DSD in LMS con SOX
Pagina 102 di 115
... 2 52 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 ... ultimo
Visualizzazione dei risultati da 1,011 a 1,020 su 1145
  1. #1011
    Jan 2013
    Da un po che non usavo il dac per DSD, ma oggi lo attacco é ho qualche problema con Squeezelite-R2, non rieco a mandare in play dsd nativo 256.
    codice:
    squeezelite-R2 -?
    Squeezelite Copyright 2012-2015 Adrian Smith.
    this modified version (v1.8.4 (R2)), Copyright 2015 -2017 Marco Curti.
    see https://github.com/marcoc1712/squeezelite-R2
    See -t for license terms
    Usage: squeezelite-R2 [options]
      -s <server>[:<port>]    Connect to specified server, otherwise uses autodiscovery to find server
      -o <output device>    Specify output device, default "default", - = output to stdout
      -l             List output devices
      -x             Disable downsampling requests to LMS
      -a <b>:<p>:<f>:<m>    Specify ALSA params to open output device, b = buffer time in ms or size in bytes, p = period count or size in bytes, f sample format (16|24|24_3|32), m = use mmap (0|1)
      -a <f>        Specify sample format (16|24|32) of output file when using -o - to output samples to stdout (interleaved little endian only)
      -b <stream>:<output>    Specify internal Stream and Output buffer sizes in Kbytes
      -c <codec1>,<codec2>    Restrict codecs to those specified, otherwise load all available codecs; known codecs: flac,pcm,mp3,ogg,aac,dsd (mad,mpg for specific mp3 codec)
      -C <timeout>        Close output device when idle after timeout seconds, default is to keep it open while player is 'on'
      -d <log>=<level>    Set logging level, logs: all|slimproto|stream|decode|output, level: info|debug|sdebug
      -e <codec1>,<codec2>    Explicitly exclude native support of one or more codecs; known codecs: flac,pcm,mp3,ogg,aac,dsd (mad,mpg for specific mp3 codec)
      -f <logfile>        Write debug to logfile
      -m <mac addr>        Set mac address, format: ab:cd:ef:12:34:56
      -M <modelname>    Set the squeezelite player model name sent to the server (default: SqueezeLite-R2)
      -n <name>        Set the player name
      -N <filename>        Store player name in filename to allow server defined name changes to be shared between servers (not supported with -n)
      -p <priority>        Set real time priority of output thread (1-99)
      -P <filename>        Store the process id (PID) in filename
      -r <rates>[:<delay>]    Sample rates supported, allows output to be off when squeezelite is started; rates = <maxrate>|<minrate>-<maxrate>|<rate1>,<rate2>,<rate3>; delay = optional delay switching rates in ms
      -D [delay][:format]    Output device supports DSD, delay = optional delay switching between PCM and DSD in ms
                   format = dop (default if not specified), u8, u16le, u16be, u32le or u32be.
