    [21:54:36.541018] process:521 strm
    [21:54:36.541077] process_strm:269 strm command t
    [21:54:36.541102] sendSTAT:184 STAT: STMt
    [21:54:40.039643] process:521 strm
    [21:54:40.039702] process_strm:269 strm command t
    [21:54:40.039729] sendSTAT:184 STAT: STMt
    [21:54:44.033853] process:521 strm
    [21:54:44.033935] process_strm:269 strm command t
    [21:54:44.033963] sendSTAT:184 STAT: STMt
    [21:54:48.036153] process:521 strm
    [21:54:48.036231] process_strm:269 strm command t
    [21:54:48.036259] sendSTAT:184 STAT: STMt
  2. #102
    Jan 2013
    sto provando varie combinazioni... finalmente sembra che ci sia qualche progresso: se non altro ora va in play, con il comando giusto, ed il progress counter avanza... ma mi sa che c' qualche problema di comunicazione con squeezelite (problema analogo a quello dell'upsampling?), perch setta la scheda audio a cavolo, e non suona
    II sintomi sono queelli gi visti in altre occasioni, ma non riesco a ricordare quali, tu a cosa ti riferisci in particolare con "problema analogo a quello dell'upsampling?" all'upsampling di WAV sul server?
    Se cos no, squeezelite riceve correttamente l'header:
    codice:
    [21:42:14.556289] _read_header:158 DSF version: 1 format: 0
    [21:42:14.556326] _read_header:168 channels: 2
    [21:42:14.556334] _read_header:169 sample rate: 5644800
    quanto viene dopo mi ocnvince meno:
    codice:
    [21:42:14.556340] _read_header:170 lsb first: 1
    [21:42:14.556347] _read_header:171 sample bytes: 0
    [21:42:14.556353] _read_header:172 block size: 4096
    [21:42:14.556359] _read_header:178 found dsd len: 12
    ma soprattutto l'errore evidentemente qui (log di Filippo):
    codice:
    [17-02-05 20:53:30.2220] Slim::Player::Pipeline::sysread (282) Pipeline doesn't have pending bytes - trying to get some from source
    [17-02-05 20:53:30.2223] Slim::Player::Pipeline::sysread (304) Attempting to write to pipeline writer
    [17-02-05 20:53:30.2226] Slim::Player::Pipeline::sysread (310) Wrote 32768 bytes to pipeline writer
    [17-02-05 20:53:30.2227] Slim::Player::Pipeline::sysread (282) Pipeline doesn't have pending bytes - trying to get some from source
    [17-02-05 20:53:30.2229] Slim::Player::Pipeline::sysread (304) Attempting to write to pipeline writer
    [17-02-05 20:53:30.2231] Slim::Player::Pipeline::sysread (310) Wrote 32768 bytes to pipeline writer
    [17-02-05 20:53:30.2233] Slim::Player::Pipeline::sysread (282) Pipeline doesn't have pending bytes - trying to get some from source
    [17-02-05 20:53:30.2235] Slim::Player::Pipeline::sysread (304) Attempting to write to pipeline writer
    [17-02-05 20:53:30.2255] Slim::Player::Source::_wakeupOnReadable (409) 00:1c:c0:37:22:73
    [17-02-05 20:53:30.2260] Slim::Player::Pipeline::sysread (304) Attempting to write to pipeline writer
    [17-02-05 20:53:30.2262] Slim::Player::Source::_readNextChunk (346) readlen undef: (Broken pipe) 32
    [17-02-05 20:53:30.2264] Slim::Player::Source::_readNextChunk (373) end of file or error on socket, song pos: 0
    [17-02-05 20:53:30.2266] Slim::Player::Source::_readNextChunk (378) 00:1c:c0:37:22:73 mark end of stream
    [17-02-05 20:53:30.2268] Slim::Player::Source::_readNextChunk (386) Didn't stream any bytes for this song; mark it as failed
    Altro aspetto che non mi torna:
    codice:
    [21:42:14.556372] dsd_decode:538 DOP output
    Il tuo DAC accetta dsd nativo o solo dop?
    EDIT:
    Squeezelite compilato per DSD?
    lanciato con l'opzione -D? Se si, toglietela, -D DOP capable, si chiede a Squeezelite di uscire in DOP, non so se quello, ma meglio toglierlo.
    Ultima modifica di marcoc1712 : 05-02-2017 a 23:42
    Ciao, Marco.
