Pagina 124 di 184
... 24 74 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 174 ... ultimo
Visualizzazione dei risultati da 1,231 a 1,240 su 1835
  1. #1231
    Moderatore L'avatar di bibo01
    Oct 2010
    Pubblicata la 3.14.1
    On desktop GUI, single click just loads item on the transport, while double-click both loads and starts playback of the loaded item.
    On touch/fullscreen GUI, in playlist editor double-click of an album or song performs similar add-play combination. In addition, in the playlist editor view double-clicking a playlist item switches playback to that song.
    Re-enables CUDA support on macOS and workaround for a case where CUDA freezes in certain environments. Cleans up metadata with extra whitespaces on import.
    Ultima modifica di bibo01 : 10-10-2016 a 01:58
  2. #1232
    Oct 2010
    Pubblicata la 3.14.2
    Fixes handling of certain multichannel FLACs. Also fixes loading of certain types of WAV files on Windows.
  3. #1233
    Oct 2010
    HQPlayer Desktop and HQPlayer Embedded 3.14.3 released.
    Fixes seeking problems, adds double-click-to-play on cover flow, optimizes GPU memory usage.
  4. #1234
    Oct 2010
    HQPlayer Desktop and HQPlayer Embedded 3.14.4 released.
    Some small fixes and optimizations to convolution engine initialization. Also fixes a timing problem in CUDA algorithm initialization.
  5. #1235
    Oct 2010
    Network Audio Daemon 3.4.2 released with minor improvements and fixes.
  6. #1236
    Aug 2011
    Bibo sai se é stato implementato il log su file?
  7. #1237
    Oct 2010
    Yes, controlled through NETWORKAUDIOD_LOGFILE environment variable. Also included in the example Windows bat-files...
  8. #1238
    Oct 2010
    Replico un messaggio di Miska che spiega un'evoluzione del programma che potrebbe risultare utile in futuro:
    Now there's a first public alpha release of HQPlayer Embedded 4.x available. It has the same control API as HQPlayer Desktop, in addition to the earlier functionality. So it can be used with Roon/Muso/Alchemy and in addition as UPnP Renderer.
    YMMV, but you may need to wait for the next Roon release. I'd be happy to hear how Muso and Alchemy work with it.
    No new licenses available for the alpha releases, I have not yet decided how new licenses would be available (earliest for final 4.0.0 release). People who already have a key file for HQPlayer Embedded 3.x can ask me update key file for the 4.x - for the same machine fingerprint.
  9. #1239
    Oct 2010
    HQPlayer Desktop 3.15.0 released!
    New poly-sinc-xtr "extreme" filters, update for Linux package forward compatibility, updates and fixes to the control protocol, number of smaller fixes and improvements.
  10. #1240
    Oct 2010
    Questo nel manuale aproposito del nuovo filtro -
    poly-sinc-xtr: Linear phase polyphase sinc filter with extreme cut-off and attenuation.
    poly-sinc-xtr-mp: Minimum phase polyphase sinc filter with extreme cut-off and attenuation.
    ...e Miska aggiunge:
    It is much steeper/longer with about 5x more taps than "poly-sinc" and attenuation spec pushed to -240 dB. So this filter cuts really fast and really hard.
Pagina 124 di 184