      -L             List volume controls for output device
      -U <control>        Unmute ALSA control and set to full volume (not supported with -V)
      -V <control>        Use ALSA control for volume adjustment, otherwise use software volume adjustment
      -z             Daemonize
      -t             License terms
      -?             Display this help text
    Build options: LINUX ALSA EVENTFD DSD
    Questo il debug di squeezelite
    codice:
    squeezelite-R2 -C 1 -D :u32be -o hw:CARD=J20,DEV=0 -d all=debug
    [14:58:25.800257] stream_init:290 init stream
    [14:58:25.800349] stream_init:291 streambuf size: 2097152
    [14:58:25.801489] output_init_alsa:889 init output
    [14:58:25.801520] output_init_alsa:930 device : hw:CARD=J20,DEV=0 requested alsa_buffer: 40 alsa_period: 4 format: any mmap: 1
    [14:58:25.801541] output_init_common:346 outputbuf size: 3528000
    [14:58:25.801596] output_init_common:370 idle timeout: 1000
    [14:58:25.802553] output_init_common:410 supported rates: 384000 352800 192000 176400 96000 88200 48000 44100
    [14:58:25.806048] output_init_alsa:946 memory locked
    [14:58:25.806250] output_init_alsa:969 set output sched fifo rt: 45
    [14:58:25.806268] decode_init:129 init decode, include codecs:  exclude codecs:
    [14:58:25.806331] register_dsd:906 using dsd to decode dsf,dff
    [14:58:25.806599] load_faad:610 loaded libfaad.so.2
    [14:58:25.806611] register_faad:640 using faad to decode aac
    [14:58:25.806916] load_vorbis:300 loaded libvorbisfile.so.3
    [14:58:25.806928] register_vorbis:329 using vorbis to decode ogg
    [14:58:25.807165] load_flac:266 loaded libFLAC.so.8
    [14:58:25.807177] register_flac:294 using flac to decode flc
    [14:58:25.807189] register_pcm:424 using pcm to decode aif,pcm
    [14:58:25.807343] load_mad:383 loaded libmad.so.0
    [14:58:25.807355] register_mad:412 using mad to decode mp3
    [14:58:25.807504] discover_server:756 sending discovery
    [14:58:25.807741] discover_server:767 got response from: 192.168.178.22:3483
    [14:58:25.807772] slimproto:849 connecting to 192.168.178.22:3483
    [14:58:25.807911] slimproto:882 connected
    [14:58:25.807925] sendHELO:124 mac: 50:e5:49:cc:b4:29
    [14:58:25.807937] sendHELO:126 cap: Model=squeezelite,AccuratePlayPoints=1,HasDigitalOut=1,HasPolarityInversion=1,Firmware=v1.8.4 (R2),ModelName=SqueezeLite-R2,MaxSampleRate=384000,dsf,dff,aac,ogg,flc,aif,pcm,mp3
    [14:58:25.808544] process:494 strm
    [14:58:25.808555] process_strm:256 strm command q
    [14:58:25.808566] decode_flush:190 decode flush
    [14:58:25.808578] output_flush:423 flush output buffer
    [14:58:25.808590] sendSTAT:171 STAT: STMf
    [14:58:25.808651] process:494 setd
    [14:58:25.808761] process:494 setd
    [14:58:25.808779] process:494 aude
    [14:58:25.808790] process_aude:395 enable spdif: 1 dac: 1
    [14:58:25.808854] process:494 audg
    [14:58:25.808864] process_audg:413 audg gainL: 65536 gainR: 65536 adjust: 0
    [14:58:25.808875] set_volume:251 setting internal gain left: 65536 right: 65536
    [14:58:28.548373] process:494 strm
    [14:58:28.548390] process_strm:256 strm command t
    [14:58:28.548402] sendSTAT:171 STAT: STMt
    [14:58:32.548398] process:494 strm
    [14:58:32.548413] process_strm:256 strm command t
    [14:58:32.548425] sendSTAT:171 STAT: STMt
    [14:58:36.551789] process:494 strm
    [14:58:36.551803] process_strm:256 strm command t
    [14:58:36.551814] sendSTAT:171 STAT: STMt
    [14:58:41.550835] process:494 strm
    [14:58:41.550849] process_strm:256 strm command t
    [14:58:41.550860] sendSTAT:171 STAT: STMt
    [14:58:46.548144] process:494 strm
    [14:58:46.548157] process_strm:256 strm command t
    [14:58:46.548199] sendSTAT:171 STAT: STMt
    [14:58:49.474995] process:494 strm
    [14:58:49.475008] process_strm:256 strm command q
    [14:58:49.475018] decode_flush:190 decode flush
    [14:58:49.475029] output_flush:423 flush output buffer
    [14:58:49.475058] sendSTAT:171 STAT: STMf
    [14:58:49.487566] process:494 audg