    E. F. Schumacher (mis-attributed to A. Einstein)
  3. #103
    Jan 2013
    Ho verificato ed in Daphile ci sono diverse patch per il DSD, sia a LMS che a Squeezelite e persino una per SOX, bisognerebbe indagarle ed eventualmente applicarle, sinceramente pensavo fosse pi semplice.
    @Paolo, se vuoi provare SOX con una pipe (fuori da LMS), prova a vedere di applicare questa patch: http://www.daphile.com/gpl-src/00-Da...ata_size.patch
    In particolare mi stupisce squeezelite, possibile che nessuno usi la versione standard per il DSD?
    Non ricordo, ma mandando dsd nativo con LMS a squeezelite funziona?
    UnixMan likes this.
    Ciao, Marco.
  4. #104
    tebibyte L'avatar di UnixMan
    Sep 2013
    s, mi riferivo a quello.
    codice:
    esatto. Ad occhio e croce, sox non processa un bel nulla, per cui non ci sono dati da inviare...
    codice:
    entrambi.
    s e s. Fatto (tolto -D).
    quel che temevo. Quella per sox bisognerebbe mandarla a Mans, cos magari pu integrarla direttamente lui.
    Tnx. Ci provo e vi faccio sapere...
    hai la patch? cosa hanno modificato?
    s. Posso confermare che funziona, sia in DoP che nativo.
    Tolto il "-D" (che pensavo fosse necessario per il DSD), questo quanto succede mandando in play un file dsf (per altro prodotto proprio con sox):
    codice:
    [17-02-06 00:36:33.7534] Slim::Player::StreamingController::stop (2097) 00:1c:c0:37:22:73
    [17-02-06 00:36:33.7537] Slim::Player::StreamingController::resetSongqueue (1776) Song queue is now
    [17-02-06 00:36:33.7555] Slim::Player::StreamingController::play (2100) 00:1c:c0:37:22:73
    [17-02-06 00:36:33.7564] Slim::Player::StreamingController::_setPlayingState (2357) new playing state STOPPED
    [17-02-06 00:36:33.7566] Slim::Player::StreamingController::_setStreamingState (2366) new streaming state IDLE
    [17-02-06 00:36:33.7571] Slim::Player::Song::new (108) index 0 -> tmp:///home/data/audio/DSD/test.dsf
    [17-02-06 00:36:33.7574] Slim::Player::StreamingController::_setStreamingState (2366) new streaming state TRACKWAIT
    [17-02-06 00:36:33.7649] Slim::Player::StreamingController::_playersMessage (789) Getting stream info...: tmp:///home/data/audio/DSD/test.dsf
    [17-02-06 00:36:33.7655] Slim::Player::Song::getNextSong (229) tmp:///home/data/audio/DSD/test.dsf
    [17-02-06 00:36:33.7658] Slim::Player::StreamingController::_nextTrackReady (737) 00:1c:c0:37:22:73: nextTrack will be index 0
    [17-02-06 00:36:33.7661] Slim::Player::StreamingController::_Stream (1203) Song queue is now 0
    [17-02-06 00:36:33.7663] Slim::Player::StreamingController::_Stream (1206) 00:1c:c0:37:22:73: preparing to stream song index 0
    [17-02-06 00:36:33.7665] Slim::Player::Song::open (363) tmp:///home/data/audio/DSD/test.dsf
    [17-02-06 00:36:33.7674] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: dsf->dsf via: -
    [17-02-06 00:36:33.7677] Slim::Player::Song::open (387) seek=false time=0 canSeek=1
    [17-02-06 00:36:33.7683] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: dsf->dsf via: -
    [17-02-06 00:36:33.7685] Slim::Player::Song::open (408) Transcoder: streamMode=I, streamformat=dsf
    [17-02-06 00:36:33.7689] Slim::Player::Song::open (461) Opening stream (no direct streaming) using Slim::Player::Protocols::Volatile [tmp:///home/data/audio/DSD/test.dsf]
    [17-02-06 00:36:33.7692] Slim::Player::Protocols::File::open (81) duration: [264.626] size: [373448796] endian [] offset: [0] for tmp:///home/data/audio/DSD/test.dsf
