Il NAA, questo sconosciuto...
Pagina 29 di 31
... 19 20 21 22 23 24 25 26 27 28 29 30 31 ultimo
Visualizzazione dei risultati da 281 a 290 su 302
  1. #281
    kibibyte L'avatar di Maggio
    Nov 2013
    Mi sa che deciderò per altro molto presto...
  2. #282
    nibble L'avatar di EuroDriver
    Feb 2015
    Monaco
    NAA on WS2012 +AO in MSM vs NAA on Win 8
    Today Geoff Armstrong and I did a lot of testing of NAA on Win 8 and WS2012 and playing from HQP on OSX Yosemite and Win 8.1 with and with out RAM disk
    The SQ of NAA on WS2012+AO is so much better than Win 8, it is amazing. The amount of SSD activity is completely different
    Here is WS2012 SSD flashing
    https://www.facebook.com/video.php?v...=2&theater
    Here is Win 8 SSD flashing
    We found some surprising differences when we used RAM disk on the HQ Player desktop machine.
    IM RAM made the Win 8.1 HQ Player desktop sound worse, whilst OSX RAM Disk made the Yosemite HQ Player sound better. These results were with fibre optic isolation between the NAA PC and the LAN !
    Either its OS related noise via the AC power cables or there is some USB data packet issue which is OS activity related. These results are strongly pushing us to try WS2012 on the machine running HQ Player desktop
    HQP Windows 3.6.2 beta 4 sounds noticeably better than OSX 3.6.1.2
    HQ Player 3.6.1.1 on various PC's > HQ Player NAA on WS 2012 + AO(MSM) on i7 3770 on DH61DL mobo > TOTALDAC D1 USB cable >
    Exasound E20 Mk III with 0.82 clock > Hypex NCore 400 > Inakustik LS1203 >
    B&W 805D. DSpeaker 8033 > Velodyne SPL 1200 Ultra
    GIK room treatment, diagonal speaker placement
    Sonos Connect> Toslink > miniDSP Dirac DDRC-22D > Toslink > NAD D3020 > inAkustic zip cord > KEF LS50 + SVS SB-1000
    No room treatment, tiled floor, asymmetric room, unequal speaker distances to listening position
  3. #283
    Moderatore L'avatar di bibo01
    Oct 2010
    Originariamente inviato da EuroDriver
    Was your Win NAA the one in your signature? With LPS?
    What is IM Ramdisk?
    I can accept that WS+AO is much better that W8.1 for NAA. However, you run the first one optimized (perhaps in core mode) and the second one non-optimized. Please try to do the test with WS in GUI mode and no AO.
    I suppose that you cannot compare it to a minimal Linux installation as well because your Exasound DAC is not supported.
  4. #284
    Feb 2015
    Monaco
    What is IM Ramdisk?
    NAA hardware was as per signature with HD Plex LPS
    IM RAM is a RAM software for Windows. We downloaded Primo RAM, but could not get it to work :-(
    There is no way to unload AO once installed on WS2012. I would have to buy and build a new SSD to run WS2012 without AO
    My experience with HQ Player desktop on WS2012 + AO in Guimode, is that the SQ is significantly inferior to MInimal Server Mode
    The big surprise was even with NAA optically isolated from LAN, RAM disk on HQ Player PC made a sonic difference ! Ethernet timing improvement with WS 2012 ? ?
  5. #285
    Oct 2010
    It is odd that you have not managed to make Primo RamDisk work.
    What was the problem?
    I am sure that someone else here may be able to help you out on that.
  6. #286
    Feb 2015
    Monaco
    We kept on getting the error "unable to assign drive letter"
    There are a lot of choices / options such as cluster size, which we did not know what to choose ! Suggestions on settings would be very welcome
  7. #287
    Dec 2010
    Cagliari
    My two cents about a lot of arguments of a really complex system.
    I'm now listening to my music with this set:
    Server: Winserver 2012R2+ AO+Primo Ramdisk (for music files only in I/O mode)+ HQ
    NAA: Winserver 2012R2 +AO+Primo Ramdisk (where stay NAD.exe)+jplay
    Both PC are connected by double TPlink 210 plus fiber cable (static IP).
    Although i'm still testing not only the sound quality of the system but, more important for me, his stability, I can come to some conclusion:
    1) I've affirmed again and again, from my first use of HQ+NAA system (only or yet one year ago!), that is not true that server quality, PSU and so on was non influential on SQ because LAN connection was galvanically isolated. This statement is simply not true and also adding the optical fiber to the ethernet connection you'll be able to easily perceive that every change on the server has an effect on SQ.
    2) Windows NAA is clearly superior to the Linux+Cubox and quality of HW, especially mobo quality, is also really important
    3) Every program you want to install on PC, server or NAA, must be installed before AO install. Primo Ramdisk (server!) make is excellent job with no issue if installed in this way.
    4) in my system HQ is better in RAM on W8.1 and in C: on WinServer but also in W8.1 with fiber connection. NAD is always better in ramdisk, with both OS.
    5) music files sounds always better from ramdisk
    The fact that I'm using a nodac (DSD direct stream from JLSounds I2S over USB interface, with only a first order lpf) allow me to listen to each change of SQ without any DAC (and his manipulations!)interference, a great advantage in my opinion.
    Probably this setup is the better you can get with a pc but it's a very complex system, I'm still testing the great number of combinations in the sound signature considering the relationship derived from the sum of HQ+AO+Jplay, each one with complex settings crossing mutually.
    My aim, at the end of this complicated evaluation, is to compare my previous good server setting W8.1 based (HQ+ramdisk+jplay) with the best final WinServer edition, to decide if this really hard, complex and expansive work make sense or not. Surely it's not trivial....but also very promising.
    Ultima modifica di bibo01 : 19-03-2015 a 07:42 Motivo: english
  8. #288
    Aug 2011
    Su win server 2012 funziona solo la versione di PrimoRamDisk server....
    se lo si installa in gui mode nessun problema.
    se lo si vuole installare direttamente in core mode bisogna avere una copia di oledlg.dll in System32...
  9. #289
    Oct 2010
    I will soon add my version to the soup when I start firing my bullets with a special OS version and a special NAA!
  10. #290
    Feb 2015
    Monaco
    AudioDan
    Have you or do you power your SSD with independant power supply ?
    What do you think is the transmission mechanism of changes to HQ Player Desktop PC to NAA PC ? It can not be RF, so maybe the timing of the USB packets within the block of data requested by the USB receiver ?
Pagina 29 di 31