    [14:58:49.487576] process_audg:413 audg gainL: 65536 gainR: 65536 adjust: 0
    [14:58:49.487587] set_volume:251 setting internal gain left: 65536 right: 65536
    [14:58:49.487938] process:494 strm
    [14:58:49.487948] process_strm:256 strm command s
    [14:58:49.487958] process_strm:325 strm s autostart: 1 transition period: 10 transition type: 0 codec: d
    [14:58:49.487971] sendSTAT:171 STAT: STMf
    [14:58:49.487990] codec_open:218 codec open: 'd'
    [14:58:49.488014] stream_sock:384 connecting to 192.168.178.22:9000
    [14:58:49.488151] stream_sock:413 header: GET /stream.mp3?player=50:e5:49:cc:b4:29 HTTP/1.0
    [14:58:49.488165] sendSTAT:171 STAT: STMc
    [14:58:49.488178] process_strm:357 set fade mode: 0
    [14:58:49.488202] process:494 audg
    [14:58:49.488216] process_audg:413 audg gainL: 65536 gainR: 65536 adjust: 0
    [14:58:49.488227] set_volume:251 setting internal gain left: 65536 right: 65536
    [14:58:49.516108] stream_thread:176 headers: len: 115
    HTTP/1.1 200 OK
    Server: Logitech Media Server (7.9.1 - 1511211491)
    Connection: close
    Content-Type: audio/dsf
    [14:58:49.516641] sendRESP:202 RESP
    [14:58:50.007157] output_thread:697 open output device: hw:CARD=J20,DEV=0
    [14:58:50.007553] alsa_open:367 opening device at: 44100
    [14:58:50.007725] alsa_open:440 opened device hw:CARD=J20,DEV=0 using format: S32_LE sample rate: 44100 mmap: 1
    [14:58:50.007754] alsa_open:531 buffer: 40 period: 4 -> buffer size: 1764 period size: 441
    [14:58:50.038047] _read_header:191 id: DSD  len: 28 consume: 28
    [14:58:50.038168] _read_header:158 DSF version: 1 format: 0
    [14:58:50.038181] _read_header:168 channels: 2
    [14:58:50.038194] _read_header:169 sample rate: 11289600
    [14:58:50.038204] _read_header:170 lsb first: 1
    [14:58:50.038214] _read_header:171 sample bytes: 2305843009213693951
    [14:58:50.038225] _read_header:172 block size: 4096
    [14:58:50.038235] _read_header:191 id: fmt  len: 52 consume: 52
    [14:58:50.038247] _read_header:178 found dsd len: 12
    [14:58:50.038257] dsd_decode:765 setting track_start
    [14:58:50.038269] dsd_decode:819 DSD256 stream, format: DSD_U32_BE, rate: 352800Hz
    [14:58:50.047894] _output_frames:61 start buffer frames: 70656
    [14:58:50.047918] _output_frames:146 track start sample rate: 352800 replay_gain: 0
    [14:58:50.047934] sendSTAT:171 STAT: STMs
    [14:58:50.047963] sendSTAT:171 STAT: STMt
    [14:58:50.057937] output_thread:697 open output device: hw:CARD=J20,DEV=0
    [14:58:50.062409] alsa_open:367 opening device at: 352800
    [14:58:50.062562] alsa_open:440 opened device hw:CARD=J20,DEV=0 using format: DSD_U32_BE sample rate: 352800 mmap: 1
    [14:58:50.062583] alsa_open:531 buffer: 40 period: 4 -> buffer size: 14112 period size: 3528
    [14:58:50.548697] process:494 strm
    [14:58:50.548734] process_strm:256 strm command t
    [14:58:50.548745] sendSTAT:171 STAT: STMt
    [14:58:51.549787] sendSTAT:171 STAT: STMt
    [14:58:52.550904] sendSTAT:171 STAT: STMt
    [14:58:53.551970] sendSTAT:171 STAT: STMt
    [14:58:54.548166] process:494 strm
    [14:58:54.548205] process_strm:256 strm command t
    [14:58:54.548216] sendSTAT:171 STAT: STMt
    [14:58:55.549257] sendSTAT:171 STAT: STMt
    [14:58:56.550378] sendSTAT:171 STAT: STMt
    [14:58:57.551451] sendSTAT:171 STAT: STMt
    [14:58:58.549019] process:494 strm
    [14:58:58.549078] process_strm:256 strm command t
    [14:58:58.549090] sendSTAT:171 STAT: STMt
    [14:58:59.550130] sendSTAT:171 STAT: STMt
    [14:59:00.551252] sendSTAT:171 STAT: STMt
    [14:59:01.552324] sendSTAT:171 STAT: STMt
    [14:59:02.548313] process:494 strm
    [14:59:02.548346] process_strm:256 strm command t
    il comando di C-3PO
    codice:
     Command:
    [flac] -dcs --totally-silent $START$ $END$ -- $FILE$ | [sox] -q -t wav - -t dsf -b 1 --buffer 8192 - gain -h rate -v -I -b 90.7 -f 11289600 sdm
    Tokenized command:
    "/usr/bin/flac" -dcs --totally-silent -- - | "/usr/bin/sox" -q -t wav - -t dsf -b 1 --buffer 8192 - gain -h rate -v -I -b 90.7 -f 11289600 sdm
    Niente Audio!