    [17-02-06 00:36:33.7694] Slim::Player::Protocols::File::open (98) Opening file /home/data/audio/DSD/test.dsf
    [17-02-06 00:36:33.7698] Slim::Player::Protocols::File::open (192) Seeking in 0 into /home/data/audio/DSD/test.dsf
    [17-02-06 00:36:33.7701] Slim::Player::Song::open (482) URL is a song (audio): tmp:///home/data/audio/DSD/test.dsf, type=dsf
    [17-02-06 00:36:33.7713] Slim::Player::StreamingController::_Stream (1265) 00:1c:c0:37:22:73: stream
    [17-02-06 00:36:33.7762] Slim::Player::StreamingController::_Stream (1302) Song queue is now 0
    [17-02-06 00:36:33.7765] Slim::Player::StreamingController::_setPlayingState (2357) new playing state BUFFERING
    [17-02-06 00:36:33.7767] Slim::Player::StreamingController::_setStreamingState (2366) new streaming state STREAMING
    [17-02-06 00:36:33.8319] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: dsf->dsf via: -
    [17-02-06 00:36:33.9013] Slim::Player::Player::_buffering (1140) Buffering... 0 / 20480
    [17-02-06 00:36:34.2061] Slim::Player::Player::_buffering (1140) Buffering... 851756 / 20480
    [17-02-06 00:36:34.3810] Slim::Player::StreamingController::playerTrackStarted (2180) 00:1c:c0:37:22:73
    [17-02-06 00:36:34.3812] Slim::Player::StreamingController::_setPlayingState (2357) new playing state PLAYING
    [17-02-06 00:36:34.3814] Slim::Player::StreamingController::_Playing (361) Song 0 has now started playing
    [17-02-06 00:36:34.3821] Slim::Player::StreamingController::_Playing (390) Song queue is now 0
    *** /tmp/squeezelite.log ***
    [00:36:33.755869] decode_flush:190 decode flush
    [00:36:33.755914] output_flush:423 flush output buffer
    [00:36:33.775897] codec_open:218 codec open: 'd'
    [00:36:33.775987] stream_sock:384 connecting to 127.0.0.1:9000
    [00:36:33.776055] stream_sock:413 header: GET /stream.mp3?player=00:1c:c0:37:22:73 HTTP/1.0
    [00:36:33.865041] stream_thread:176 headers: len: 115
    HTTP/1.1 200 OK
    Server: Logitech Media Server (7.9.0 - 1468928517)
    Connection: close
    Content-Type: audio/dsf
    [00:36:33.926466] output_thread:638 open output device: hw:CARD=D20
    [00:36:33.926956] alsa_open:355 opening device at: 44100
    [00:36:33.927202] alsa_open:406 opened device hw:CARD=D20 using format: S32_LE sample rate: 44100 mmap: 1
    [00:36:33.927240] alsa_open:485 buffer: 499 period: 3 -> buffer size: 22005 period size: 7335
    [00:36:34.061277] _read_header:158 DSF version: 1 format: 0
    [00:36:34.061440] _read_header:168 channels: 2
    [00:36:34.061448] _read_header:169 sample rate: 5644800
    [00:36:34.061455] _read_header:170 lsb first: 1
    [00:36:34.061462] _read_header:171 sample bytes: 186720576
    [00:36:34.061468] _read_header:172 block size: 4096
    [00:36:34.061475] _read_header:178 found dsd len: 373448716
    [00:36:34.061482] dsd_decode:527 setting track_start
    [00:36:34.061489] dsd_decode:543 DSD to PCM output
    [00:36:34.231506] _output_frames:61 start buffer frames: 3526656
    [00:36:34.231572] _output_frames:146 track start sample rate: 705600 replay_gain: 0
    [00:36:34.241591] output_thread:638 open output device: hw:CARD=D20
    [00:36:34.257120] alsa_open:355 opening device at: 705600
    [00:36:34.257366] alsa_open:406 opened device hw:CARD=D20 using format: S32_LE sample rate: 705600 mmap: 1
    [00:36:34.257395] alsa_open:485 buffer: 499 period: 3 -> buffer size: 131070 period size: 43690
