Ciao, Paolo.
Ciao, Marco.
Ciao, Paolo.
* 2017/05/21 19:49:23 Signalyst HQPlayer 4 Embedded 4.0.0b1
+ 2017/05/21 19:49:23 Engine starting...
2017/05/21 19:49:23 asoundlib version: 1.1.0
2017/05/21 19:49:24 libDSP version 18.4.3
2017/05/21 19:49:24 Number of processor cores: 4
2017/05/21 19:49:24 DSP thread pools disabled
2017/05/21 19:49:24 Pipelined DSP enabled
2017/05/21 19:49:24 Audio engine: network
2017/05/21 19:49:24 Network Audio IPv6 support disabled
2017/05/21 19:49:24 Discovery from 0.0.0.0
& 2017/05/21 19:49:24 Discovered network audio: name='' version='Signalyst Network Audio Daemon 3.5.1' @192.168.1.5:43210
2017/05/21 19:49:25 Network endpoint: xCORE USB Audio 2.0: USB Audio (hw:0,0)
2017/05/21 19:49:25 Network endpoint: HDA ATI SB: ALC663 Analog (hw:1,0)
2017/05/21 19:49:25 Network endpoint: HD-Audio Generic: HDMI 0 (hw:2,3)
2017/05/21 19:49:25 Discovered 1 Network Audio Adapters
2017/05/21 19:49:25 Set channels: 2 (2)
+ 2017/05/21 19:49:25 Connect to 192.168.1.5:43210
2017/05/21 19:49:25 Network format: 44100/32/2 [pcm]
2017/05/21 19:49:25 Network format: 48000/32/2 [pcm]
2017/05/21 19:49:25 Network format: 88200/32/2 [pcm]
2017/05/21 19:49:25 Network format: 96000/32/2 [pcm]
2017/05/21 19:49:25 Network format: 176400/32/2 [pcm]
2017/05/21 19:49:25 Network format: 192000/32/2 [pcm]
2017/05/21 19:49:25 Network format: 352800/32/2 [pcm]
2017/05/21 19:49:25 Network format: 384000/32/2 [pcm]
2017/05/21 19:49:25 Network format: 705600/32/2 [pcm]
2017/05/21 19:49:25 Network format: 768000/32/2 [pcm]
2017/05/21 19:49:25 Network format: 2822400/1/2 [dsd]
2017/05/21 19:49:25 Network format: 3072000/1/2 [dsd]
2017/05/21 19:49:25 Network format: 5644800/1/2 [dsd]
2017/05/21 19:49:25 Network format: 6144000/1/2 [dsd]
2017/05/21 19:49:25 Network format: 11289600/1/2 [dsd]
2017/05/21 19:49:25 Network format: 12288000/1/2 [dsd]
2017/05/21 19:49:25 Network format: 22579200/1/2 [dsd]
2017/05/21 19:49:25 Network format: 24576000/1/2 [dsd]
2017/05/21 19:49:25 Set volume: -3
2017/05/21 19:49:25 Automatic rate family disabled
2017/05/21 19:49:25 DirectSDM enabled
2017/05/21 19:49:25 SDM conversion parameters (5, 0)
2017/05/21 19:49:25 DSD 6 dB gain disabled
2017/05/21 19:49:25 Initial parallel threads: 4
2017/05/21 19:49:25 Number of logical cores: 4
& 2017/05/21 19:49:25 Set transport (240):
2017/05/21 19:49:25 Set filter: 6
2017/05/21 19:49:25 Set dither: 5
2017/05/21 19:49:25 Set oversampling: 6
2017/05/21 19:49:25 Set modulator: 3
2017/05/21 19:49:25 IntegratorM: IIR
2017/05/21 19:49:25 Audio engine SDM mode enabled
2017/05/21 19:49:25 Requested output rate: 12288000
2017/05/21 19:49:25 Set sampling rate: 12288000 (12288000)
2017/05/21 19:49:25 Automatic output rate switching enabled
+ 2017/05/21 19:49:25 Server starting...
2017/05/21 19:49:25 Control active volume range: -60 - 0 dB
+ 2017/05/21 19:49:25 Engine running
& 2017/05/21 19:50:09 Idle
& 2017/05/21 19:50:10 Play next URI: http://127.0.0.1:49152/LMS2UPNP/bb-b...e-91-idx-1.wav
+ 2017/05/21 19:50:10 Playback engine running
2017/05/21 19:50:10 Rate or blocksize change triggered
2017/05/21 19:50:10 Rate: 44100, block size: 4704, frame size: 588
2017/05/21 19:50:10 Block size: 4704 (sample: 4)
2017/05/21 19:50:10 Oversampling: poly (light)
2017/05/21 19:50:10 Modulator: fifth order 1-bit 256+fs
2017/05/21 19:50:10 Integrator: IIR
2017/05/21 19:50:11 Playback engine ratio: 278.639
2017/05/21 19:50:11 Set volume: -3
2017/05/21 19:50:11 Initialization complete, starting audio engine
+ 2017/05/21 19:50:11 Network engine starting...
2017/05/21 19:50:11 Network SDM streaming
+ 2017/05/21 19:50:11 Network engine started at: 12288000
2017/05/21 19:50:11 Parallel threads: 4
2017/05/21 19:50:11 Nested parallelism: 0
2017/05/21 19:50:11 Parallel pipelines: 4
2017/05/21 19:54:01 End of track
& 2017/05/21 19:54:01 Next
2017/05/21 19:54:01 Idle request
& 2017/05/21 19:54:02 Play next URI: http://127.0.0.1:49152/LMS2UPNP/bb-b...e-91-idx-0.wav
& 2017/05/21 19:57:15 Idle
& 2017/05/21 19:57:15 Play next URI: http://127.0.0.1:49152/LMS2UPNP/bb-b...e-91-idx-1.wav
2017/05/21 20:01:37 End of track
& 2017/05/21 20:01:37 Next
2017/05/21 20:01:37 Idle request
& 2017/05/21 20:01:38 Play next URI: http://127.0.0.1:49152/LMS2UPNP/bb-b...e-91-idx-0.wav
a giudicare dal log postato, ad occhio e croce avevi ragione... non usa un singolo stream, ne crea uno nuovo ad ogni traccia.
Ma Riccardo conferma che il gapless funziona: non ci sono "buchi" o salti tra una traccia e l'altra, la riproduzione va avanti senza interruzioni.
Ciao, Paolo.
Ciao, Marco.
Buonasera, c'è qualcuno sul forum che utilizza il cubox collegato al pc tramite cavo crossover?
In caso affermativo, quale sarebbe la procedura per assegnare l'IP statico al sistema che si va a caricare sulla scheda sd?
Grazie
bit32
No.
Il "giochino" si fa con "hqplayerd", cioè con la versione "embedded" di hqplayer (che esiste solo per Linux), non con quella desktop.
Ciao, Paolo.
Buongiorno a tutti, scusate se ripeto in qualche modo la domanda, vorrei acquistare un cubox, che vorrei collegare direttamente al pc senza passare attraverso il router,
qualcuno è a conoscenza di un metodo che consenta di assegnare ip statico all' immagine confezionata dall'autore?
Grazie
bit32