    Cosa potrebbe essere?
    Con Hqplayer é tutto ok.
    Anche a me pare tutto OK. tutto il resto suona senza problemi?
    Ciao, Marco.
  2. #1012
    Aug 2011
    Non so il perché, ma adesso va...
  3. #1013
    nibble
    Dec 2010
    Ciao a tutti, da qualche tempo mi sono dotato anche di un dac che accetta DSD per cui ho installato la versione modificata di SOX per fare conversione dei PCM. Il mio attuale sistema è:
    -server con win10 + lms + sox
    -pc player con daphile
    Riscontro però un problema: mentre col flusso PCM il sistema è gapless, quando converto in DSD (qualsiasi frequenza) ho un gap tra i brani. Avete riscontrato lo stesso problema? C'è qualche settaggio che mi son perso?
    Grazie
  4. #1014
    Aug 2011
    Originariamente inviato da m_b
    Grazie
    Hai provato con un player diverso? tipo squeezelite-R2?
  5. #1015
    nibble
    Dec 2010
    Non ancora, proprio per fare questa controprova ho preparato una live usb con gentoo (usando l'immagine che hai preparato tu ..a proposito, grazie !! ). Proverò nei prossimi giorni, ma non ho familiarità con linux...nel caso verrò a far qualche domanda banale nell'altro thread
  6. #1016
    Aug 2011
    Vai tranquillo é fatto apposta per chi non ha familiaritá con linux...
  7. #1017
    Jan 2013
    Grazie
    Ho uno sfocato ricordo di un problema analogo segnalato tempo fa in merito, non ricordo come lo avevamo risolto a suo tempo, una prima prova è togliere il -C (se c'è) da squeezelite, usando Daphile non saprei.
    Se mandi DSD 'nativo' lo fa lo stesso?
    Ciao, Marco.
  8. #1018
    nibble
    Dec 2010
    Su Daphile, nel setting della scheda audio/dac, la voce del DSD nativo non me la fa selezionare. Temo che Daphile abbia qualche problema col driver del dac.
    Vediamo il lato positivo ...motivo in più per provare Gentoo...
    Nel caso...cosa vuol dire "togliere il -C" e come si fa?
    grazie!
  9. #1019
    Jan 2013
    grazie!
    nella riga di comando di squeezelite, togli (o non metti) l'opzione -C.
    Ciao, Marco.
  10. #1020
    nibble
    Dec 2010
    Ciao, con LMS su sistema Ubuntu qual'è la versione di sox modificato da utilizzare tra queste?
    sox-dsd-linux-gnu-amd64
    sox-dsd-linux-gnu-i386
    Poi nella cartella usr/share/squeezeboxserver/bin ho varie sottocartelle (aarch64-linux ; armhf-linux; i386-linux ; ....) contenenti dei file SOX. In quali di queste devo sostituire il vecchio SOX con il nuovo modificato?
    grazie ciao
Pagina 102 di 115