    *** /var/log/squeezeboxserver//server.log ***
    [17-02-06 00:36:35.0061] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: dsf->dsf via: -
    ...mentre questo ci che succede tentando la conversione al volo:
    codice:
    [17-02-06 00:41:34.8863] Slim::Player::StreamingController::_setPlayingState (2357) new playing state BUFFERING
    [17-02-06 00:41:34.8864] Slim::Player::StreamingController::_setStreamingState (2366) new streaming state STREAMING
    [17-02-06 00:41:34.9241] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [sox] -q  -t flac $FILE$ -t dsf  -b 1 - rate -vMn 5644800 sdm -f  sdm-8
    [17-02-06 00:41:34.9251] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [sox] -q  -t flac $FILE$ -t dsf  -b 1 - rate -vMn 5644800 sdm -f  sdm-8
    [17-02-06 00:41:35.1638] Slim::Player::StreamingController::playerReadyToStream (2198) 00:1c:c0:37:22:73
    [00:41:34.667800] decode_flush:190 decode flush
    [00:41:34.667851] output_flush:423 flush output buffer
    [00:41:34.885644] codec_open:218 codec open: 'd'
    [00:41:34.885715] stream_sock:384 connecting to 127.0.0.1:9000
    [00:41:34.885778] stream_sock:413 header: GET /stream.mp3?player=00:1c:c0:37:22:73 HTTP/1.0
    [00:41:34.945701] stream_thread:176 headers: len: 115
    HTTP/1.1 200 OK
    Connection: close
    [00:41:35.163197] _read_header:158 DSF version: 1 format: 0
    [00:41:35.163256] _read_header:168 channels: 2
    [00:41:35.163264] _read_header:169 sample rate: 5644800
    [00:41:35.163271] _read_header:170 lsb first: 1
    [00:41:35.163277] _read_header:171 sample bytes: 0
    [00:41:35.163283] _read_header:172 block size: 4096
    [00:41:35.163290] _read_header:178 found dsd len: 12
    [00:41:35.163297] dsd_decode:527 setting track_start
    [00:41:35.163317] dsd_decode:543 DSD to PCM output
    [00:41:35.163324] _decode_dsf:258 frames got to zero
    [00:41:35.163331] decode_thread:99 decode complete
    [00:41:35.164441] output_thread:638 open output device: hw:CARD=D20
    [00:41:35.164492] alsa_open:355 opening device at: 705600
    [00:41:35.164707] alsa_open:406 opened device hw:CARD=D20 using format: S32_LE sample rate: 705600 mmap: 1
    [00:41:35.164736] alsa_open:485 buffer: 499 period: 3 -> buffer size: 131070 period size: 43690
    la cosa interessante che nel frattempo il counter di LMS avanza ed il processo di sox vivo, ma non sembra fare nulla: non utilizza CPU n fa I/O. Come se stesse aspettando qualcosa...
    Ciao, Paolo.
    Se tu hai una mela, e io ho una mela, e ce le scambiamo, allora tu ed io abbiamo sempre una mela per uno. Ma se tu hai un'idea, ed io ho un'idea, e ce le scambiamo, allora abbiamo entrambi due idee.
  5. #105
    Sep 2013
    Ahi. Cominciamo subito male... la patch fallisce l'ultimo chunk:
    codice:
    --- src/dsf.c
    +++ src/dsf.c
    @@ -278,7 +281,10 @@ static void dsf_write_bits(struct dsf *dsf, const sox_sample_t *buf,
                    unsigned d = dsd[i * dsf->block_size];
                    for (j = start_bit; j < start_bit + len; j++) {
    -                       d |= (buf[i + j * dsf->chan_num] > 0) << j;
    +                       if (buf[i + j * dsf->chan_num] > 0)
    +                               d |= 1 << j;
    +                       else
    +                               d &= ~(1 << j);
                    dsd[i * dsf->block_size] = d;
    il codice in git non corrisponde.
    Con la patch parzialmente applicata, qualcosa cambia: vengono prodotti dei dati, che squeezelite riceve e... "suona", ma junk (viene fuori solo rumore):
    codice:
    [17-02-06 01:46:21.7378] Slim::Player::StreamingController::_Stream (1265) 00:1c:c0:37:22:73: stream
    [17-02-06 01:46:21.7400] Slim::Player::StreamingController::_Stream (1302) Song queue is now 1
    [17-02-06 01:46:21.7403] Slim::Player::StreamingController::_setPlayingState (2357) new playing state BUFFERING
    [17-02-06 01:46:21.7404] Slim::Player::StreamingController::_setStreamingState (2366) new streaming state STREAMING
    [17-02-06 01:46:21.7540] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [sox] -q  -t flac $FILE$ -t dsf  -b 1 - rate -vMn 5644800 sdm -f  sdm-8
    [17-02-06 01:46:21.7546] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [sox] -q  -t flac $FILE$ -t dsf  -b 1 - rate -vMn 5644800 sdm -f  sdm-8
    [01:46:21.988143] _read_header:158 DSF version: 1 format: 0
    [01:46:21.988599] _read_header:168 channels: 2
    [01:46:21.988607] _read_header:169 sample rate: 5644800
    [01:46:21.988613] _read_header:170 lsb first: 1
    [01:46:21.988619] _read_header:171 sample bytes: 2305843009213693951
    [01:46:21.988626] _read_header:172 block size: 4096
    [01:46:21.988632] _read_header:178 found dsd len: 12
    [01:46:21.988639] dsd_decode:527 setting track_start
    [01:46:21.988646] dsd_decode:543 DSD to PCM output
    [01:46:22.078507] output_thread:638 open output device: hw:CARD=D20
    [01:46:22.078721] alsa_open:355 opening device at: 44100
    [01:46:22.078983] alsa_open:406 opened device hw:CARD=D20 using format: S32_LE sample rate: 44100 mmap: 1
    [01:46:22.079016] alsa_open:485 buffer: 499 period: 3 -> buffer size: 22005 period size: 7335
    [01:46:22.196789] _output_frames:61 start buffer frames: 159744
    [01:46:22.196853] _output_frames:146 track start sample rate: 705600 replay_gain: 0
    [01:46:22.206886] output_thread:638 open output device: hw:CARD=D20
    [01:46:22.221039] alsa_open:355 opening device at: 705600
    [01:46:22.221299] alsa_open:406 opened device hw:CARD=D20 using format: S32_LE sample rate: 705600 mmap: 1
    [01:46:22.221322] alsa_open:485 buffer: 499 period: 3 -> buffer size: 131070 period size: 43690
    [17-02-06 01:46:22.2056] Slim::Player::StreamingController::playerTrackStarted (2180) 00:1c:c0:37:22:73
    [17-02-06 01:46:22.2059] Slim::Player::StreamingController::_setPlayingState (2357) new playing state PLAYING
    [17-02-06 01:46:22.2061] Slim::Player::StreamingController::_Playing (361) Song 1 has now started playing
    [17-02-06 01:46:22.2066] Slim::Player::StreamingController::_Playing (390) Song queue is now 1
    [17-02-06 01:46:22.9703] Slim::Player::StreamingController::pause (2116) 00:1c:c0:37:22:73
    [17-02-06 01:46:22.9711] Slim::Player::StreamingController::_setPlayingState (2357) new playing state PAUSED
    Dopo di che ho provato a ricostruire a mano come avrebbe dovuto essere la funzione con l'ultima parte della patch, ma non funziona: non solo produce dsf invalidi ma, curiosamente, si comporta come il sox di Mans non patchato (cio, non fa neanche finta di suonare).
    Direi che a questo punto tempo interpellare Mans...
    Ciao, Paolo.
  6. #106
    Sep 2013
    nota a margine:
    se genero un file dsf con sox e chiedo informazioni sullo stesso (con soxi) prima che il file sia completo (cio mentre sox sta ancora girando), ottengo questo risultato:
    codice:
    /opt/sox-dsd/bin/soxi *.dsf
    /opt/sox-dsd/bin/soxi FAIL formats: can't open input file `pippo.dsf': invalid data chunk size
    ...quando invece il file (lo stesso file) completo, risulta tutto ok:
    codice:
    Input File     : 'pippo.dsf'
    Channels       : 2
    Sample Rate    : 5.6448e+06
    Precision      : 1-bit
    Duration       : 00:04:24.63 = 1493764608 samples ~ 19847 CDDA sectors
    File Size      : 373M
    Bit Rate       : 11.3M
    Sample Encoding: 1-bit Direct Stream Digital
    Ciao, Paolo.
  7. #107
    Aug 2011
    Et
    47
    Paolo a te riproduce file dsf senza l'opzione -D in squeezelite?
  8. #108
    Sep 2013
    s (vedi sopra).
    Ciao, Paolo.
  9. #109
    Aug 2011
    Et
    47
    s
    e sei sicuro che non ti faccia una conversione in PCM?
  10. #110
    Sep 2013
    certo.
    A te no? Se cos fosse, checklist:
    *) Il tuo DAC (l'interfaccia USB) supporta DSD nativo (non DoP)?
    *) il Kernel e le librerie ALSA che usi lo supportano?
    *) hai compilato SL con l'opzione DSD?
    Ciao, Paolo.
Pagina 11 di 114
nexthardware.com - 2002-2018
